Drifting
Home › Forums › 1/8, 1/10, 1/12, 1/18 – Discussion › Drifting
- This topic has 12 replies, 6 voices, and was last updated 20 years, 5 months ago by
August 4, 2005 at 1:09 am #9904
August 4, 2005 at 2:20 am #19192
Well the RS4 is a 4WD Car, so get enough torque in it and you should be able to drift fine.
Because of the dimensions you’ll probably be best off going for somewhere like a Basketball court to try it, but it should be a buzz
August 4, 2005 at 2:21 am #19193
it drifts fine, just faster!
August 4, 2005 at 3:03 am #19189
Ah…are micro rs4s considered relatively “pricey” cars for their size?
Anywhere to get them in Aus? And any videos of them drifting? I’d love to see some 😀
Edited by – Seatbelt on 03 August 2005 23:14:26
August 4, 2005 at 1:22 pm #19186
to buy off the shelf here ther’re pretty pricey (like 600 aud), but no doubt will have down abit in price since then. Check around, you might be able to pick one up second hand, much cheaper and probably with elecronics installed too
August 4, 2005 at 3:39 pm #19182
Or you can import them from tower for less than 100USD (Plus postage) for the Kit. or just under 200 USD as a RTR
August 4, 2005 at 4:12 pm #19179
wow!! They have come down in price… might have to grab another one… or maybe I should’nt have sold my first one after all
August 4, 2005 at 9:05 pm #19178
What’s the most basic “good” setup I could have with a micro rs4?
August 4, 2005 at 9:51 pm #19170
Its a hpi pro in a smaller scale if that helps…
You can do heaps to it but im not sure on/of a basic setup. :smiley2:
Buy 1 and start from scratch and find out what works best for you.
August 4, 2005 at 11:11 pm #19167
Ah ok, how are the electronics included in the RTR packs? Are they worth considering getting if I have no rc gear except for the radio stuff?
Also noticed, the other 1/18 car, Xray M18. How do they compare to the MRS4s?
Edited by – Seatbelt on 04 August 2005 19:19:50
August 5, 2005 at 2:45 am #19162
If i had the money i would have either > Back to Drifting
I just managed to get into my local shopping centre with My fetted car (01 MZ 2×4 stack with iW Xspeed Pro) With the Dif fully locked i managed to drift with ease on a waxed floor But it took a bit of throttle juggling with alot of under steer at the front… FUN :p
On the point of under steer at the front you give it a mass attack of foward throttle and around the back end comes then of throttle to even out, Only using reverse to flick turn the car if needing a direction change or if your going to impact something…
That’s the best i can do at explaining it…
Give it a try and then you will know of what i am talking
August 5, 2005 at 1:17 pm #19156
If you want an Aussie source that’s pretty dam cheap with HPI stuff get onto Mark and Deb at MRC Model cars (http://www.mrcmodelcarparts.com.au) The know their stuff, and won’t screw you around 🙂
August 5, 2005 at 2:40 pm #19153
M18 is a more professional level of finish (typical of Xray
), needs less hop ups added to it to perform. They’re both good, but if you want to drift, get the HPI. If you want to race, go the Xray.M18 hold their own amonst the 1/10s, too… (the one I saw racing did, anyway!!!)
