enertec bit clones, $16 aud!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › enertec bit clones, $16 aud!
- This topic has 19 replies, 7 voices, and was last updated 22 years, 2 months ago by
December 10, 2003 at 6:04 pm #10110
i’ve noticed that enertec micro chargers are $16 at dse and tandy electronics. cheap enough to throw away when the batt’s go flat! they come with a dual nimh cells, and 2 speed as standard. perfect for a full suspension mod:8ball:
December 10, 2003 at 7:16 pm #21204
hmmm ill be back later im going on a excusion to tandy 😀
December 10, 2003 at 11:45 pm #21122
Thats a damn good price for those.
I wish I had known before I got home, oh well there’s alway tomorrow.
December 11, 2003 at 4:48 am #20861
That is cheap(like $10 off the original). And Kmart got the HotWheels RC which use the same controller and Chassis. Only the shell is different. But they cost $24
December 11, 2003 at 7:59 am #21002
I hate the way they slow when you steer (off boost) it sound like an OK idea, but sucks in practise.
December 11, 2003 at 11:25 pm #20413
Im sure that can be modded out.
December 12, 2003 at 4:54 am #20523
i don’t mind the slow turning function for normal hooning but in technical and rough terrain it would be nice to have boost while turning. so whatta ya reckon micro, up for the challenge? i’ve got a couple i’d like modded!:8ball:
December 12, 2003 at 5:04 am #20524
Yeah I’ll give it a go. Send them over.
December 13, 2003 at 8:39 pm #38842
i bought one today, they are great. i love them and they go really fast you get good range and the head lights and tails lights are kool, but how do i take the body off.
December 13, 2003 at 10:24 pm #39418
you can use a 2mm flat screwdriver to get that screw out. i replace it with a normal phillips head screw:8ball:
December 15, 2003 at 2:27 am #38829
my car fell of my table the sarv and now, when it hits the turbo it doesnt really work properly, any suggestions what could be wrong with it.
December 15, 2003 at 2:56 am #38828
wow. these cars sound pretty good
are they worth getting?
what bodies do they come with?
same size as normal char-gs?
any pics? -
December 15, 2003 at 3:54 am #38827
brendan: :sad:i feel your pain! i’m no techo so the best advice i have is check for broken wires and have a close look at the transformers around the motor wires. the first one i bought died after 5 goes, but i found out it was a dud motor. i just replaced it and haven’t had a problem since, so test the motor as well.
dizzy: i think they’re unreal! but it was one of the first cars i bought so i’m a bit biased. check this thread for more info: -
December 15, 2003 at 4:00 am #38825
yeah these cars are great, they are super quick.
@betty.k-how do u remove that bit of plastis above the motor -
December 15, 2003 at 4:15 am #38826
remove the screw that holds the pcb down and CAREFULLY lift the pcb. enertecs are not wired up as neatlty as a bcg and there’s a bit of tape holding the batts down which has steering wires stuck to it so go easy. you’ll see what i mean. once you’ve done that you’ll notice there’s 2 screws in the motor cover. take ’em out and with a small screwdriver pop the cover off through the tab slot behind the motor.:8ball:
December 15, 2003 at 4:18 am #38824
thanks man, but i dont think it is the car. I think it is the controller. because i noticed when i put it all the way doen the led light blinks on and off
December 15, 2003 at 4:27 am #38823
i have a controller that stutters in reverse too, probably a dodgy terminal, but i fixed that, and this brings us back on topic, by buying another one. they’re cheap enough to set fire to for fun!! but remember kiddies, don’t play with fire unless under strict adult supervision! and brush 3 times daily. and respect your parents. and……..:8ball:
December 15, 2003 at 4:56 am #38822
and even if u do stuff the car up you no u got a kool set of wheels for ur bit. remember kids dont call girls sluts unless they really are sluts. and only play with fire if u really fell the need to, like this http://www.sharemation.com/brendan123/fire.wmv i bet i tought that punk a lession never to mess with me again.
Edited by – brendan123 on 14 December 2003 23:57:14
December 15, 2003 at 5:11 am #38813
:Dheh heh! you get bored easy, don’t you!:8ball:
December 15, 2003 at 5:15 am #38814
howd u guess:D
