Mini Cooper M03 Shell Painting
Home › Forums › 1/8, 1/10, 1/12, 1/18 – Discussion › Mini Cooper M03 Shell Painting
- This topic has 113 replies, 10 voices, and was last updated 21 years ago by
merc-blue.
February 21, 2005 at 5:04 pm #12562
I ve built my m03, now I m up to painting the mini cooper shell. But am lost when it comes to masking and painting.
The roof needs to be painted white, the wheel guards and sideskirts black, the front grill silver and the rest of the body blue.
Which area should I paint first. The roof ?, then mask it all off, do the wheel guards/sideskirts and front grille with a brush, then spray the inside with blue ? Will the blue show up behind the silver ?
Any help appreciated.
February 21, 2005 at 7:57 pm #58614
Paint darker colours first, white comes last.
Silver is usually pretty opaque, but pretty hard to paint with a brush (brush marks show up). PS12 Tamiya spray is the best coverage.
February 21, 2005 at 8:38 pm #58615Quote:Paint darker colours first, white comes last.
Okay, I have tamiya mask the one that looks like sticky tape, but for large surfaces what do I need to buy from the hobby shop to mask it off ?
February 21, 2005 at 9:37 pm #58618
but if your using a brush for the fenders with black paint how many coats do you need to apply so that when you spray later on with a spray can it dont show up and through the black? is it 3 or 4?
im trying to work out how to do the roof aswell kev let us know what you get to cover up that thing.
February 21, 2005 at 10:08 pm #58619
You can use any masking tape.
Scotch/3M makes some good ones; the best is Tamiya’s own yellow masking tape or the Scotch/3M blue one (car paintshops use it). Good tape gives clean lines!
You can buy cheaper tape (beige stuff) to fill in the rest, after you line the edges with the expensive stuff.
February 21, 2005 at 11:03 pm #58621
or tape a peice of paper or plastic over the larger areas.
my 1:10 bodies only got 2 coats of paint and that’s all they needed. like pb said, dark colour first.:8ball: -
February 22, 2005 at 12:00 am #58622
Thanks for the help guys. This is what I’ll plan to do hopefully it won’t be too much work.
1. Mask off body portion next to wheel guards and side skirts.
2. Paint wheel guards and side skirts with black pc paint, several coats with brush.
3. Mask off body portion of front grill.
4. Paint front grill with silver/chrome pc paint, several coats with brush.
5. Remove Masking in points 1 & 3.
6. Mask off front grill, all windows, and Roof.
7. Paint body with blue pc paint spray can.
8. Remove roof mask.
9. Mask body around roof.
10. Paint roof with white paint.
11. Remove all masking.I envy those people that can do those fancy air brush designs…
February 22, 2005 at 1:57 am #58623
me too!:smiley2:
i’m no expert but here’s what i would do:
1. mask everything first, leaving the “blue” section clear. paint it blue. you can go a bit thick and messy as the outer side won’t show all those surface blemishes like “orange peel” and drips.
2. remove the roof mask and paint the whole thing white (so all the blue is covered.
3. remove the wheel mask and do your black guards. (try to stay on the guards, no need to go everywhere)
4. remove the grille mask and paint silver (again, just the grille.)
5. remove the window mask and bash it til it dies!:D
the most important part is the white layer. it should stop any of the black silver showing through to the outside. do 2 white coats if you wanna be sure.:8ball:
Edited by – betty.k on 21 February 2005 21:00:26
February 22, 2005 at 2:08 am #58624
or you can buy a tamiya decal sheet with the union jack for the roof :smiley2:
i like the look of the union jack so ill get it, but ill paint the roof white anyway knowing my driving skills(or lack of) it will come off lol
February 22, 2005 at 3:35 am #58625
i would do alot more than 2 coats.. i tend to do about 10 thin coats it gives u a arsome covering and solid flawless colour
February 22, 2005 at 4:09 pm #58631Quote:me too!:smiley2:
You’re a legend.
That’s sounds bloody good to me.
I’m off to the hobby shop to buy some spray paint.
February 22, 2005 at 4:21 pm #58632
ok…i did my first tamiya mini body this way, first hand painted the black guards, tape the roof(this can be tricky due to how it is molded)or you can do it first, you DONT HAVE TO PAINT DARK TO LIGHT EVERY TIME!!!!!! then do your main colour then the roof, or what ever way you feel easiest doing it. 4 or 5 light coats will do for any colour. hope this helps????? prob confused you even more
:D:) hope to see it next sunday.BIG DAVE
February 27, 2005 at 12:22 am #58704
just a bit of advice needed for me guys.
if i put a thin layer of silver down then paint over it with blue would the blue come out through the silver?
February 27, 2005 at 12:44 am #58705
yes it probly would
February 27, 2005 at 4:29 am #58706Quote:just a bit of advice needed for me guys.
I’m doing what betty and mini-g said. I’ve masked the windows, roof, front grill and sides of the wheel arches/side skirts. This took me about 4 hours to do with tape and hobby knife.
I’ve hand painted the wheel arches/side skirts black, several coats so that brush marks don’t show.
If I get time tommorow, I’m going to spray a few coats of blue. remove the masking on the front grill and hit the front with silver, then finally remove the masking tape from the roof and hit the whole shell with several coats of white.
February 27, 2005 at 4:52 am #58707
yeah thats the way.. once ur all done.. i would suggest leaving the window masks on and doing a thick coat (via many thin coats) of white to protect ur paint from wheel rubbing or internal scraches
February 28, 2005 at 6:59 am #58718Quote:…thick coat (via many thin coats) of white to protect ur paint from wheel rubbing or internal scraches
use tape – gaffer tape, PVC tape, electrical tape…
No paint is immune to friction. 👿
February 28, 2005 at 3:30 pm #58719
yeah but it helps.. the other trick i have picked up is do teh top of your wheel wells with some ofcuts of polycarb and some shoo goo which would help strengthen them.. and any were where a body shell normally cracks
March 8, 2005 at 3:43 am #58810
Hey, here’s an update… my first lexan paint job… woo hoo.
Thanks for all the advice and help !
Now for the stickers….
March 8, 2005 at 11:46 am #58811
that is very nice man!
too bad you will race it. :smiley2:
March 8, 2005 at 1:01 pm #58812
good work! that turned out just as you said it would. and that aint easy!:smiley2::8ball:
March 8, 2005 at 5:52 pm #58814
sweet looking mini..
March 8, 2005 at 6:14 pm #58815
Good Job,
Like mini-g said, cant wait to see the thing in action down the park :):):smiley2: -
March 8, 2005 at 9:28 pm #58817
i think he will keep that 1 as a shelf item wouldnt you?
ill show you guys what a real mini suppose to look like on sunday all beat up and lots of dings in it! lol
March 8, 2005 at 11:54 pm #58820
Yeah, after all the time spent on it, I think it might be a display shell. So far it’s taken:
1 hour cutting/dremel the lexan body
4 hours masking tape body prep.
4 hours painting over several days – bloody paint fumes.
? hours putting decals on…$35 worth of tamiya paint.
I’ll get a frewer mini body for racing – they don’t come with any decals, so I’ll just slap 2 different tones of paint on it and be done with it.
March 9, 2005 at 2:00 am #58821Quote:i think he will keep that 1 as a shelf item wouldnt you?
no!:D:8ball:
March 9, 2005 at 2:03 am #58823
frewer minis do come with decals..ii would STRoNGLY suggest one, the tamiyas dont last eg 1 race and its gone only reason u would run one is for TCS
March 9, 2005 at 1:05 pm #58826Quote:frewer minis do come with decals..ii would STRoNGLY suggest one, the tamiyas dont last eg 1 race and its gone only reason u would run one is for TCS
Thanks for that Merc. I called the aussie distributor down in adelaide and they said that it didn’t (perhaps it was the last one they had in stock). But I sure hope it does come with all the decals and window masking. They’re a hard item to find…
March 9, 2005 at 3:50 pm #58828
castle hill raceway has them in stock kev… just pop up on friday night and get one.
BIG DAVE
March 9, 2005 at 3:59 pm #58830
and they do have the decals in the bag, i’m certain i saw them in there… Kev; glad i’m only doing one colour, so i dont have 4 hours of masking to look forward to, but i did cut out my body last night (S15 Sylvia) and it took about an hour and a half or so, with the wings and such. Who knows how long the decals are going to take me, they’re not die-cut!! (not that i expected that…) I might have to start a “first time painting body” topic shortly…:smiley2: Coming along nicely though…:approve:
Edited by – dgs73 on 09 March 2005 10:59:53
March 9, 2005 at 5:42 pm #58835
so castle hill is a track and has a hobby store on site aswell aye?
my mini’s paint job is qik cheep and nasty but hey ive always been into racing my cars not presentation. thats my excuse for lack of skill and patients.
March 9, 2005 at 5:59 pm #58836Quote:castle hill raceway has them in stock kev… just pop up on friday night and get one.
BIG DAVE
Excellent. Also how much are they ? Kellets have them for $35.
9pm not too late to show up ? Wouldn’t mind checking out the racing as well.
Cheers.
:smiley16:
March 9, 2005 at 6:00 pm #58837
this is the case… only minor parts, ie. tyres, inserts, bodies, spur and pinion gears, afew other bits ‘n bobs… usually a few things for sale through the racers too, you’ll see fliers up from time to time… that’s how i got my TC3… with the type of work i’m in at least i should be able to do a half decent job on my painting without too much hassle…
March 9, 2005 at 6:02 pm #58838
Kev; if you want to race you’d have to be there by 6:30-7:00pm, would be good to see you guys there!!
March 9, 2005 at 6:30 pm #58843Quote:Kev; if you want to race you’d have to be there by 6:30-7:00pm, would be good to see you guys there!!
Damn… I don’t get home till around 8pm… then it’ll take me a good 40 minutes to drive up to castle hill from where I am.
Would’ve been good for a race though.
Talldude won the finals last Sunday…
March 9, 2005 at 7:31 pm #58845
sweet… good stuff TD!! Shame your not able to get ther earlier, but registration closes at 7ish… we’re usually there till about 12am or so… sometimes it runs longer, but not much. Bring a jumper if you’re coming, it can get cool out that way later in the evening…
Edited by – dgs73 on 09 March 2005 14:32:55
March 9, 2005 at 7:42 pm #58846Quote:Quote:castle hill raceway has them in stock kev… just pop up on friday night and get one.
BIG DAVE
Cheers.
:smiley16:
yeah 9pm will be fine, just in time for the finals. think the mini’s are $35 there too, no more than that. hopr to see you there.
March 10, 2005 at 10:20 pm #58866
this is my mini in action, the yellow is a good racing colour as it actually allows me to see the thing in action!
March 10, 2005 at 10:59 pm #58870
That’s very nice. Photo looks like you’re drifting around the corner.
*LOL* front body pin shows you were in a hurry to get some run time.
March 11, 2005 at 12:36 am #58874
lol
whoops ahh who cares it was still fun to drive it pitty i didnt get much of a runtime missed out on getting more time due to me rocking up late to free practice.
will perfect the mini next time i swear kev!
March 11, 2005 at 2:08 pm #58877
looking good TD… that’d be easy to see no matter how many people on the track!!
March 11, 2005 at 3:00 pm #58878
Looks like I’ve stuffed up applying the decals on my m03 shell, got air bubbles, rips and wrinkles… It’s quite hard applying the front headlights on without any wrinkles for some strange reason. There’s got to be a special technique of some sort. Do they need to be heated up slightly with a hair dryer first ?
Oh well, race shell now…
March 11, 2005 at 3:38 pm #58879Quote:Looks like I’ve stuffed up applying the decals on my m03 shell, got air bubbles, rips and wrinkles… It’s quite hard applying the front headlights on without any wrinkles for some strange reason. There’s got to be a special technique of some sort. Do they need to be heated up slightly with a hair dryer first ?
the hair drier does come in handy for this purpose, so yes.
March 11, 2005 at 5:54 pm #58880
you could buy some more decals?
if you race that shell in 5mins it will look like shit 🙁
March 11, 2005 at 7:47 pm #58882Quote:Looks like I’ve stuffed up applying the decals on my m03 shell, got air bubbles, rips and wrinkles… It’s quite hard applying the front headlights on without any wrinkles for some strange reason. There’s got to be a special technique of some sort. Do they need to be heated up slightly with a hair dryer first ?
try applying with a MILDLY soapy warm water (not much), and work from one edge to the other, squeezing out liquid as you go. The soapy water helps the thing from grabbing straight away, so if it’s not in the right place you have a chance to move it. It evaporates out fairly quickly, but you’ll obviously have to wait longer before it’ll be ready to use. Dont heat them; it’ll make the glue even grippier… the water meothod is what we use to apply vinyl signage to glass, acrylic and other annoying surfaces, and i found it carried over to this application quite well. But TD is right; no matter how good you apply your decals, one good nights racing will see alot of them damaged anyway…:dead:
March 11, 2005 at 8:43 pm #58886
hey dgs, that’s a killer tip. you should write up a little tute on decal application, i know you gots skillz in that area:smiley2::8ball:
Edited by – betty.k on 11 March 2005 15:48:27
March 13, 2005 at 12:32 am #58895
DGS, you’re a legend. Excellent tip ! Thanks for sharing.
You’ve just cut my decal applying time into half. Not only that, your methods do give time to adjust the decal to the right place before the glue kicks in.
:):DThe finished product…
March 14, 2005 at 2:00 pm #58899
glad it all worked out for you, it looks pretty damn good. Cant wait to help rub some off again…:smiley2::D. Glad you and betty found my tips useful…:)
March 14, 2005 at 3:57 pm #58902Quote:glad it all worked out for you, it looks pretty damn good. Cant wait to help rub some off again…:smiley2::D. Glad you and betty found my tips useful…:)
LOL, took it for a run on the street, hit a small tree branch and did four to five somersaults in the air before landing and sliding another 6 metres on the ground. It’s all scratched up and has a hole in the roof from impact.
Merc is absolutely right about these Tamiya shells, they’re very fragile ! Tamiya radials have turned to slicks…
Looks like I’ve got to get another shell soon…
Didn’t make it up to Castle hill on Friday night… Work colleague lent me 5 xbox games and I couldn’t control myself and had to play.
March 14, 2005 at 4:13 pm #58904
damn!
sorry to hear about the incident. my shell is not looking good no more but hey its for racing.
your right about those tires they arent that great.
March 14, 2005 at 5:31 pm #58907Quote:damn!
Yeah, I’m not fussed about it, don’t really have the space to put a lexan display shell, so basically just used it and had fun with it ! But it was good learning the ropes in how to paint/mask and decal them, so next time it should be easier.
Fitted the manta ray ball diff and hollow carbon gear shafts last night, you got to take half the car apart to do that ! Don’t think I want to adjust the ball diff now…
These cars are really fun…and very different to drive !
btw. I may not be going next week to Tempe racing due to royal easter show tickits that were bought for me…:evil: so you might want to charge up your own batts before race day.
March 14, 2005 at 6:55 pm #58912Quote:Quote:glad it all worked out for you, it looks pretty damn good. Cant wait to help rub some off again…:smiley2::D. Glad you and betty found my tips useful…:)
hey kev, you think slicks are bad!!!! mine has the foam coming through…..and after saying hello to a netball post the crack in my bod has become a hugh tear. got to love them though:D
March 15, 2005 at 2:09 pm #58928
lol those rears have more foam visible than rubber Dave!
March 15, 2005 at 4:20 pm #58931
and there was a guy racing his mini with tires like that the other week at the hill:shock:
March 15, 2005 at 4:24 pm #58932
yeah get HPI x patten tyres and HPI 5 spoke rims and a frewer racing shell .. i hvae only ever broke 1 frewer shell from driving it under a 1:1 car LOL.. and the xpattens kick ass..
March 15, 2005 at 4:54 pm #58933Quote:and there was a guy racing his mini with tires like that the other week at the hill:shock:
that explains alot… he was all over the place…
March 16, 2005 at 10:55 pm #58973
took my mini out for a run to wear down the batts (its been that long since i run them thatthey still had charge since 2 sundays ago!)
and all i got was smiles from people, everyone seems to love the mini!
big bonus is nothing is broken no rollovers but i did bold two tires.
bring on sunday, im ready for the track lol
March 17, 2005 at 1:58 pm #58983
yeah, i was thinking that double wide lanes using the Z track… should be perfect for the 1/10s… we’re talking 8 foot wide lanes here, with no doubt 4 cars… bring on Sunday!! And p**s off rain!!!
March 17, 2005 at 3:56 pm #58985
yeah rain dont look good might ruin my free weekend!
i like your track idea dave should be good.
March 17, 2005 at 5:14 pm #58994
mate with this scale we can successfully use the carpark at Meadowbank if it rains… i’ll do the sweeping…:smiley2: plus, the pillars will give us an extra challenge…:D keeping my eye on the weatherwatch site, and Sunday (at the moment) is looking like it migt be clearing… but we’ll see. Fingers crossed eh?
March 17, 2005 at 8:32 pm #58995
with this scale you would be better of going to Jasco if it rains…!:smiley2:
March 17, 2005 at 8:34 pm #58996
More space is all:)
March 17, 2005 at 8:41 pm #58997Quote:with this scale you would be better of going to Jasco if it rains…!:smiley2:
that’s where i was talking about…:D hopefully there wont be any need though…
March 18, 2005 at 5:39 pm #59016
looks like it’s clearing up over this way… amy it stay that way for Sunday… though i think i may have spoken too soon…:smiley2:
April 5, 2005 at 10:15 am #59182
Hi, just bought new wheels and a body for my M03 mini… but, will these new wheels fit on it?
Edited by – minioned on 05 April 2005 06:21:45
April 5, 2005 at 10:50 am #59183
yeah they will fit no problems.
April 5, 2005 at 11:43 am #59184
Thank god for that, Ive been trawlin google and because I noticed that the middle screw bit was different. I think these wheels look REALLY nice, if you want them, go on eBay, quite a few sets on there for cheap! Mine were less than ?10 for 4
Also… what tires would I need for them?
Edited by – minioned on 05 April 2005 07:44:44
April 5, 2005 at 6:14 pm #59188
…any interest in these if i can get them?
…I will start another thread if you need more…
April 5, 2005 at 7:58 pm #59189
hmmmmmmm
what other styles do you have acces to?
more interested in fewd bodies due to some clubs only allowing fwd bodies on ff cars.
April 5, 2005 at 8:16 pm #59190
…These are M-03 chassis bodies though..3rd party, made locally here..I have never seen them else where though…
April 5, 2005 at 10:13 pm #59191
I like them shells! How much for one (Subaru) to the UK :D?
April 5, 2005 at 10:38 pm #59192Quote:…These are M-03 chassis bodies though..3rd party, made locally here..I have never seen them else where though…
I was wondering why they were so squashed up, I guess its good to have something different…:smiley2:
I do like the Lancer:smiley2:
Edited by – peteWah on 05 April 2005 18:41:17
April 6, 2005 at 1:17 pm #59195
I remember seeing a body for this chassis of a Mini Estate, anybody know where I can get one? I saw one on eBay a while back
April 7, 2005 at 5:32 am #59206
Just been looking at the petrol tamiya mini… and the wheel bearings look different, will I have to get different wheel nuts to put the larger wheels on my electric one? Pic here: http://img154.exs.cx/my.php?loc=img154&image=582114pl.jpg
April 7, 2005 at 11:26 am #59207
minioned there are many different nitro minis.. the best is probly the HPI mini pro the eletric version i also very good.. remember guys there are alot of 1:12 shells around becasue xray and yokomo make 1:12 tourers..
finaly later today (probly in lunch break im gonna post my m03 build up/hop up guide -
April 7, 2005 at 11:27 am #59208
no the wheel nuts are the same…gust the wheels make them look different.
BIG DAVE
April 7, 2005 at 1:22 pm #59210
ok guys no pics yet but this is what the beast has
Hollow carbon Gear Shafts
TA03 Ball Diff
Hardened Ball Diff Outdrives
Tamiya Mini Universal drive shafts
Stainless Steel suspension hinge pins
Front Ti turnbuckles
Tamiya TRF shocks
alloy front uprights
rear toe in uprights
antiroll bar kit
alloy motor mount
and probly others i forgot :S
of the lot the parts i recomend mostly are
antiroll bars
unis
bearings (a given)
ball diff
trf shocks (or mini CVAs if ur cheap)
front aloy uprights
once u got that u got a good racer once u got more it just tweaks the car
but seriously anti roll bars are arwsome ina mini make it really easy to adjust suspention and help stop it rolling the alloy uprights wont bend like all the stock ones do the ball diff just well.. it make quite a difference in ur steering and same with unis .. (never have understeer again) the rear toe in will keep the “twitchy” car stable (the mo3L is extreamly stable with this) and the trf shocks cause there oh so smooth and easy to adjust
also running x pattern tyres (love em) and a cooper body (untill i can be bothered getting a bmw mini).. will edit and fix this up later with more indepth info -
April 7, 2005 at 1:25 pm #59211
so theyll DEFINANTELY fit yeh? Im really worried about them not fitting cos I love them!! I hacked the wheel arches off my old shell to see if I could make more room! Luckily Im getting a new one 😀
April 7, 2005 at 2:43 pm #59212
hey merc found this site for m04’s
http://rcontario.com/rcorevms2004.html
can i ask what the universal drive shafts do?
April 7, 2005 at 3:03 pm #59213
there bassicaly more efficent that the dogbones and also when ur steering is “full lock” they dont pinch like the dogbones do so it allows u to acctually use full lock.. also gotta trim ur EPA down with alloy uprights or u can tear up ur servo gears then u steer past the max the knuckle will allow
Edited by – merc-blue on 07 April 2005 11:46:16
April 7, 2005 at 3:25 pm #59214
dude i know this might sound bad but bloody hell improve your typing skills i can bearly understand what your trying to say!
as for hop ups i got basically all that you have except the universal drive shafts. the mini handles fine have yet to race it.
April 7, 2005 at 3:32 pm #59215Quote:dude i know this might sound bad but bloody hell improve your typing skills i can bearly understand what your trying to say!
yi man gt da unis day r pritty good. no cliking noises wen turning.
April 7, 2005 at 3:36 pm #59216Quote:Quote:dude i know this might sound bad but bloody hell improve your typing skills i can bearly understand what your trying to say!
ha ha kev :p
April 7, 2005 at 3:44 pm #59217
shit yeah that one was exceptionaly bad wasnt it.. i’ll edit it
April 7, 2005 at 3:48 pm #59218
thanks man now that makes sense.
i use a manta ray ball diff it seems okay. i got some hpi tires but have yet to run them.
April 7, 2005 at 9:44 pm #59220Quote:thanks man now that makes sense.
I use the manta ray ball diff as well, but don’t really like it that much as even when the thing is tightened up, the diff action is still fairly loose. but hey, better than the gear diff.
April 7, 2005 at 9:50 pm #59221
yeah i aint a great fan of it aswell…….
i wonder how the other type goes?
April 8, 2005 at 12:40 am #59223Quote:yeah i aint a great fan of it aswell…….
Yeah not sure if the ta03 ball diff is any better ? But I don’t think I’ll be getting the other one unless the existing one breaks.
I also got the shorten touring car springs, makes my m03 chassis sit with a 8mm ride height and finally the wheels don’t sit with positive camber.
April 8, 2005 at 1:43 am #59225
TA03 ball diff is good tighten it up and it may aswell be a spool..
April 8, 2005 at 2:49 am #59226Quote:TA03 ball diff is good tighten it up and it may aswell be a spool..
That’s odd. The ta03 ball diff looks very similar to the manta ray ball diff where both diffs use those metal cones to apply pressure to the diff plates.
I think I’ve tightened the manta ray ball diff as much as it will go, but don’t want to tighten it any further for fear of stripping something. Although it doesn’t slip now, there is still plenty of easy diff action – but too much for my liking.
April 8, 2005 at 11:15 am #59228
nah the ta03 uses plates and has a race bearing (not sure is mantaray does)
April 8, 2005 at 1:13 pm #59229
both diffs are the same except the ta-03 has a thinner plastic gear. i put an extra shim in mine to lock it up as much as possible.
