Copper strand emergency!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Copper strand emergency!
- This topic has 12 replies, 4 voices, and was last updated 21 years, 11 months ago by
January 2, 2004 at 7:49 pm #11983
I ve finally broken the 4 copper strands off the PCB :dead:
I ve looked at this photo. But I ve got 2 wires coming out of each side of the steering – 4 in total, and can t work out where they all go.
Obviously left and right go to L and R on the PCB – but where does the extra strand from each side go? I m pretty sure one of them was soldered to where the positive battery wire goes… maybe both.
It s a Compact Char-G if it makes any difference.
January 2, 2004 at 8:12 pm #49121
The extra strand(copper painted in black) goes to the positive battery (Red).
January 2, 2004 at 9:13 pm #49122
Just to clarify, the 2 black ones go to ‘positive’, one of the others goes to L, and the remaining one goes to R.
If the steering is opposite after you connect them then reverse the L and R wires.
Goodluck
January 2, 2004 at 9:18 pm #49124
generally i’ve found that ‘L’ on the pcb means the right hand coil and ‘R’ goes to the left coil:8ball:
January 2, 2004 at 10:08 pm #49126
Thanks everyone 🙂
January 3, 2004 at 4:15 am #49128
This is turning into a nightmare. I’ve just snapped one of the black strands (down near the coil) – can I just unwind some more from the coil? Or does this mess up the steering?
… I did get to see it run on 2 cells for a few sweet seconds. And holy crap it was cool 🙂
Not a bad days worth of damage for someone who’s barely done any soldering before.
January 3, 2004 at 4:34 am #49129
unwinding a few cm of the wire won’t affect steering. it’s only if you unwind lots like half of it that you mess it up. just remember to scrape a little of the enamel off the end you’re soldering:8ball:
January 3, 2004 at 4:41 am #49130
Just to make it easier…
When soldering fine enamelled wire, dont scrape the enamel, you just end up breaking the wire.
Here’s how to do it.
Put a blob of solder on the end of the iron.
Push the new (unstripped) enamelled wire into the blob. It will resist going into the molten solder. As you do this ad some more solder to the blob.
What you will find is that the fresh solder contains fresh flux, which is acidic, and this will eat away the enamel and tin the wire.
After about 2 or 3 seconds the wire will be clean and tinned and you can trim it and solder it on to where ever you want.
Its easy once you get the knack, easier than stripping and tinning a standard piece of wire.
Goodluck with it.
January 3, 2004 at 5:02 am #49131
aha! nice tip micro, didn’t realise that:smiley2::8ball:
January 3, 2004 at 5:22 am #49132
Just look and learn my son, look and learn.
And dont say I never teach you anything :smiley2::)uA
January 3, 2004 at 5:52 am #49133
yes paw!:approve::8ball:
January 3, 2004 at 7:26 pm #49136
😀 FIXED!
Thanks for the tips about the enamel – never would have realized I needed to do that. Took me ages to get those copper strands working – must have unwound about 1/4 of the coil (kept breaking!). But it’s all working again, and I got the extra battery hooked up. Dual cell is nutzo – totally uncontrollable and cool. Whoo!
I’ll have to get one of my lxx boosters fet modded soon.
January 3, 2004 at 9:25 pm #49137
aah!:) nothing like the feeling of a successful repair! well done, that’s one of the trickiest repairs to do:dead::8ball:
