Main difference Between Bit and Compact
Viewing 4 reply threads
    • #11749
      I was just wondering what the main differences are between a Bit Char-G and a Compact Char-G before i go and buy one. Thanx
    • #46327
      ms char-ged
      nothing, except the name, and the different frequencies, there are also different cars, that are not available in compact char-gs, but only in bits, and there are accesories, such as different bodies, engines, chicanes, pylons, etc……, that you will only find in the bit char-g range
    • #46328
      oic…so will there be replaceable bodies, engines etc for the compact range in the near future?
    • #46329
      barto_85
      Im not sure if there will be compact bodies in the near future, but the bit char g bodies can be bought and do fit the compact char g s anyway. Same with the motors, tires, suspension etc.
    • #46333
      micro_Amps
      Quote:
      main differences are between a Bit Char-G and a Compact Char-G ??
      In short…..the box! Its the same product.
      Same with the Hobico Microsizers.
      So if you see any refferences to these, consider them all the same thing. All the accessories and hop ups are compatible accross the 3 of them.
      :)uA
