Motors
Home › Forums › Bit Char-G, Digi-Q and other Micros › Digi-Q and other IR Controlled Micros › Motors
- This topic has 17 replies, 5 voices, and was last updated 22 years, 7 months ago by
scottyboyfun.
January 25, 2003 at 11:50 pm #11527
are there any motors available for digi Q which are about 2/3 of regular speed or evn slower. i want to race my bcg on my track but the Digi Q is way to fastblackeye:
February 14, 2003 at 11:00 pm #41133
so no1 out there knows whether or not there are, i know there is the easy speed but its still a fair bit to fast
February 18, 2003 at 6:15 am #43656
Id try placing a resistor in series to the motor, that will slow it down, just you need 2 find a suitable value.
February 18, 2003 at 11:23 pm #40941
im not to good with electronics so is there anything else u suggest and i just want it so i can switch betwwen slow and fast easily
February 19, 2003 at 3:36 am #40896
You know it really isn’t that hard,
It just sounds it, all that you would be doing would be cutting a wire that goes to the motor, and soldering a resistor in the gap!
Resistors come in all different values, so all you would need to do would be to try them out.
Just dont drip solder on the circuit board.
Ill have a look for you to c if ne1 has done this already.
February 19, 2003 at 8:52 pm #43650
ok thanks, what iwas hoping for was just a new micro snap motor sinetad of having to cut a resitor off evry time i wanted speed back
February 27, 2003 at 6:45 pm #40324
heh he, the digi’s can’t be modded, and I wouldn’t suggest modding a 1 inch $40 car. Get the propo special controller, you can modify all stats on the digi, in speed, accel, brake, and turning radious. It is the one and only mod that you need, they are however a bit expensive, running almost as much if not more money than the car.
ag04
February 27, 2003 at 9:49 pm #40296
thanks for that aq, is that the controller where u can key inb codes to drift and do donuts etc etc?
February 28, 2003 at 1:47 am #40266
Find below the codes, I got these from the below link.
KEAL put these all together in a list from the tinyrc forums!
THANKYOU KEAL!http://tinyrc.com/forums/showthread.php?s=853c1394e16d9157334ad7801819c4ca&threadid=6950
all the codes u could ever want!
Here’s the latest compilation of codes to feed your Propo Special Controller! I’ve taken all the codes posted so far and organized them by type. There’s a couple new codes in here. Have fun!
EXHIBITION CODES (for showing off)
Ballet Mode (9153 9253 9353 9453) (weaves around when accelerating, does spin at full throttle)
Max Spin Mode (9727 9737 9747 9757) (Drives normally, does spin at full throttle)
Spinning mode (0818) (spins at any speed, forward or reverse)
PuruPuru Back-and-Forth Mode (9214 9215 9216 9217) (dances back and forth when idle)
PuruPuru Rhythmic Mode (9365 9465 9565 9665) (dances Ayumi Hamasaki’s song ‘Independent’ when idle) NEW!
PuruPuru Side-to-Side Mode (9147 9157 9167 9177) (dances side to side when idle)PERFORMANCE AND RACING CODES
Digi Propo Easy Mode (0573)
Digi Propo Normal Mode (9573)
Mode A Advanced for floors (0321)
Mode A Advanced for carpet (0322)
Mode A Reverse Disabled (0648 0658 0668 0678)
Mode B Intermediate for floors (0271)
Mode B Intermediate mode for carpet (0281)
Mode B Reverse Disabled (0184 0284 0384 0484)
Mode C Beginners for floors (0343)
Mode C Beginners for carpet (0443)
Parallel Parking Mode (0555)
Parallel Parking Mode Reversed (0556)
RC Mode (9753) (reverse is braking power – for highspeed technical courses) NEW!
Tank Mode (9325 9326 9327 9328) (Car drives like a tank)
Toy RC Mode (0512 0513 0514 0515) (Imitates the Tomy Bit Char-G driving style)CHALLENGE CODES (Need a challenge? Try these)
Reverse Acceleration Mode (0761 0762 0763 0764) (Forward/Back is reversed)
Reverse Driving Mode (9853 9854 9855 9856) (Left/Right and Forward/Back is reversed)
Left & Right Reversed Mode (0423 0424 0425 0426) (Left/Right steering is reversed)
Tricky Mode (0444) Mastering this code makes you a DigiQ Master
Weaving Modes (0216 0217 0218 0226 0227 0228 0236 0237 0238)
Weaving Modes (0246 0247 0248 0256 0257 0258 0266 0267 0268 0276 0277 0278)__________________
MAME, DigiQ, and MP3s!Last edited by keal on 01-18-2003 at 10:20 AM
February 28, 2003 at 1:49 am #40265
Tiny RC has a fair bit of info on the forums about digiQ Shypo, if you fancy a look, click on the forums button, then go down to the digi q bit!
February 28, 2003 at 1:50 am #40261
February 28, 2003 at 1:51 am #40262
thanks for the help scottyboyfun, do u hapen to know how much a propo would set me back?
March 1, 2003 at 6:28 am #40204
it costs about $40 american, but I’m not familiar with australian currency.
ag04
March 1, 2003 at 9:16 pm #40177
thats about $70AU, thats pretty cool, and u can use it on all Digi’s right?
March 6, 2003 at 12:19 am #39915
yep, except f1 and combatdigi’s (tanks)
________
DigiQ-R: NSX-R -
March 6, 2003 at 1:18 am #39907
yeah but u can change the channels on the controller yeah?
and the digits arent hard to use are they??im not hugely into Digi’s but if this thing is sweet ten i may buy 1
July 24, 2003 at 3:50 pm #22034
Man that sounds cool, like traction control.
July 24, 2003 at 6:15 pm #22046
thees a drift setting.. as if you woul use traction:evil:
