kit racing
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › kit racing
- This topic has 7 replies, 2 voices, and was last updated 23 years, 6 months ago by
January 5, 2003 at 1:29 pm #9553
i just bought me the mph version of this for 1.98 at target. how do i make these gears line up to run smooth. i cut them to fit but the gear from the motor to the next gear dont line up properly. can someone help. thanks in advance
January 5, 2003 at 1:37 pm #17468
1.98?(US) at Target.. I have got to get down to the states more often. Are you trying this on a bit (or micorsizer) or are you just trying to get the kit gears/motor to mesh? I have the Energi, but have not had a chance to swap parts with a bit/microsizer.
January 5, 2003 at 1:41 pm #17469
im trying it on a microsizer and im just trying to get the gears to mesh properly.
January 5, 2003 at 5:52 pm #17472
CRX,
Have you got the white pinion gear from your KIT racer attached to your motor? Chances are you do. This gear only works with the KIT racer gears, not the bit gears. If you putthe black gear on from your Microsizer motor you will find that it will mesh properly.
January 6, 2003 at 1:34 am #17476
thanks for the info brett. But this is what i actually want to do. im trying to put in the 2.6 motor into the microsizer with the green gears that came with the kit. i have put the white gear on the 2.6 with the green gears all on the microsizer. the car runs and everything but it has horrible mesh. Ive noticed if i take off the heat sink and push the motor down harder, i receive greater gear mesh then before. Is there a way to keep it like this, or am i better off just using regular microsizer gears. Thanks Jon
January 9, 2003 at 10:22 am #17762
hey do the kit racer motors work in compact char-g? and how fast are they in a compact char-g if they do? also are the rear axels useable in a compact?
January 9, 2003 at 12:36 pm #17772
Bit Racer=KIT racer thats where your 3.0 motor has come from so its exactly the same rating as it would be in a BCG.
the KIT racer gears dont work aswell with a BCG becos of the weight of the BCG and lack of torque the motor can deliver, if you really want to use the KIT gears then i suggest using a dual Cell Car or soemthing with ALOT of power
January 10, 2003 at 1:53 am #17792
so your saing they come with 3.0?
