Its here! 2-speed Boost Up!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Its here! 2-speed Boost Up!
- This topic has 10 replies, 3 voices, and was last updated 24 years ago by
PandaBear.
October 18, 2002 at 7:39 am #9330Quote:Originally posted by Chris_Flowers on 17October2002
I’d like to see them put joysticks in instead of buttons, makes it feel more like an R/C then a toy! I saw the mod for it somewhere – probably QFM…
Nothing personal, Chris… but RC = TOY.. :smiley3: Coming from one who’s played for 25+ yrs, RC is my life – but its still very much a toy.
Why don’t you mod one of your TXes with sticks? You might soon also discover that the TX box is too small to give enough leverage to use sticks, unless the TX is stuck to a table. Good idea in concept, but lacks a little in the implementation.
October 19, 2002 at 12:52 am #15589
This is the kind of thing you need for controlling a booster car:
The trigger control is off some cheap Nikko R/C car and didn’t work so I wired it up to behave like an ordinary joystick for Spectrums/Amigas etc., only the trigger controller has two forward settings which would be ideal for wiring up to the booster button.
October 19, 2002 at 2:56 am #15590
Is this someDIY booster system? Man that’s talent =)
October 19, 2002 at 2:04 pm #15605
K.I.T.T so you press the trigger once and it drives normally, then you press it down further and you get the boost right? Thats pretty awesome man :smiley1:
October 19, 2002 at 4:46 pm #15614
Putting the boost button above the “go” button would have been a lot handier… hmm… not hard to add an extra pushswitch with flyleads…!
October 19, 2002 at 5:01 pm #15616
Chris, yep that’s the idea only it’s plugged into an ordinary OEM controller that’s single speed, have yet to get a booster setup I can really make it work with.
October 19, 2002 at 5:20 pm #15621
Oh hey you guys must not know about the joystick port project I did with my first OEM Bullet controller as I did this like over 6 months ago. Check it out: http://62.188.32.182:1453/~rid/OEMjoystickport/
October 20, 2002 at 7:29 am #15635
Wills,
where did you buy the fairlady Z?
October 20, 2002 at 7:40 am #15637
Hi Guys,
Just wondering if you can switch the Fairlady and Auto Modelista set to run at full speed only like with the four band controller.
Thanks
October 21, 2002 at 9:28 am #15691Quote:Originally posted by Shypo on 20October2002
Usual hongkers place.
October 21, 2002 at 9:33 am #15692Quote:Originally posted by Trueno on 20October2002
Nup, can’t switch anything (not like “B” or “C” on the 4-band).
Then again, it wouldn’t be very hard to solder in a switch or jumper to short out the boost button and put it permanently on. (Already have some unique ideas, but didn’t want to hack up this 1-n-only Zed.)
I’m wondering myself what happens if we use a ‘normal’ 57M controller with the Zed… unfortunately this is my only 57 set.
