Help with broken controller please!
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Help with broken controller please!
- This topic has 5 replies, 3 voices, and was last updated 21 years, 1 month ago by
January 17, 2005 at 6:03 am #12509
HI guys
I recently bought a MR-02 overseas and i m having problems with the controller.To accelerate and to stop is fine, but the car does not reverse when i push the trigger forward. Sometimes the car goes crazy and starts reversing by itself and i have to stop it by pulling the trigger, other than that my car cant reverse. I know that it is not a problem with the car because I switched the crystal with another controller and it works fine.
Does anyone know about the controllers that come with the MR-02? or does anyone know somewhere where i could get it fixed? -
January 17, 2005 at 1:05 pm #58029
are you sure it’s not a trim adjustment problem?
is the abs brake on?:8ball: -
January 17, 2005 at 3:51 pm #58030
I dont think theres anything wrong with it. It was the same with my bro’s madforce when he first got it. What you have to do to reverse is push the trigger forward (as much as you want) then bring the trigger back to neutral and just pull it back about 1mm(but just tap it and wait 1/2 a second) and it should reverse.
January 17, 2005 at 3:58 pm #58031
Mr02’s have a brake function. The funny thing is when we put the x-speed in it all we had to do to reverse is double tap the control forward (once for brake second time for reverse).
January 18, 2005 at 12:33 am #58044
ignore the abs brake question from me, i was thinking iw02:clown:
sounds like your trim is out. put the car on a stand so the rear wheels aren’t touching anything. fiddle with the throttle trim until it starts to creep forward, then back it off until it stops and is silent.:8ball:
January 18, 2005 at 5:56 pm #58057
i know about the double tapping in order to reverse and it still doesnt work.
I’ve also tried the throttle trim and that doesnt do anything either. Even if i put the trim to reverse maximum it stays still. Im pretty sure there is a faulty connection inside the controller because when the car goes on its own crazy reversing sprees then i can reverse using the trigger. Thanks anyways for the help guys. I ll ring around to see if there are any stores that will repair it.
