Mini-Z Colones
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › Mini-Z Colones
- This topic has 9 replies, 8 voices, and was last updated 21 years, 7 months ago by
June 22, 2004 at 6:19 pm #12202
Hey whats better, a Iwaver or a LXX mini-z clone? and plz tell me where can i get one?
June 22, 2004 at 6:25 pm #52661
srry for the double post* and can the Iwaver use regular mini-z hop ups? (like clear chasis and turbos)cuz i know they can use mr-01 hop ups
June 22, 2004 at 6:29 pm #52662
The I waver is basically 90% plug and play with mini Z parts.
As far as I know every part in the I waver is compatible with the mini Z except the servo gears, somebody correct me if i am wrong.
June 22, 2004 at 6:57 pm #52664
the lxx and iwaver are basically the same, just the lxx was 1st generation and the iwaver is second generation and comes with a clear controller.
nearly all parts fits except the servo gears.
June 22, 2004 at 8:28 pm #52670
The answer to your final question is – you can get one from
June 23, 2004 at 12:40 am #52695
Servo gears do fit! I put an iwaver servo gear into my mr01. Don’t ask why! argh…..
June 23, 2004 at 2:03 am #52698
That clear Tx is super cool.
June 23, 2004 at 1:22 pm #52706
ph2t; we had the reverse issue the other week, by that I mean mini Z gears do not fit in the Iwaver servo box. After afew attempts by afew members at the Meadowbank meet it was deemed impossible. Do you find there’s abit of play between the gears? Curious…
June 23, 2004 at 2:04 pm #52707
the iwaver has a slightly bigger Potentiometer in the servo box….by ‘bigger’ I mean the that metallic, protruding knob centered on the pot. This knob is the one that connects with the first servo gear in a tube-esque alignment. THe other two servo gears are interchangeable with z ones….
In short, one of the servo gears is designed for the iwaver pot, which is bigger. Try as I did, you cannot forcibly squeeze a Kyosho gear of the same type into the iwaver pot. perhaps if you found some way of making it bigger, but the gears are so damn small.
June 23, 2004 at 2:08 pm #52708
so if i replace the servo gears and the pot then all is well? the gears move freely otherwise?:8ball:
