Go Faster
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Go Faster
- This topic has 21 replies, 10 voices, and was last updated 22 years, 5 months ago by
LILNismo.
September 28, 2003 at 11:22 pm #11313
Ok, As this is my first post i’m going to keep it simple. Just got my first Char-G, what is the first thing i do to make it go faster?
September 29, 2003 at 1:43 am #32448
change motor…gearing….more powerfull battery….i dont have a bit char g….but ive read through alot of posts….
cheers
dan -
September 29, 2003 at 12:42 pm #32232
yep motor is the first one, then the battery is the next one, these are the first 2 to do and then go onto modding it like dual battery, etc. Try http://www.bitchargoz.tk for a range of hop ups in oz.
September 29, 2003 at 1:36 pm #32235
take off all the parts of the car tyhat have not use. For example, take off the spoiler on your car or dremels down some parts of your chassis. Heck, maybe even remake a body out of somethinf lighter… the possibilities are endless
September 29, 2003 at 2:49 pm #31185
Thanks, for that guys, but where do i get new motor and batterys?
September 29, 2003 at 6:32 pm #39234
Sorry, i withdraw my last statement. Didn’t see Barrelll’s Link, thanks alot Barrelll. Man that 3.5 motor looks good, is it worth getting?
September 29, 2003 at 6:54 pm #32090
3.8 motor is probably the best all round motor going around…
October 1, 2003 at 6:11 pm #31044
That 3.8 that barrelll sells is a monster! Giant torque, acceleration and top speed. Get it!
October 2, 2003 at 12:52 am #31050
If i got that motor, would i need to get a new battery?
October 2, 2003 at 4:45 am #31023
By replacing battery you don`t gain speed it extends the runtime.
For higher speed you need:
-Perfection 3.8 or 4.2 motor
-higher ratio gearsFor top speed you need:
-4.2 motor
-Mos-fet mod
-dual-cell mod
-Bit racer gears -
October 2, 2003 at 10:26 pm #30878
Heeeyyy, Matic finally makes an appearance.
Words of wisdom from the other side of the world.
Good to see you on Ausmicro Matic.
(Sorry, getting off topic here)
He’s right tho, the things on the bottom of the list will get you going REAL fast.
October 3, 2003 at 2:44 am #30820
October 3, 2003 at 3:26 am #30799
I think maybe a tricell Mod will bring u even higher Top Speeds but the lack of acceleration is the upset.
October 4, 2003 at 1:31 am #31169
Plus theres the problem of finding room for the extra cells.
October 6, 2003 at 1:16 am #30547
how do i do a duel/tri, actully just to be novel a quad cell mod?
October 6, 2003 at 2:51 am #30548
October 6, 2003 at 5:19 am #30553
Anything over a 2 cell mod is a waste of time unless you want a drag car.
They cant steer because they are too heavy with cells, and just tip over all the time.
October 6, 2003 at 10:44 am #30556
Dude, that is so true. If anything I just focus my dual cell modding on lxx boosters. That way you have the two speeds to work with and it’s a bit more managable.
October 6, 2003 at 8:20 pm #30562
Tri cell is bad for drag already due to the extra weight/load for the motor. It’s acceleration is slower than a Dual cell so there is no point to make one for drag. but to tackle a top speed, tri cell/quad cell is good(before u burn the motor:D)
October 7, 2003 at 2:02 am #39112
Yeah, you need to be careful on the high voltage bits, only run them for short bursts. If the motor heats up it can burn out. They still run afterwards, but they are very weak because most of the torque producing windings are open circuited.
October 7, 2003 at 3:37 am #30959
I find out Tomy 2.6s has bad qualities. I got two and both of them just suddenly stopped running. It didn’t even got hot. Weird
October 8, 2003 at 12:24 am #30599
With that 2.6 i got that with mine and it has also lost some of it’s power, maybe it stuffed like yours leonli
