Jamie FETs
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Jamie FETs
- This topic has 13 replies, 6 voices, and was last updated 22 years, 6 months ago by
GT-ahh.
August 7, 2003 at 2:25 pm #11221
Hey Jamie
Dont suppose you know how to solder FETs to the mini z ?
Let me know mate
August 7, 2003 at 3:45 pm #21686
if you need help on how to solder them i know a site with some good tips and pics of how to so just pm me and let me know
August 7, 2003 at 7:07 pm #21696
I am not sure, as i havent got mine yet, but i think its pretty simple. Ill do mine and see how i go then give you a hand with urs.
August 8, 2003 at 4:51 pm #21743
*nods* It’s not hard, just fiddly 😉
I’ve got 40 FETs sitting in a tube in front of me right now 😉
August 8, 2003 at 6:25 pm #21751
Feeling Generous?? j/k ive got a pack of 12 coming today hopefully.
August 8, 2003 at 6:40 pm #21758
there easy
August 9, 2003 at 5:15 pm #21820
haha
August 9, 2003 at 6:28 pm #21822
ok when u guys install the fets
first take the batteries out… 1 killed 2 fets cause i was too laszy to take the batteries out…after full throttle for half a second then touch the fets to ur bottom lip..if u burn urself, theyre not installed correctly..check the solderjoins…
then gradually throttle for longer periods of time till ur sure theyre good… -
August 19, 2003 at 6:57 pm #21458
I got mine right first go 🙂 I found that if you glue them in a stack, then place a zip tie around them, it makes soldering easier.
An idea for a simple heatsink…use a piece of solder wick, soaked in solder, and solder it onto the 3 common outputs. Makes the job easier.Remove the big block thing on the pcb (the black thingo) and solder on the stacks.
Be careful desoldering the chips, i managed to lose 2 pcb pads and man it was a headache, i had to retrace the Tracks on the pcb and solder flying wires.
August 19, 2003 at 8:46 pm #21099
yeah i lost a track on my pcb too…
make sure u test the fets by touching them to ur lip..if they burn you, they havent been soldered correctly… -
August 19, 2003 at 9:37 pm #21100
so jamie have you got your mini z with FETs flying now? If so you reckon you can do mine and jarratts sometime soon? Let me know when your ready.
August 20, 2003 at 5:46 pm #20594
Now That I know what to do, all the tricks and stuff to get it right, i rekon i could give it a shot Josh. My car ain’t flying cause the servo gear is broken again and I don’t have my plasma dash motor yet.
GT, i didnt have any problems with the stack getting hot, i just checked all the connections with a Multimeter and its all sweet.
August 21, 2003 at 1:05 am #20647
just pm your address jamie
August 21, 2003 at 4:22 pm #20680
Barrelll, check ur PM’s
