Ideas for having a car with no visible arial.
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Ideas for having a car with no visible arial.
- This topic has 15 replies, 10 voices, and was last updated 20 years, 8 months ago by
RacerX.
August 9, 2003 at 5:30 am #11230
Topic pretty much sums it up. I was playing around with newly bought GTR from Toys R US here in Japan, and I managed to tuck in the cable completly inside the chasis. Obviously this reduced my range quite dramatically and was pretty much useless.
What Im trying to find out is, is there any way or any other technology that can be used to have a respectable range without having the antenna visible.
The cars look so much hotter and realistic with no giant antenna sticking out and destroying all sense of reality.
Any ideas ? How do those mobile phones with no antennas work, is there something we can hide inside the car and get almost the same range ??
MxM
August 9, 2003 at 10:35 am #21813
mxmm,
make an antenna like a thunder chargers -
August 9, 2003 at 1:13 pm #21814
First off, welcome to the board fellas.:)
mxm, mobile phones can afford to have small antennas ’cause their freq of operation is so high. General rule, the higher the freq, the shorter the antenna to have the same effect.
Personally I use electric guitar string that is very fine and tensile. You can’t even tell that it’s there.
August 9, 2003 at 1:19 pm #21815
superman can see everything
August 9, 2003 at 2:58 pm #21816
I got a clone and i ripped the arial off and i still had really good range.
August 9, 2003 at 5:09 pm #21818
how is the range when using the guitar string does it affect it at all?
August 9, 2003 at 5:32 pm #21821
I think it actually increases the range. ph2t will be able confirm that when he’s on next.
August 9, 2003 at 7:50 pm #21823
Get yourself a roll of thin enamled wire.
Coil it up into a square loop that will fit inside the roof of your chassis. About 20-30 turns should be enough and just solder the wire to to terminal where the antenna used to be.
You might also consider trying to build a small
loaded antenna. Basically, get a small ferrite
slug (from an old AM radio.. look inside the tiny metal can’s, you can get the enambled wire from them too) and put 5-10 turns onto the slug and leave the rest of your antenna to protrude.
I haven’t tried this one myself, so at the moment it’s just a theory. If your looking for information on the web about it, look for “loaded antennas”. -
August 9, 2003 at 10:02 pm #21824Quote:how is the range when using the guitar string does it affect it at all?
Guitar string antenna and crip cap removal has given me a steady 9 meter average indoors.
August 10, 2003 at 3:09 pm #21830
cool i might have to give it a go thanks for that ph2t
August 10, 2003 at 3:26 pm #21832
my rsx is cripple capped, i couldnt find it so i might trythe guitar thing. How do u do it? i dont want to open the pcb stuff but
August 13, 2003 at 8:27 pm #21914Quote:my rsx is cripple capped, i couldnt find it so i might trythe guitar thing. How do u do it? i dont want to open the pcb stuff but
but what? but i spilled it all over my pants? but i ate it last night? heh just some strongbad humor just use a soddering gun becareful though, i accdently broke a car while soddering once i was so mad i almost gave my self 3rd degree burns waving the bloody thing around but anyways back to the point, use a soddering gun u can pick one up at ur local RadioShack, hope this helped, in anycase if im absolutely totally wrong Feel Free to Spam me till i Cry
August 16, 2003 at 4:13 pm #21993
I’ve actualy dremeled a hole big enough for the areial in the bonnet of the car I run the ant to the clip on the pcb and the down out the hole makes it look like a normal car ant and height
April 25, 2005 at 2:15 pm #20465
MXM The reason why some electronic devices or cell phones have no antenna’s, is because they use (micro strip antenna’s) ecth on the PCB.THE antenna load is match to the circuits input and output stages of the amplifiers stage (impedances).Its called RF impedance matching.In RF circuit design. This is not a theory. ITs a fact.Look up impedance matching for RF CIRCUITS.And Micro strip PCB antenna’s.Or PCB’s ecth antenna’s.You could try what TRASH commented on. Using the magnetic wire and, form a loop coil to form a antenna but you still have to match the load with the impedances of the last stages of the amplifier to any antenna you use for this kind of load.If you don’t do any impedances matching of your load for your loop antenna and size of the wire and lenght in will not work.And the loop coil that TRASH commented on would be the easise way and cheapest. The guitar wire that PH2T used is just a wire the same as a dipole antenna with the, I guest the same lenght of wire he had in the car in the first place. he just changed the type of wire used. It did not change the load of the wire or the impedances of this wire thats why I assumed it worked in his car.MXM you can try no wire but the car might not work. Or you will get a short range it depends. GOOD LUCK.:smiley16:
April 25, 2005 at 7:41 pm #20463
crikey! this is an oldie, good value but:8ball:
June 21, 2005 at 9:04 am #19752
Also keep in mind that there is no isolation between the antenna and the tuned circuit in the receiver. So a different antenna or configuration may detune it.
