I push left, it goes right!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › I push left, it goes right!
- This topic has 9 replies, 4 voices, and was last updated 22 years, 11 months ago by
Impreza.
November 6, 2002 at 4:27 pm #9485
Hi Everyone,
Just got my brand new replacement Trueno Set. Unfortunately every now and then it turns the wrong direction. I can be holding the controller down to turn left and it turns right. The same thing happened a couple of times with my Accord. Has anyone else had this happen and if so any easy tricks for stopping it? I ain’t sending it back again.
November 7, 2002 at 2:08 am #16866
Have you checked the axles of the front wheels for lint or hair ? It doesn’t take much rubbish on the axle to start causing a problem with steering. Do both front wheels spin freely and spin the same amount ?
November 7, 2002 at 5:54 am #16891
It was brand new so there’s no crap on it. The steering works fine but it will turn the opposite direction to the one I direct it to and it’s only intermittently.
November 7, 2002 at 7:27 am #16914
Have you checked whether or not the steering wires are shorting or touching each other inside the chassis ? Might be worth just popping the board out and putting it back in, making sure that the wires aren’t touching.
November 7, 2002 at 9:31 am #16932
Just a thought, what mhz is it? Do you have anything your place that might run at the same freq?? Maybe try it in a few different rooms to see if it still does this? Again just a thought.
Cheers.
November 8, 2002 at 2:10 am #17048
Thanks Guys,
I tried it again last night and it only did it twice. I might try opening it up just to check. It’s27MHz, which is of course everybody’s favourite! Where about’s do the steering wires run? Thank again
November 8, 2002 at 5:43 am #17066
On the PCB in the car, there are 6 wires that connect along one side of the board. The contacts that they connect to are labelled V+ (voltage), F (Forward), B (Back/Reverse), L (Left), R (Right) and GND (Ground). Check that the uninsulated wires running from the Left and Right contacts do not touch any other uninsulated wires. These wires (L & R) go from the board to the coils in the front that control the steering.
Hope this helps
November 8, 2002 at 6:17 am #17070
Thanks heaps,
I’ll have a look tonight.
November 8, 2002 at 6:27 am #17072Quote:Originally posted by Genspec on 08November2002
Actually those wires *are* insulated – otherwise you’ll have a lot of fun winding the magnets without them shorting out.
Those fine copper wires are painted with clear lacquer, which is the insulator. If you need to resolder them for any reason, use sandpaper and sand the tips where you want to solder, otherwise the soldering won’t work.
Take care not to wreck them – those wires are finer than human hair.
November 8, 2002 at 1:33 pm #17159
If you are just reattaching them you should be ok without sandpaper, since the ends should already be bare. At least I was able to re-establish a good contact when I re-soldered mine on, don’t ask how they came off in the first place…:smiley9:
