Ford Focus WRC IW-02, cool!!!!
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › Ford Focus WRC IW-02, cool!!!!
- This topic has 9 replies, 9 voices, and was last updated 21 years, 2 months ago by
z-beam.
December 8, 2004 at 5:28 am #10285
Check it out, my new toy…..:p:p:p:p:p
I gotta say that I’m pretty impressed, with just a handfull of hop ups, the IW02 handles better than my mr01 ever did. What I have done to the IW-02.
3racing ball bearings
kyosho mr02 hard front springs (yellow)
I put graphite on the front kingpins to help smooth out the front suspension
3racing rear roll shock set for mr01, medium springs (green)
kyosho stock mr01 gear diff (old one I had)
pn racing modified motor mount ( I knew I kept it for a reason!)
stock iwaver motor in an ATOMIC can with neo’s ( I did this because I needed a can that had the screw holes in it so it would screw onto the pn racing motor mount) No fet stack or nelly turbo yet, hence I why kept the stock armature.
The stock parts you get with the iw02 are crap, these include the screws (the heads strip easily), h-plates are craooy plastic. the rear diff is even worse that when I got my iw-01 ages ago.
so some things must be replaced, but the motor mounts (RM and MM) are both good and I didn’t have any issues with them. I chose the pn racing one cause it fit the best with the ford focus shell…
the motor is stock iwaver motor. I did notice when I pulled it apart to transfer it to the atomic can that there was a lot of crap on the commutator that required cleaning….. now I’m running the stock iwaver armature in an aTOMIC can with neo’s and the 9t pinion. This provides for great accel (given stock fets) and good top speed.
But as I said before, the biggest thing is the handling. The chassis comes though the corners a lot more even now and will maintain that line you set earlier on in the turn. I accoplished solid turns with 2/3 power. There were quite tight turns and given the slighty rough (concrete) surface Iwas happy.
This car is now definately a track only car. With the detail on the autoscale shell is mad!
for the price, I give the IW-02 a big thumbs up. I would definately get the following though
bearings
better diff
graphite mr02 h-plates
mr01 roll shock set (or mr02 rollshock set, depends on motor mount setup)so there you have it!
cheers,
December 8, 2004 at 5:42 am #23977
go the focus!
December 8, 2004 at 6:37 am #23979
lookin good, i like details on that body indeed.
that the same roll shock as you got for me? it looks pretty top quality!
also i got that hi-dash motor for you…
December 8, 2004 at 7:25 am #23975
…the focus body ROX!! Definately need one for a repaint job…If i find some i will pick up two 😉
December 8, 2004 at 7:43 am #23976
nice looking ride there…. need some good spotlights for some cool night time rallying 🙂
bit if ya find a couple add 1 for me will ya please
Edited by – Priest on 08 December 2004 02:45:48
December 8, 2004 at 12:43 pm #23968
oooooooooooooooooo toy *prod prod*
hehehhee iw02 still fettable like the 01s?
nice ride ph2t love that focus shell and every1 look its ridin high. -
December 8, 2004 at 12:51 pm #23966
the smart money says don’t let me near it!:dead::8ball:
December 8, 2004 at 3:21 pm #23951
Yeah the focus looks sick i wonder how an IW02 will go up against a MR02 i reckon it would be a good race ……:D:smiley2::D:smiley2::D
December 8, 2004 at 3:54 pm #23961
For info, I have an IW04 coming in the group buy so we’ll see how well FET modding works on that board 😉
I belive the 02 type of chassis is vastly better than the 01 for handling…
So how does it rate against the X-Mods ph2t?
December 8, 2004 at 5:36 pm #23954
kicks its arse i bet…
untill he puts the 02 pcb into the xmod and then we will see an equal test of each chassis’ abilities…
