cripple cap
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › cripple cap
- This topic has 18 replies, 8 voices, and was last updated 21 years, 11 months ago by
November 25, 2003 at 9:49 pm #11922
just got my first gen-yoo-wine tomy ccg (yay!). these things s##t all over clones! any way i just want to confirm the cripple cap procedure. is this it in the pic below? if so, when i do remove it, do i replace it with some wire to bridge the gap or leave the gap alone?
:8ball: -
November 25, 2003 at 11:02 pm #48203
here is a procedure ph2t posted on ausmicro a few months ago, hope it helps.
November 26, 2003 at 12:20 am #48205
aah, thanks for that. i missed that thread. time for mod number 1!:8ball:
November 26, 2003 at 3:44 am #48211
errr um betty, where did you get that pic from in your first post? That pic is ripped from my tutorial for this mod that barto has given you a link for.
November 26, 2003 at 4:16 am #48213
yeah, i know!! i forgot that i’d read it before and ripped the pic for future reference, but didn’t include the tutorial!:blush:
so yes it’s your pic, sorry if i scared you! (sometimes i’m a bit of a drip!:approve:):8ball: -
November 26, 2003 at 4:23 am #48215
nah that’s cool dude, I was worried that you had gotten it from somewhere else that had ripped my pics….
November 26, 2003 at 4:32 am #48216
btw, i did the mod to the letter including enamelled copper wire and it gave me another meter or two on top of the 10 – 12 i had before. i also put a telescopic aerial on the tx, much better!:):8ball:
November 26, 2003 at 5:26 am #48220
just don’t modify the range too much. U barely able to see the car when it’s 15-20M away from u.
betty.k: ph2t had a few excellent tutorials.
There is the internal Dual Cell Mod. The DIP switch mod and of cource the cripple cap removal. So if u want get started on modify ur Bit. Read his tutorials first. It’s easy.
And once u got the hang of it. Read micro_Amps MOSFET mod tutorial.Edited by – leonli17 on 26 November 2003 00:28:38
November 26, 2003 at 8:11 am #48229
betty, congrats on your first Tomy. You know there is no going back now don’t you:evil:
November 26, 2003 at 3:06 pm #48236
eeyup!! i’m already installing headlights and popped a 2.6 in it and i’ll be adding front suspension as it rolls over on my uneven concrete backyard. i sort of want to keep my new shell relatively unscratched, all my other clones are worn down to the plastic!!:8ball:
November 26, 2003 at 4:10 pm #48238
you drive yours on concrete? i did that once and my steering needed tobe cleaned of all the metal shards. i usually drive mine on the tile bathroom floor, but with slippery tiles, stock tyres and a 3.0 motor, its a hard but fun task.
doesnt the standard CCG come with a 2.2? if so, how could you notice the power difference? unless the 2.2 has poor torque or vice versa, its hard to tell which is faster without a really big difference. (1.0-3.0 for example)
Edited by – twizm on 26 November 2003 11:14:01
November 26, 2003 at 4:27 pm #48240
the motor that came with my ccg was yellow. after comparing it to the tomy 2.6 i bought earlier (orange) i can estimate that the yellow motor must be a 1.0.
yeah, i drive on concrete, got a huge back yard. i just remove the shards by blowing them away or with a little screwdriver. i usually don’t care about all the scratches but this is my special ‘pride and joy’ tomy ccg!!:8ball: -
November 26, 2003 at 9:55 pm #48244
ohh really? the yellow motor, is definitely a 2.2, must be a dodgy one though.
November 27, 2003 at 2:50 am #48246
yeah, it’s weak as pi55. even my stock shen is faster. aah well, that motor’s in the cat’s car now!:8ball:
November 27, 2003 at 4:59 pm #48253
what will that particular modif enable your car to do…
and and my 2.2 motor that i got with my CCG WRX
did not work to start with and now it dose
even dgs said it was dead…
i also have 2.6 motor which i cant tell the diff between the speed of the 2.2 and 2.6
all i know is i want to go faster already i.e 3.0, 3.8, 4.2
1.0 blue 2.2 yellow 2.6 orange and dgs knows the rest
is that any help
cheerbro: pcd79 -
November 28, 2003 at 1:14 am #48263
Thanks ph2t, I hadn’t seen that thread either.
I just had a think about the capacitor and why it’s there. To put attenuation on a rxer isn’t a real clever idea unless you have problems with signal overloading. Even then it makes a lot more sense to attenuate the signal on the transmitter.
The capacitor on antennas is used for two reasons.
One is as a high pass filter to keep low frequencies out like power line noise. The other and more important reason is stray capacitance.The antenna wire forms a capacitor with anything close to it. It’s not much, but it is more than enough to detune the tank circuit in the radio.
A capacitor in series makes sure than any stray capacitance is kept to a minimum.So it is more likely that they had problems with de-tuning and added the mod as an improvement (sic). Does anybody know what the value of the capacitor is ?
November 28, 2003 at 1:42 am #48266
Nah man, being a surface mount ceramic pkg there’s never any labeling for those critters!
bugger!ph2t.
November 28, 2003 at 2:51 am #48269
Save them, because I can measure them if somebody cares to post me one.
I suspect they are about 10pf. I’d sugesst measuring them yourself with a 100M resistor, but even then the cap is still too small. Unless you have a CRO. -
November 28, 2003 at 4:14 am #48272
so what are you getting at here trash? do you reckon a different cap could improve range or clarity?:8ball:
