Iwaver 04 is OUT!!! It’s Madforce but better.
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › Iwaver 04 is OUT!!! It’s Madforce but better.
- This topic has 24 replies, 9 voices, and was last updated 21 years, 3 months ago by
bithed.
December 1, 2004 at 6:49 am #10316
Iwaver 04 Is OUT in TOYEAST. Grab it while u can. SICK Controller!!!!!!!!!!!! Has E{A on throttle and steering.It has 10 model memory, as well as ABS brake.
Kinda like a MX3 controller except it’s AM. for $50US nothing to complain!!!!
Check it OUT GUys!!! -
December 1, 2004 at 7:05 am #24362
Sorry to get ur hopes up guys. I just found on the bottom of the photo, it says that the TX has ABS but the 04 RX doesn’t have brake. Damn. But for $50USD, it’s still pretty good.
December 1, 2004 at 12:23 pm #24361
yeah someone get one to test if they are alrite.
iwaver build quailty aint that great man imagine the damage done to these things if you took it off road. hell if a kyosho monster isnt that strong (stock) imagine an iwaver with shitty plastics and such.
alloy is a must ill be guessing.
December 1, 2004 at 12:27 pm #24359
wow! so how does the brake work on the tx? will this tx work on a rx with brake?:8ball:
December 1, 2004 at 2:17 pm #24358Quote:yeah someone get one to test if they are alrite.
i can see i’m not needed here…:D:D
December 1, 2004 at 3:43 pm #39003
…so should i stock up on REAL monster parts now ? 🙂
December 1, 2004 at 4:57 pm #24341
uh, yes… lol 😀 btw, i only have 3 Monster wheels now… heavy landing last weekend cracked one in half. Had taken a big chip out a few weeks ago, and forgot to check it i guess. As a result, the thing is back up on bricks yet again:angry:
Edited by – dgs73 on 01 December 2004 11:58:44
December 1, 2004 at 5:01 pm #24340
i have a slightly chipped one i can flow you 🙂 It’ll be in your next shipment..
December 1, 2004 at 5:06 pm #24335
chrome or white dood? Legend either way… much appreciated:approve::D
December 1, 2004 at 5:07 pm #24336
chrome…i really should mail you today sp we can catch up…typing now 😉
December 1, 2004 at 5:31 pm #38995
sweet… i’ll be off here soon for the day anyway
December 1, 2004 at 7:44 pm #24331
heya guys can someone tell me the difference between the overland and the monster is it just shell and tyre size or are they other differences
December 1, 2004 at 7:56 pm #17899
Monster was designed on the overland chassis, with a few changes to accommodate larger wheels, plus the mounting (shell to chassis) is different. Due to higher mount on Monster the front and rear shock towers are different. Shocks are the same (i have o.l. oil shocks on my Monster), any other differences allude me at the moment… Bithed; wanna lend a hand dood?:D:D
December 1, 2004 at 8:25 pm #24328
same battery case, same esc, same antenna, same crystal, same wheel nuts, same pillow balls; 4.8 and 5.8…umm…bearing sizes are different…rear axle is fatter, knuckles are fatter, rear gear box is different…the floppy bits that hold the front and rear to the battery case are diffrent…body mounts are different…dampers stays are BASICALLY the same but only one size on monster, scraping the bottom of the barrel now…um…the monster is cooler…COG feels lower but that MIGHT just be the body type…oil shox fit both…BASICALLY the Monster is a chunky OL but in reality they are quite differnt machines…Hope this helps some…
December 1, 2004 at 8:57 pm #24326
thanks mate… too hot here to think what small differences there are between the two… but between us we’ve pretty much covered it:approve:
December 1, 2004 at 9:10 pm #24327
thanks for that guys i think you just about covered it all 🙂 cause i was looking at hopups for the 04 and thought the gpm alloy motor mount for OL would fit the MZM 🙂
December 1, 2004 at 9:12 pm #24325
hehehe and here in the West its a nice balmy 26C :p
December 1, 2004 at 9:25 pm #24323
mate our workshop is easily 40 degrees atm… too f**k’n hot. However, beer o’clock has just rolled around…:approve:
December 2, 2004 at 3:09 am #24320
mmmmm beer and monster trucks… just what i’d like for christmas:D
December 2, 2004 at 3:02 pm #24285
I’m bringing in an 04 with the group buy. Will be able to do side by side comparo with my MZ from Bithed (when it arrives ;))
December 2, 2004 at 7:39 pm #24207
now the question of the day is……….i read on another forum that there will be a radical redesign of the monster early next year so if iwaver is changing the design does that mean kyosho is working on a new monster? be interesting to find out if that is the case
December 2, 2004 at 8:07 pm #24203
if they are changing it lets hope for 4WD!!!!!!!!!
even a zip zap monster has aprimative 4wd system and its 1:64th scale.
December 2, 2004 at 8:16 pm #24200
yeah thats what i was hoping they will change it to 4wd cause it aint really a monster if its not 4wd 2wd its just a truck with big wheels 🙂
December 3, 2004 at 4:19 am #24191
priest, you can hack the gpm alloy front servo case and mount it in with the rest of the plastic front servo case. this stops the front pillow ball mounts from cracking….that happens after you get an alloy front damper mount. and trust me, if you get the iw04, you will get the alloy damper mount a week later….
December 6, 2004 at 12:50 am #24081
hehehe ph2t ive already ordered them 🙂
