looking to buy carbon fibre sheet locally (melb)
Home › Forums › General Chat › looking to buy carbon fibre sheet locally (melb)
- This topic has 21 replies, 8 voices, and was last updated 17 years, 1 month ago by
November 10, 2006 at 8:04 am #9627
g’day, i’ve never looked into buying pre made cf sheets before and yellow pages didn’t help much.
basically, i’m looking for pre-fab cf sheets like 2 – 3mm thick to make replacement parts for an rc car. so i’m not after a large quantity.
it would be great if i could buy it locally at a retail outlet, hardware shops don’t stock it.
but failing that if anyone knows of a good online outlet i’m all ears (erm, eyes?)any help is much apreciated, even the name of the type of shop i should be searching for would be great! :8ball:
November 10, 2006 at 2:45 pm #25415
I can’t help directly, but I did see a rally driver making his own side mirrors from CF sheets and adding the resin.
I don’t know if they’d help you find a source, but contact MRT Rally, I think at, http://www.mrtrally.com.au and see if Brett Middleton or someone can help you.
Alternatively look for someone in motorsport closer to you.Good luck!
Graham. -
November 11, 2006 at 8:45 am #25325
Try rc plane shops. Dunno about ‘sheets’, but Rojs Hobbies in Fairfield has ‘strips’ about 10-20mm wide. I’ve used them to fix my MA-010 chassis.
November 13, 2006 at 11:44 am #25319
10-15yrs ago we could get small panels of CF boards from the aviation service/repair industry, for which Vic was a pretty big player. But these days that industry has died, all gone offshore.
Your best bet for retail quantities is Fibrelyte in UK; they can supply sheets or if you’ve CAD’d a design they can cut it for you too. Either way its not cheap, but given the health hazards with CF dust – I’d prefer to pay with $$, not your lungs.
For other stuff, I’ve been doing my fabrication out of PCB fibreglass.
November 14, 2006 at 12:00 pm #25317
betty.k,
I’m assuming you’d know about this anyway, but here we go…
CF is probably not the answer for toughening up basher vehicles, as it is so stiff and brittle it will quite easily shatter/break on impact. Soft nylon/FRP is the most durable material as it flexes to absorb shock.
However if you are building a race vehicle, CF’s rigidity will help handling and take a bit of weight off…if you are a good driver.
If not, nothing looks sexier than a chassis decked out with CF and anodized alloy :beer: .
November 15, 2006 at 7:18 am #25304
the reason i chose cf is because i will be able to work with it using the tools i already have.
aluminium is a more affordable choice but i find it clogs up files and grinding wheels.
i thought of using blank pcb but for a full chassis i don’t think it will be strong enough.i chose a bad time to hunt for cf too, from what i can gather there appears to be a worlwide shortage of the stuff (i blame them scientists and their carbon nanotube junk!)
the parts i’m replacing are fibreglass reinforced plastic, if i can get hold of that i think it will be my choice.
i should have mentioned it sooner but if anyone can get me a chassis for a hpi rs4 rally/sport then please lemme know!!:D :8ball:
November 15, 2006 at 12:17 pm #25236
PCBs can be sandwich glued together with epoxy to double their thickness, usually plenty strong if you avoid the pre-drilled veroboard stuff.
CF is a bugger to cut & file. Your drills and files go blunt extremely quickly, even high speed steel and diamond files aren’t much tougher. Plus I also try to file/cut under water to avoid wearing big chunky repiratory masks.
November 15, 2006 at 12:46 pm #25237betty.k wrote:i should have mentioned it sooner but if anyone can get me a chassis for a hpi rs4 rally/sport then please lemme know!!:D :8ball:
Should be similar to chassis for original RS4 Sport & RS4 Pro… but all discontinued now.Wonder if you can take the HPI Sprint’s chassis and recut the holes to suit.
It looks wider and fatter than RS4’s design so should be enough fat there.
Not sure how much of the Sprint’s mechanicals are recycled from RS4
but the overall layout is pretty identical. -
November 15, 2006 at 7:50 pm #25232
that’s another option i’m considering, buying some other hpi chassis and modifying it.
do you think the nitro chassis’ are the same size as the rs4 electrics? :8ball: -
November 16, 2006 at 4:31 am #25231
http://www.boyztoys.ie/index.php?subj=itemdetails&id=1021
Found this one on the net. Hope it helps.
November 16, 2006 at 6:36 am #25230
Just a thought.
Bunnings sell fibreglass cloth and resing etc.
I’m sure you could make sheets with it.
I like it because it looks juuuusssst like CF except it’s white. Very sexy.
I’ve used PCB for making brackets and parts, very easy to work with if you have a scrollsaw.
November 16, 2006 at 12:30 pm #25225betty.k wrote:that’s another option i’m considering, buying some other hpi chassis and modifying it.
If you’re talking about the 1st generation HPI RS4s, yes they are identical!Both EP and GP RS4s from that era (which I think the Rally is based on)
use pretty much the same gearboxes front and rear, suspension identical.Very surprisingly Tower still has the nitro chassis…
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXM750&P=7
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXM758&P=7I searched last night but they don’t list any more RS4 Pro or Sport plates.
Aluminium definitely more forgiving for Rally use, better than FRP.
The silver stock one could be better for modifying as it uses panhead screws.
The purple option chassis (used on RS4 Racer) is thicker & countersunk
so would be more work to do screw holes.I still have my RS4 Sport, Nitro RS4 & Nitro RS4 Racer here… np’s if you
want to take a lookie to check the differences – over xmas period maybe? -
November 16, 2006 at 12:38 pm #25211
Leon’s got the right bit, HPI “A230” is the exact part number.
I just walked over to the shelf and picked up the RS4 Sport… yep same part!
Unfortunately I’ve also found this thread… which confirms HPI has run out of stocks and not making any more, but thread poster seems to have commissioned a run of aftermarket units.
http://www.rcuniverse.com/forum/m_4374163/anchors_4374163/mpage_1/key_/anchor/tm.htm#4374163
November 17, 2006 at 3:30 am #25206
Yea, that website was the only one i can find that still stock that part. But like Panda said, Aluminium would be better suited to rally use. Get the nitro chassis and mod it. 🙂
November 17, 2006 at 8:13 am #25203
i knew i could count on you guys!:topstuff:
well spotted leon, i’m waiting for them to reply to my email.
cheers panda, the countersunk purple chassis sounds good, just curious as to whether it has rolled edges? looks like it does. what about the stock one? rolled edges? i just worry that they may get in the way of the battery.
i’ll email that bloke on rcu if all else fails.
so after all that, no matter what i end up with (actually managed to repair the main chassis, lexan + superglue!;) ) i’d still like to make my own.
as that bloke on rcu said the weak point is where the steering shafts screw in (see attached pic). i think i can make one stronger by eliminating the big cutout between the 2 holes.
then again i could try to avoid hitting walls at full speed a little better!:D :8ball:
November 17, 2006 at 11:52 am #25200
If you’re still after CF, I ran into someone on another forum that might be able to help you out.
http://www.sydneycruising.com/1/forum/index.php?showtopic=4361&st=10&#entry101249
“Custom Carbon Pty Ltd -Specialists in Carbon Fibre Motor Sport Components, 81 Basalt st Geebung 07 38652014”
He made his own CF bonnet for a Nissan Skyline. Very nice.
HTH, Graham.
November 18, 2006 at 1:29 pm #25198betty.k wrote:cheers panda, the countersunk purple chassis sounds good, just curious as to whether it has rolled edges? looks like it does. what about the stock one? rolled edges? i just worry that they may get in the way of the battery.
yes the nitros have a bit of a folded-up edge below the engine, you can see it in the Tower pix.But nuttin’ a big vice + hammer can’t fix 😉 especially with the thinner stock plate. Gets warped regularly from running anyway, needs a bit of panel bashing occasionally.
Wouldn’t even bother making cutouts, just leave the thing whole – it don’t help cooling anyways. And give a bit more meat around the outer holes.
Can buy sheets of aircraft-grade aluminium quite easily, easy to cut with a nibbler or jigsaw. Maybe even the chequer-board stuff…
January 2, 2007 at 11:12 pm #59835
http://www.geelongorthotics.com.au/news.htm
cf sheet in different thicknesses is used a fair bit in orthotic manufacture. i used to work as a secretary for my mum who was a podiatrist and used to think the cf sheet could come in handy. we stopped making orthotics from scratch when a company in melbourne started to produce them in bulk custom orders. we only did minor alterations and repairs after then so the mats for manufacture just didnt get ordered. cf sheet became available after we stopped production so i dont know much about it.
these guys are in geelong, but almost any podiatrist would have the same catalogue with the cf sheet available for order. its for medical purposes so it might be a little pricey, but youll probably be getting some very nice matirials though.
