i waver and plasma dash situation
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › i waver and plasma dash situation
- This topic has 10 replies, 6 voices, and was last updated 21 years, 8 months ago by
jamiekulhanek.
June 23, 2004 at 3:20 am #12205
i ve just run with my first hot motor and it seems to be starving the steering motor of power. when under load like accelerating the steering is very slow, acting the same as if the batteries were flat. jamie suggested an electrolytic capacitor across the battery terminals, and i m thinking the stock i waver steering fets could be replaced. anyone else had this happen?:8ball:
June 23, 2004 at 3:51 am #52699
I can’t honestly see how changing to higher current FET would affect this, cause if they are getting starved, then it won’t help the problemone little bit, however, if the problem is something else, be my guest to bitch slap me.
June 23, 2004 at 12:02 pm #52703
lol i want one of jamies motors now so it can wreak my xmods and i can bitch slap him
June 23, 2004 at 5:55 pm #52718
i just tried the capacitor (10v, 470 uf) and it sorta helped, but not enough. i’m guessing a bigger one will help but that will be huge and no one else has had this problem. pork hunt is running the same setup and he’s having no trouble with steering (except for the busted servo gears!):8ball:
June 23, 2004 at 8:33 pm #52726
mate ‘ill tell you now one of these sorry his motors will KILL your Xmod.
June 23, 2004 at 8:43 pm #52731
things get mighty hot with these motors that’s for sure! i had the stock switch burn out on me (literally!). i can understand people making fireworks with these using no turbo or fet stacks:8ball:
June 23, 2004 at 9:33 pm #52733Quote:…when under load like accelerating the steering is very slow, acting the same as if the batteries were flat.
Put a voltmeter (preferably analog) across the battery.
Check if the V is dropping a lot at full load.Some brands of (I’m assuming) AAAs have very high internal
resistance and when you load them high, they can’t pump
out enough juice & the V drops. Battery gets hot. -
June 23, 2004 at 11:46 pm #52737
i checked voltage. i’m using the xspeed at the mo, and at rest it’s 5v and when using full throttle it drops to 4.6. and when going forward and reverse it drops to 3.5. i’m using a digital multimeter so all values are averages. i tried the plasma with powertech 800mah nimhs and energizer nimhs. perhaps the resistance lies in the switch. with i wavers the power switch sits (electrically) between the 2 sets of 2 batteries, whereas a kyosho has the switch wired to the pcb. so the iw switch is right in the firing line. as i said one switch burnt out, a melting scorching burn out. and everything got hot, not too hot but definately not warm:8ball:
June 24, 2004 at 1:55 am #52750
Changing FETS wouldnt fix your problem, it may make it worse as they might allow the motor to draw more current.
I put a 6v 3300uF capacitor on my little bro’s Z, it fits nicely, its not that big either because its only 6v.
If it is the switch, maybe wire it to turn on a low resistance relay or something like that ? -
June 24, 2004 at 3:01 am #52759
all points noted!:smiley2: with the fet replacement, i was refering to the steering fets.
i’m just sourcing components from old junk so it’s old technology, ie big. i’m sure i’ll find a higher value, smaller size at jaycar. basically my setup is this:i waver
powertech nimh/ energizer nimh
plasma dash
whoah nelly turbo
switch from an enertec (aint blown yet!:p):8ball: -
June 24, 2004 at 3:18 pm #52775
It sounds like the switch is arcing, which is limiting the current available, and causing RF noise which is amking the steering screw up.