BIG DAVE
April 8, 2005 at 2:46 pm #59231
ok.. well mini-g that depends cause there is a ta03 and a ta03R gear diff im runing the 03-r cause it lighter
April 8, 2005 at 4:12 pm #59233
yeah but the two ball diffs i am talking about are the same except the said gear. the 03 and 03r diffs are the same. just put an extra cone shim in the diff and do it up as tight as it will go. you feel a definate stop when the diff is fully tightened.
BIG DAVE
April 8, 2005 at 6:55 pm #59234Quote:yeah but the two ball diffs i am talking about are the same except the said gear. the 03 and 03r diffs are the same. just put an extra cone shim in the diff and do it up as tight as it will go. you feel a definate stop when the diff is fully tightened.
BIG DAVE
Okay thanks for the tip Big Dave. Is the extra cone shim available at the hobby store as a tamiya spare parts bag or a good hardware store ?
April 8, 2005 at 7:58 pm #59236
hmmmmm took my mini out for a spin today, notice it turns more tighter in one direction then the other!
might change my tires on sunday if i still get the same results looks like another rebuild of the diff!!!!!!!!!!!!!!!!!!!!!!
April 8, 2005 at 8:40 pm #59238Quote:hmmmmm took my mini out for a spin today, notice it turns more tighter in one direction then the other!
I don’t think its a diff problem. I think its more to do with the centering of the servo and the end point adjustments (epa) that you need to make on the 2pl controller.
April 8, 2005 at 8:59 pm #59240
ahhh cool show us how to do it man on sunday it would be cool :smiley2:
April 13, 2005 at 6:00 am #59269
Anyone know where I can get the spotlights that are on Tamiya Monte Carlo Minis in some pictures?
April 13, 2005 at 12:24 pm #59270
minioned if u can track down the tamiya monte carlo body/body parts set best bet is probly http://www.tamiyaclub.com but remember tamiya shells are WEAK and one crash and they look MESSED up
April 13, 2005 at 12:26 pm #59271
Are there any other shells made by other companies that will fit on the M03 chassis? I dont really race mine, just play wiv it in the park so crashing doesnt happen that often 😀
April 13, 2005 at 1:04 pm #59272
yes frewer make a direct replacment.
BIG DAVE
April 13, 2005 at 1:05 pm #59273
got a link to a pic of it and any idea of price 😀
April 13, 2005 at 2:01 pm #59274
miniowned the frewer is a basic mini shell doesnt have all the fancy bits the montecarlo has its just a plain very bassic min and the would be really cheap over therew say 15ish pounds
April 14, 2005 at 5:13 am #59284
Ok, I’ll have a look around 😀 Thankyou
April 21, 2005 at 11:15 am #59353
http://img224.echo.cx/my.php?image=dscf59832tc.jpg
Mines done 😀 😀 What you think???
April 21, 2005 at 12:52 pm #59354
thats hott..
great job.
PS. what wheels are they i picked up like 4 sets off a mate and hae NFI wat they are .. eg. brand? -
April 21, 2005 at 1:31 pm #59355
Theyre the standard Tamiya ones, they were black(reinforced) but I painted them white. Im quite happy with them, look look great 😀
April 21, 2005 at 5:27 pm #59360
Reinforced black wheels can be soaked in acetone to dissolve the superglue (& paint!).
April 21, 2005 at 8:27 pm #59363
ok guys i tracked down them comical bodys turns out there at RCmart the made by northcraft http://www.rcmart.com/catalog/product_info.php?cPath=421_438&products_id=11287 check it out
April 21, 2005 at 9:21 pm #59364
They aren’t all that flash… TFTR fellas tried them out in 2003 I think. 🙂
April 23, 2005 at 12:06 pm #59367
Does anyone have or know where I can get the decal sheet for the M03 Mini Cooper body?
April 23, 2005 at 12:55 pm #59368
try ebay or http://www.tamiyaclub.com
April 24, 2005 at 9:10 pm #59371
PS.. any one looking to get a mini.. PM me i might be selling my hoped up mini + spares + ESC+ batterys pretty cheap (wanna concentrate on my tourer)