October 9, 2008 at 4:41 am #62159
October 26, 2008 at 9:31 am #62170
atkol gay video u s navy videos
fucking girl porn large tit videos free
free syreaming sex videos flash video end of the world
round mound video free sweet adri video
hiltons paris sex video block porn sites
serial number easy video converter 7.2.7 soviet olympic photos
cartoon male porn goal keepers are crazy video
video news nak amateur steel boat free planszip line videos video of a cartwheel
pregnant squirting nipple video peris speedway sprint car video
hot naked free porn 1984 from thriller video
smallest penis in the world video aircrft video
model porn star olympic view drive lynnwood road widening
first time bondage video real amateur wife swap al
lsu women’s basketball 2006 video lahar video indonesia
sybian videos bbw hilga sven video clips
porn tube big black boobs palm beach porn
singaapore porn blue man video who
catholic girl sex videos video produzioni
game video wholesale wholesale karen and sarah josephson olympics
franklin video rockford speedway video files ipod free buy two in one hole porn homemade video tapes , stream online video cp cam video web server , wet cunt video amateur free movie porn video , funny video download wma free dirty adult porn , free posting video montezuma revenge video game , tie a windsor knot video gay ebony creampie video , kfc video of chicken band california dani in video , free ebony squirter video ariel dion porn , milf sinsation videos video auditons , amature girls sex video brunettes videos , bizarror porn you porn no , clevland steamer video video from ipod to xbox 360 , i survived video porn tied in ropes , the first video game timeline pleasuring yourself video , free interracial milf porn absolutely free full length movie porn , sexy long video clips porn star huge penis , small porn penis charlie farren video , moonlighting taming of the shrew video crazy fight street video , teen and forum and video llamaweb videos , teacher and student hardcore porn ghetto gaggers zshare videos capture download software video crossroads cafe video series tpes
October 26, 2008 at 9:32 am #62161
people hardcore porn crazy weird sexy video
homemade amateur anal movies free porn videos of straight boys
wieson video card liana porn videos
days of thunder video video keno strategies
porn free thumbnail boys hidden cam video masturbating
interracial porn big black dick lasd academy video
youtube leonard cohen suzanne video clip ulead video srudio
nuclear weapons test videos mature porn large womenlusitania vintage video clip mature older women free videos
video scott v harris free adult anime sex videos
anime porn sluts sadomasochisme video
ulead videostudio 12 video tutorial training macbook nokia 95 video transfer
porn image cleaner autocad instructional video
free large porn vids porn star karma rosenberg
ulead video codec porn happy ending
efa porn taylor bow mpegs porn
video game designer job description salary aunt judy’s amateur
kneehigh park video hp sff video card dc5100
pug bowling funny videos free ccna video podcast
picture of pci express video card free teen hardcore sex videos
south indian sex video actress 1943 porn video wasp code video mood enhancing dvd , video games arcades in miami getto porn , amatrice video discounted porn dvd sale , aviation news videos previous user hypnotic slow motion video fireplace , asian lesbian porn finder nubile teens videos , hours of free sex video’s fitness video channel , remove drm from itunes video download high quality 3gp video , straight guys in gay porn ncis video bloopers , booty video porn download streaming video xtube , baby bash obsession video armed car video , the darkness video game free download video game sales stats , gravel pit wu tang video ransoms audio and video , clay school porn asian slump cum then shits video , record skype video phone mother daighter porn , tom jerry videos at target walmart olympic stain canada , free teen hardcore porn picture thumbs juliet anderson porn star , hotwives porn altered states psychology presentation video , 3-d cartoo porn no sleep till brooklyn video , video long legs mini dress metallica video clip download , female bodybuilders fucking porn blue ringed octopus video free sex videos web sites ex real doll fucking videos
October 26, 2008 at 9:33 am #62162
see saddam hussein hanging video lesbian older younger orgy video
fuck hard her porn nvidia video driver documentation functions
video pictures women nude 07 nhl video
tenchi muyo hentai porn reality kings 10 minute porn
shocking video sex eyeball video session control
kim kardashin online work out video ncaa basketball tournament video
vintage stock uses videos tulsa cash video
hot new porn stars wrestlmania 21 videosbeach hunter sex video fred lilly porn
indian porn girls thumb nails animalsex porn stories
welsh amateur boxing champions chicago amateur athlete
malissa midwest videos buck wild video chicks
elect the dead music videos daisy duck disney porn
pr rbd video redhead porn galleries
forming die video free nurse videos
ministryofsound stupid disco video wrestling moves video clips
web cam chat porn sex first solo time video
nude metro women video access patterns for pc video game
wholesome lesbian porn mariah shane video
siren porn clips porn viedos free
deal digital dish network recorder video changing room sex porn hosted 2000 winter olympics hientai anime porn , free xxx redheadsex video 7 pin s video to 3 , tracey lords videos alanna amateur , 2nite shaggy video wild mitsubushi ws-65315 video card , olympic games sports played free porn ups guy at work , intercourse photo video free internet porn photos , polish home videos kim kardashian with ray j video , wild free fuck videos burn video cd using alcohol 120 , young porn nudist pentagone video , carey free mary porn plaboy the mansion video game , crazy video activation code and email video teen blowjobs , for porn mp3 black manta video , oline porn no sign up beijing art show , hypnotize porn vulnerable music video by secondhand serenade , video xxx gratuit alt amateur pics , uber porn amercian tap syllabus video tape , fantasy catfights video video couples erotic , indio video converter yahoo video results tagged as cosplay , ametuer houswives nude video 3d printers video , luba video hot video game invite big girls dont cry video fergie forced sex videos rent per minute
- The topic ‘looking to buy carbon fibre sheet locally (melb)’ is closed to new replies.
