Drifting with Mini-Z/iWavers
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › Drifting with Mini-Z/iWavers
- This topic has 5 replies, 4 voices, and was last updated 20 years, 4 months ago by
FALCON-LORD.
August 1, 2005 at 12:40 am #9912
Is it possible to drift with Mini-Zs or their iWaver counterparts? Any mods that could allow them to? Thanks
August 1, 2005 at 1:53 am #19251
Drifting is about loosing traction with all wheels and maintaining a controlled slide.
The Mini-Z is a 2WD car, so can never truely drift.
You can establish a drift then counter steer into it and simulate a proper drift in this fasion.
If you want drift, you need to have maximum torque, and minimum grip.
I have managed to drift both my OL and My MMZ, the OL running with a standard X Speed, and the Monster with a Plasma atomic and a Whoa Nelly. The Key is having the right serface after that. (And the right tires)
August 1, 2005 at 2:47 am #19245
So what did those drifts look like? Realistic? Could you just wrap the tires in tape and run it on tiles?
August 1, 2005 at 1:35 pm #19241
If you wrap the tires in tape you can run on some carpet… on Tiles you will find that gives you to little grip and makes it a bugger to get started.
The other problem with tiles is you have the grout lines that will bugger up your drift all the time, you are better of with a lino flaw, or polished boards.
August 2, 2005 at 1:15 pm #19231
Seatbelt; I got mine to drift quite happily when I still had a Plasma Dash powered Z, just found you had to stiffen up the springs on all corners (yellow plus an o plate works well…), and hard rubber, about 40-50 degrees
August 2, 2005 at 7:47 pm #19217
powesliding action has been acheived on the foam matts i bought to make a track. great fun!
