Lights, Camera, no action
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Lights, Camera, no action
- This topic has 6 replies, 3 voices, and was last updated 23 years, 10 months ago by
PandaBear.
October 29, 2002 at 12:46 pm #9425
I just did my first light mod. Just the head-lights for now and I seem to not be able to find lamps that do the trick. They either burn out quick or they the 3V battery (tried two types) doesn’t put out enough juice.. I have tried two different types of halogen lights both rated for 3V and am just using some cheap wire (which may be some of the problem- it seems to run a current but is not copper). I was wondering who has had success with do it yourself light jobs, and what components you are using, rating etc… I do have some soldering skill and can read a wiring diagram. Help…
October 29, 2002 at 1:02 pm #16329
The best ones i’ve seen use white LEDs powered by a lithium CR2016 or 2032 cell.
October 29, 2002 at 1:05 pm #16330
maybe your doing it in series? the lights should be set up in parrallel to give both lights enough juice. u might already know that so dont bite my head off…
October 30, 2002 at 1:53 am #16338
Don’t Use Halogen! Those things take way to much current. You’re batteries won’t last very long. Gomisan is right, use white LED’s. You can pick some up at Radio Shack. They also have blue ones. You’ll have to read the back of the package because they come in different voltages but the blue and white ones are usually around 3V so hook them up in parellel with a lithium battery and you’ll be lighting the way for a long time. If you get red or another color LED they will be lower voltage so you’ll need a stepdown resister in series with the led. If you mail me the specs of the LED’s you’re going to use (voltage and current draw) and what battery you’re going to use I’ll tell you what resistor you need or if you even need one.
-Peter
October 30, 2002 at 8:24 am #16354
Thanks all. Peter I will try to pick up some white/blue LED’s this weekend and if I can find some red ones at the Shack I will let you know my setup for the resistor.
Cheers.
October 30, 2002 at 8:26 am #16355
Oh yeah, what about the wire for the circuit? should I worry what I use?? copper/other??
thanks…
October 30, 2002 at 10:06 am #16359
Well – Silver has the best technical conductivity, but most wires you’ll find are copper.
