Does suspension make a difference
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Does suspension make a difference
- This topic has 11 replies, 10 voices, and was last updated 22 years, 2 months ago by
Mut1ey.
September 18, 2003 at 12:20 pm #11353
I’m curious. Does it make any difference? If so, in what conditions?
Mutters
September 18, 2003 at 1:23 pm #33626
well it make a difference when turning and also tring to drive strait.
September 18, 2003 at 1:56 pm #33627
where’s the ham sandwich option?
September 18, 2003 at 6:44 pm #33631
just try driving at high speed without it! rollin i tells ya. springs work even nicer but i wouldn’t recomend doing high speed without the sway bar/tomy suspension part.
in my camo Bb(fitted with afx springs) i removed the sway so i can get maximum range out of my front full size wheels, vert important for traversing bricks with big gaps…..
September 18, 2003 at 9:42 pm #33943
yeah, it might make a difference with different sizes, but it definitly makes a difference with out it!
September 18, 2003 at 10:23 pm #33944
Yes, absolutely.
Whether on a smooth surface cornering at high speeds, or on concrete with many tiny imperfections in the surface, the suspension can be tuned to make the car run better.
September 18, 2003 at 10:58 pm #33945
Thanks for the responses so far. JFI I’m not suggesting NOT using one of these babies – just wondering if changing from the stock bar would make a difference.
Cheers
Mutters
September 19, 2003 at 3:17 am #33857
Yeah. It does make a difference. But the stock bar is good for a internal dual cell car or other heavier cars because it’s lower but it’s too hard. the suspension set u can buy come with 3 strength: hard-i find it good for driving outdoors(concrete); medium:softer than hard and it’s really good for lowerd cars. Soft- good for indoor and smooth surface.(less spin outs)
September 19, 2003 at 6:10 am #33421
I think tyres make more difference, but sure the swaybars and springs do make the car perform better, just drive the car with no swaybar and see the difference.
September 19, 2003 at 8:46 am #33425
If you are on smooth surface going straight it doesn’t mtter but otherwise yes. Cornering is a little bit obvious!
September 20, 2003 at 4:04 am #33547
I’ve spent hours and hours tweakin’ at the front end of my cars, trying to get the steering dialed.
The height of that sway bar, and the height of the steering knuckle seems to make the biggest diference.
I push down on the front corners of my car to make sure the front end has the same amount of dive in either direction.
September 20, 2003 at 4:29 am #33548
Jamie. I drove cars without swaybars and the steering doesn’t return as quick. and the car doesn’t respond as good. That’s because the extra traction between the knuckles and the other steering parts.
