I NEED HELP! SOME EXPERTS NEEDED!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › I NEED HELP! SOME EXPERTS NEEDED!
- This topic has 14 replies, 3 voices, and was last updated 23 years, 11 months ago by
November 8, 2002 at 5:43 am #9503
i was driving my bit on the kitchen table, when it feel on the floor. Wwhen i picked it up, the motor, and the clip were both not connected in the chassis. so i put it back in, and drove it, but the clip keeps slidding off when it runs. Also, the gear that turns the motor, keeps coming off. does it stay in place, or is it supposed to come off? anyway, when the thing runs, it makes a rattling sound, and somtimes has trouble starting becuase the back wheelies dont rotate right. I need to turn the wheel for it to start. I need someone to really help me out with this. PLease answer back or just email me at pakiplaya@hotmail.com. Thank you
November 8, 2002 at 7:21 am #17079
Sound like you might have bent theclip/heatsink. is theclip flat? (the bit that supost to be flat anyway) if not bend it back cos it sould like as if the clip isn’t holding the moter in snugly anymore. Also check if any of the plastic that the clip pushes up agences isn’t bent,twisted or broken, if that happen, you need a new car body (or if you are good at melting plastic) So the answer to the question “is it supposed to come off” is NO, it should be a tight fit and sould take a bit to get the clip off.
best of luck
November 8, 2002 at 7:24 am #17081
I think you’ve damaged something in the rear end.
Take it apart, then check the chassis carefully for cracks… anything even broken off?
Sounds like your axle is bent too… see if you can straighten it back. Find something flat that’s 1cm wide (I use a little metal ruler) and roll the axle on it, you’ll soon see where its bent.
Also check your gears, there may be a broken or damaged tooth.
It is not a good idea to fall onto the floor, especially if its a tiled or hard floor. That 1m drop is like driving off a cliff 200m high in your 1:1!!
November 8, 2002 at 7:26 am #17083
sounds like you have a few different problems and each needs to be treated individually. ok when you say clip doyou mean the metal heat sink or the black plastic tab on the chassisthat the shell and the heat sink secure onto?
November 8, 2002 at 11:17 am #17121
if you have any cracks in your chassy get some 90 sec. epoxy then repair them with that then use a rotary tool to file it down a lil.
November 9, 2002 at 3:19 am #17181
ok the heat clip is ok now. it goes in place, but the ider gear, or idler i dont know how to spell it, keeps slidding off. its the gear that rotates the motor. It keeps slidding off. is there a way to make it stay in place, and is it supposed to slid off, this IDLER( or IDER) gear?
November 9, 2002 at 4:12 am #17187
its called the pinion use super glue to hold it
November 9, 2002 at 4:55 am #17190
oh ok
November 9, 2002 at 8:24 am #17200
how come my heat sink clip isnt connecting or snapping in?
November 9, 2002 at 9:00 am #17206
check to see if theres a crack whare it snaps in if not try pulling the part whare the heat sink snapins into the chassy out a lil and that should fix it.
November 10, 2002 at 7:42 am #17214
but them it wont rotate!!!!
November 10, 2002 at 7:42 am #17215
do u mean by putting some glue so that it will stop the post from going through the whole? and where do i put this dab of glue?
November 10, 2002 at 9:48 am #17226
put it on the ruff side then make shure the ruff side is on the oppset side to whare the gears go.
November 11, 2002 at 4:48 am #17304Quote:Originally posted by arabicryda on 10November2002
The shaft does *not* rotate on the chassis. The idler gear only rotates on the shaft. Fix the shaft so that it cannot move left/right and there’s enough shaft for your idler gear to sit on, and you’ll be fixed.
November 11, 2002 at 7:03 am #17317
THANK YOU THANK YOU THANK YOU, I GET IT NOW, I WUZ SOOOO CRAZY, THANKS ALL OF U, AND MORE TO PANDABEAR, U DA MAN:smiley4:
