LWB Hummer Report……
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › LWB Hummer Report……
- This topic has 11 replies, 9 voices, and was last updated 22 years, 3 months ago by
GT-ahh.
March 14, 2003 at 8:32 am #10146
Got my LWB Hummer in yesterday. Shweeeet! Made by Bensu, Again “Shweeeet”. Came with a blue cap motor but it’s definatley not a 1.0, runs like a strong 2.8 or 3.0. Pinion is 11 toothed so torque is not it’s fortay but the motor has enough torque to get it movin pretty good. The chassis is “stretched” which makes this rig the “perfect” candidate for a dual/triple battery mod. (longer than a ZZ) Dual will fit with NO chassis mod, triple with lil modding. Steering is good and responsive, range is excellent (25ft), body is outstanding, very detailed though paint leaves a lil to be desired. The only bad thing I have to say about it is the wheels & tires. Tires are hardly ever great on clones but I knew that so I got Bit Charg-A tire with the order. These are “great” soft tires. Now the wheels are horrible, decent looking but wobbly and off center which throws the axle gear off too. Vibrates like crazy so the rig may get a set of German Alloys or at least a MS Full Wheel Mod along with a tripple Batt Mod.
http://www.toyeast.com/proddetail2.asp?pdtid=AC1293
LWB Hummer – $6.75
Soft Bit Tires – $2.25Not a bad deal!
DarkTari
DarkTari
If It Won’t Fly……Modify -
March 14, 2003 at 1:13 pm #37315
The wheelbase is longer, eh? I wonder if some slot car bodies would fit it then – normally they don’t fit well on BCGs because the wheelbase is shorter. Maybe hotwheels or matchbox cars could be used to vacuum form new shells too. hmmm…
DaveF! 👿
March 14, 2003 at 5:37 pm #37324
i highly doubt 1:64 shells will fit..they have a tendancy to be to shallow. Because bit char-Gs are super-chibi ^_^ you need a bubbly sorta shell…
March 15, 2003 at 8:04 pm #37207
super chibi! is that the word for it! i wonder how much bit charg oz will sell them for?
March 15, 2003 at 8:36 pm #37209
Chibi??
June 3, 2003 at 1:49 am #28443
i got one of these lwb hummers.
it fits exactly on a die cast body i got but….. the actual car is s@#t its slow even with the original body on it and it doesnt turn that well. i could do a dual cell modd and new motor that could improve speed but the handling will still be bad.
so i was thinking maybe i could swap chips maybe using a lxx booster one. would i have to replace the steering wires aswell to fix the handling or will a better chip improve the steering reguardless?
June 3, 2003 at 8:18 pm #28370
every times i see one of those things i think “full wheel mod, lowered body, putty body kit, and under glows….” well im fresh outta skillz.. so who wants to make that dream of mine come tru??
June 3, 2003 at 9:55 pm #28374
does anyone know if i swap the pcb’s on the hummer with another bit say an original bit or a Lxx bit would it improve the handling of the thing???
June 4, 2003 at 2:02 am #28380
Talldude, prolly not. The bad steering is to do with the actual phyical steering mechanism. Try pulling the front assembly apart and re-seating the coils and/or magnet. A lot of clones come with one coil NOT sitting flat which will cause bad steering no matter what the little trimmer on the underside is set to. Also as time goes by the magnet can become loose, try re-seating this with a touch of glue to keep it there.
June 4, 2003 at 4:05 am #28384
thanks ph2t
yeah one side was not sitting flat up so dat was effecting the steering.
but the car needs more power and the gears are too high because when u put it forward then reverse its lacking torque. i think a dual cell would fix that problem and maybe some new gears……
damn i should really stop spending all my money on these things
my family already thinks i got a problem with these things
June 8, 2003 at 5:54 pm #28095Quote:i got one of these lwb hummers.
I don’t hear great things about Lxx PCB’s, as a matter of fact I wouldn’t suggest using an Lxx booster PCB.
June 8, 2003 at 7:02 pm #28097
they are selling at trading direct for under $15, so now would be a good time to by one
