motor – how many turns?
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › motor – how many turns?
- This topic has 3 replies, 3 voices, and was last updated 22 years, 4 months ago by
jamiekulhanek.
October 28, 2003 at 8:30 am #11874
heya ppl,
I m soon going attempt at handwinding my own motor, so since its my first time I ve got some questions to ask. 🙂
Could anybody tell me how many turns can the fets(6×2 and 5×2, IRF7389) take on a regular FA130, stock armature, around 30 gauge wire? Using 4x800mah NiMH batts.
Would there be any formulas to calculate the amount of power drawn to the motor with the certain amount of turns and gauge size?
Just to confirm, from my knowledge, the magnets dont make a difference to the amount of power drawn as that is determined by the number of turns on the arm. Am I right?
thanks
November 4, 2003 at 4:49 pm #47723Quote:heya ppl,
I’m soon going attempt at handwinding my own motor, so since its my first time I’ve got some questions to ask. 🙂
thanks
First i ask, what motor are you using as the donor, unless it is something like the plasma dash’s guts it just won’t cope (believe me i have tried). Anything below about 35 turns and the motor will shit itself to death.
The type and quality of the magnets makes a big difference to power draw, i.e. if you add Neodymium magnets current draw will increase many times over.
As for the rest i am really not sure, i *think* a 6×2 stack will handle down to 20 turns or so, but am not quite sure.
A really simple way of getting more power is to run 5 cells.
I guess for the formula you could use I=Current V=Volts R=Resistance
R=V/I. You might want to check with micro amps, cause i cant really remember.
November 5, 2003 at 4:17 am #47727
Thats Ohms law, looks correct.
November 6, 2003 at 6:36 pm #47748
Basically you need to choose whether to use 4 or 5 cells, the current draw, stick them in the above equation and work out the resistance.
You can determine the motor power output by P=VI
(Power in watts). Halve this number and you will get the maximum power at the motor shaft, as motors are around 50% efficient at max power.I used this formula to determine that my Plasma Dash motor develops around 30 watts of power.
Waht fets are you using BTW?? i recommend a 6×2 stack.
