iw01 steering prob
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › iw01 steering prob
- This topic has 7 replies, 4 voices, and was last updated 20 years, 9 months ago by
merc-blue.
May 14, 2005 at 5:23 pm #10020
I have an iw01 pcb in a mini-z setup. For some reason the steering wont go back to the centre position properly. It goes staight to start off with but if i turn left (or right). when I stop turning The wheels dont centre properly. They stay slightly to the left or right depending on which way you just steered it. If I replace the original steering fet, will it solve the problem?
May 14, 2005 at 9:20 pm #20191
probly a dead steering pot
May 14, 2005 at 9:26 pm #20187
yeah iwavers are good cheap fun. real cheap!!
if the steering pot is dirty then this site should help, step by step process and pictures.
http://minizcanada.com/tech/suspension.php
if that dont work then its a broken pot, a steering pot aint that much, if you use a kyosho pot u can use kyosho or after market steering gears which are alot better then iwaver quailty.!
so if your up for a bit of soldering it is not much of a problem
hope it helps.
May 14, 2005 at 9:34 pm #20185
it’s more likely the servo pot. have a look back through the forums, we’ve covered this before
May 15, 2005 at 6:47 pm #20180
thanks guys
. you’ve saved me a lot of trouble once again
May 17, 2005 at 7:30 pm #20140
changed the pot and the servo motor to kyosho and it still does the same thing, even a bit worse
. I noticed theres only one fet for the steering. Instead oftwo like on the mini-z pcb.If I use a 7317 fet instead will it work at all? The Whole servo is kyosho now so I dont think thats the problem. -
May 17, 2005 at 9:16 pm #20135
I’m using a mini-z controller as well. would that make a difference?
May 17, 2005 at 10:41 pm #20139
yer could be some the problems.
everytime i used my mini z controller wih the iwavers they acted strange, try the iwaver controller see if it werks.
