heli-q
Home › Forums › Floating & Flying – Discussion › heli-q
- This topic has 4 replies, 3 voices, and was last updated 18 years, 6 months ago by
z-beam.
August 11, 2007 at 11:11 am #12819
i just got one of these today, took a while to get used to it but its a tough little peice of equipment. only 2 channels, infra red with digital trim.
im pretty sure its a bit smaller than the pico-z, but ive only seen once pico, up on the very top shelf of a t’r’u store for a very brief glimpse.
for $50 from a jaycar it was expensive, but it was great to be able to really have a good go on the demo heli before making the purchase.
its good at hovering but after breaking off the 2 “machine guns” at the front it needs more weight to get some tilt so it flies forward.
is there any similar sized 4 channel helis available that are really durable?
heres a link to a japanese site with pics of the heli-q
August 12, 2007 at 7:22 am #60930
nup. the bigger they get the more breakable they get. and there’s nothing that size with full control. and the closest ones cost a bazillioin dollors anyway.
if you’ve really got the chopper bug then your next heli should be a 4ch counter rotating model like the medivac, esky lama, twister bell, etc.
also, when balancing your heli q, rather than “additive” balancing try “subtractive” balancing. eg: instead of adding weight to the front, remove weight from the back. :8ball:
August 12, 2007 at 9:42 am #60931
the tail end consists of a single metal wire, bcg size motor and stickers covering the metal frame. i could trim the stickers but i really dont want to mess with it.
i stuck in two jewellry pins, kinda like u nails but tiny steel at the front and it balanced out nicely. got some really nice extended flights indoors today.
flying is fun 🙂
even landed safely a few times.
August 13, 2007 at 9:52 am #60932
micro mosquito is similar size and 3 channel I think. Doesn’t look much like a real heli though.
I’m sure someone here has one and can give more details.
August 15, 2007 at 8:06 am #60945
micro mosquito… i saw it and bought one yesterday… great fun and a lot more enjoyable having the extra control.
does “roll” around a bit after moving forwards, but i guess its a challenge of the design.
quite a bit heavier than the heli-q, the throttle is touchier as well. lots more power+lots more weight= funfunfun.
and those eye headlights are great 🙂
<hooke d on choppers now i guess.
