Few Z Q s
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Few Z Q s
- This topic has 10 replies, 4 voices, and was last updated 20 years, 10 months ago by
January 12, 2005 at 11:21 pm #12502
Ok
got a MR02 RTR kit coming soon
will be buying ball bearings for it first off..first q,
how good is the xspeed?…the car comes with it, ive read you dont need a FET upgrade to run it..when making say a 4×2 stack do you replace the stock fet?
or solder on top?thanks
January 13, 2005 at 1:19 am #57971
x speed motors are good, i used to run one with a 10t pinion and it was definately fast enough to keep you on your toes.
when doing fet stacks you remove the stock ones.:8ball:
January 13, 2005 at 1:51 am #57972
ok, thanks…
whats the biggest stack a MR02 can fit?…
ive heard the 3×2 stack works very well -
January 20, 2005 at 12:59 am #58080
im pretty sure thats what ph2t stuck in his i-waver 02.
January 20, 2005 at 3:10 pm #58099
3×2 is about where it’s at for optimum performance and space efficiency.
I sell them in 10 packs becuase my experiements showed that beyond 5×2 nothing went better when you balanced up the hassle of making stacks bigger.
3×2 can be made to fit anything (little plastic work on iWaver though) and 2×2 has enough punch for a X-speed to be quite a pleasant drive it can’t take the Plasma Dash hybrids 😉
January 20, 2005 at 6:04 pm #58104
well i just bought a 10 pack from you..
so i guess ill be doing a 3×2 stack maybe.. -
January 21, 2005 at 9:57 pm #58138
ok, recieved my FET’s and the Mini z today
one prob, i bought some berings for it off the ausmicro store…i fitted 2 BB to both front wheels, 2 BB to hold the diff axle thingt, then i only had 1 BB to put on the rear wheel thats near the gear…the other one has only got a plastic bushing, cause i was 1 BB short..or is it supposed to be like that…i only opened the bearings today…it had 7 BB in it…but ive taken it for a run in the garage…heaps of fun..:D:D:D
January 21, 2005 at 10:25 pm #58141
It’s correct, you leave the plastic bushing in the space where the wheel and diff lock together, ie the shaft and wheel are fixed together.
January 21, 2005 at 10:50 pm #58142
ahh was a bit worried..but now that i look at it, the bushing dont move on anything..
thanks..also, ive looked at the pcb to put on the FET’s..hmmm looks harder than i thought, the pcb is upside down, so the fets go down into the chassis, know where a step by step guide on how to do it?
January 24, 2005 at 4:57 pm #58213
The quick guide is remove PCB from chassis, (leaving wiring connected) de-solder FETs, solder in new stacks…
I haven’t opened an 02 though so I don’t really know the foibles of doing the disaasembly though.
January 24, 2005 at 10:02 pm #58235
ikinari has documented a really good way of stacking fets in an 02:
http://www1.bbiq.jp/ikinari/mini-z/mr-02.html#fets
in fact he’s documented heaps of cool mods!!:p
