LXX is dead … long live iWaver!
Viewing 6 reply threads
    • #10312
      Kerosene
      I tried to install a Woah Nelly in my old LXX clone (pre iWaver).. but I screwed up the fet pads and it’s now dead in the spare parts box. Luckily I had a brand new iWaver tucked away… somehow everything went ok the second time around – and I’m now the proud owner of a stinking hot iWaver.
      This thing rips it up. Thanks Ph2t!
      It doesn’t look quite so tidy anymore though 👿
      iWaver
      Woah Nelly 1.1
      Plasma Dash (stock)
      12t pinion
    • #24309
      z-beam
      love the stealth look!
      all you need now is some holes in the front bonnet with some aluminium mesh…
    • #24302
      bithed
      …mesh the windows too…get some plastic garden netting and put THAT in your windows…looks HARD and STILL performs 🙂 and black rims brah…THATS what its all about…black rims…im loving it !!
      …i second the mesh in the hood…black of course 😉
    • #24298
      jamiekulhanek
      It’s most likely not dead, I have fixed this problem of destroyed/broken pads lots of times.
      All you have to do is trace back from the FET pads to somewhere you can solder a wire (thru PCB pin etc, and solder the wire to the FET stack….easy!
    • #24297
      Kerosene
      I’ve kept all the dead LXX bits together in the hope that one day I can save it. I sorta tried to trace where the busted pads went to.. but it was easier to just put the whole thing away and forget about it.
      Maybe if I can ever be bothered to get some new fets for it I’ll fix it.
      Yeah BLACK RIMS!
      It needs some “speed holes” next.
    • #24296
      betty.k
      holes and mesh is good:smiley2::8ball:
    • #23927
      z-beam
      the mesh! we wants it! we want to see it!!!
