motors! new plasma dash replacement found for $10
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › motors! new plasma dash replacement found for $10
- This topic has 38 replies, 10 voices, and was last updated 21 years, 9 months ago by
z-beam.
November 15, 2004 at 2:06 am #12426
http://www.tamiya.com/english/dangun/parts/parts.htm
some of these would make nice additions to my mini-z s. wasnt the plasma dash a tamiya 4wd product? all of these look new.
i know a plasma isnt any good unless you have upgraded fets but could any of these out-perform an x-speed without needing a fet replacement?
hows this… the “touch dash motor”:It s really a safety motor. The motor starts by pushing the car lightly and stops when the car hits an obstacle. In case Dangun Racer flies out of circuit, the motor stops upon bumping into floor or wall. i wonder how the hell it does that… not much use in a z tho…
Edited by – z-beam on 14 November 2004 21:16:31
Edited by – z-beam on 30 November 2004 23:45:40
November 15, 2004 at 2:17 am #56982
the torque tuned is a good motor compared with the x speed and i’ve run one in an i waver with stock fets. only drawback is the cheap and nasty copper brushes but that’s easy fixed:8ball:
November 15, 2004 at 2:41 am #56984
it said the “sprint dash” comes with carbon brushes…
did you get one in australia betty?
November 15, 2004 at 3:47 am #56985
torque tuned is good with ‘stock’ Z brushes…gets better with a bb can and carbon brushes…ALL OF WHICH I STOCK OUT THE WAZOO 🙂
My monster runs a bb can torque with no power adjustments needed at all…anything HIGHER than a TORQUE and you need some help of some sort…I LOVE TAMIYA 😀 -
November 15, 2004 at 4:15 am #56986
all the tamiya motors i’ve got either came from rcmart or bithead. i’d buy them from bithead and get them included in the next shipment to aus:8ball:
November 15, 2004 at 4:25 am #56987
…thanks betty…i have squat bb cans; the BEST…and lots of ‘stock’ z motor parts to keep things simple 🙂
…this is one i did up, a TORQUE TUNED, as a freebie for a client in Belgium 🙂
November 15, 2004 at 4:26 am #56988
…needless to say my soldering has improved :blush:
November 15, 2004 at 4:37 am #56989
im after a slower motor with a little more power than a stock-z motor… any ideas guys… its for my new camaro project.
one of those bb’d and carbon brushed torque tuned motors sound like some good produce, what’re they worth from you bithed.
November 15, 2004 at 4:44 am #56991
…TORQUE i do for 8 usd shipped…SQUAT bb can and carbon brush set is 15 USD…that may sound expensive but i KNOW you know i dont deal in badly made crap 🙂 TOTAL 23 USD shipped to your door with TAMIYA freebie stickers and yet ANOTHER pack of gum to keep that old cold turkey out of your hair 🙂
November 15, 2004 at 4:51 am #56992
is $23 USD price for the motor assembled?
i wouldnt know what to do with those parts! -
November 15, 2004 at 4:55 am #56993
correction…19.90 USD ASSEMBLED and SHIPPED 🙂 I forgot to reduce the second item by 3 USD 🙂 Yeah i can put that together for you ZBEAM…
November 15, 2004 at 5:00 am #56995
…some more samples to wet your whistle on…
November 15, 2004 at 5:03 am #56997
…and i do TAMIYA motor cases, holds 8 motors in little compartments, clear plastic lidded box, stamped with the TAMIYA and DANGUN RACER logos for 7 USD SHIPPED or 5 USD shipped if its your second item 🙂
November 15, 2004 at 5:08 am #56998
bithed, your the man!
some details on the properties of the above four would be great, as in what abilities they have (your observations not the advertising blurb)?
November 15, 2004 at 6:24 am #57005
…Zbeam im probably not the best one to ask RE: the ‘properties’ of each…There is a load of info on this site and other places about the place…actually do a simple search for plasma dash and Ausmicro comes up more than once 🙂
Right now my limit is the bb can torque…it works HELL good in the monster with torque and a high top end to match…better than an xspeed hands down…Then again someone else might not like that…
The plasma is the devils work…hot and spicy and willl melt down a naiive esc faster than I will try to sell you something 🙂
…There is an OPINION in Z circes here in Japan that the Atomic Tuned is BETTER than the Plasma Dash because it is closer to the ‘stock’ motor in design..Again some members in here will refute that and might tell you something different, expesially with the amount of mixing and matching going on with magnets and bb cans etc…
…Rev Tuned you will need a turbo for sure…Puts your esc speed and it thinks its making instant noodles instantly…Caution required for sure…
…The Mach Dash im not sure about..Bit of an unknown for me right now…
…of course ALL of these motors will be able to be used on and off no worries with Nelly ™ in your belly 🙂 oohh…That has a nice ring to it 🙂
…Final Answer? For the average Z guy i think you would be good with a torque tuned, an atomic and a plasma in your pit box…Some magnets, a couple of bb cans and some savaged ‘stock’ motors, caps and wires, and you are good to go…
…to make matters worse i use phat wires, forget the gauge now, and SQUAT capacitors cause they lok nice 🙂 They are square and flouro blue 🙂
…Right now i am pretty thin on any info of the other motor makers, NML, Atomic, PN etc…
…do a search in here and see what you come up with…
…start with this one 🙂
November 15, 2004 at 6:41 am #57006
will the atomic tuned melt my stock z?
thanx for all that info man, it brought me up to speed on the motor options for the z…
November 15, 2004 at 7:42 am #57007
..Z…An Atomic probably WILL melt you down…Its time for Some of the Tech-heads to help you out 🙂
…Below is some info stolen from somewhere on who is who in the zoo 🙂
If any of these numbers are wrong or should be adjusted please let me know and i will change them or you can adjust them in your own post…Pobody’s nerfect ok?Name
RPM
Torque
Comment
Power Consumed
RPM with LoadTORQUE TUNED MOTOR
13,600 RPM
14.5 g-cm.
Good for uphills and curves. Tech motor
1200 mA
12000 RPMREV TUNED MOTOR
17,600 RPM
10 g-cm.
Good top speed for tech straights. Tech motor 1500 mA
14300 RPMATOMIC TUNED MOTOR
15,700 RPM
10 g-cm.
Best for super technical courses.
1300 mA
15700 RPMPLASMA DASH MOTOR
29,000 RPM
20 g-cm.
Raw power for speed tracks.
4100 mA
25000 RPMMACH DASH MOTOR
23,400 RPM
15 g-cm.
Faster than a Hyper dash. Speed Motor
1900 mA
20,800 RPMULTRA DASH MOTOR
29,000 RPM
20 g-cm.
Good climbing motor. Speed with uphills
4000 mA
24,000 RPMJET DASH MOTOR
28,000 RPM
22 g-cm.
High top speed with high torque. Speed motor
4000 mA
23,000 RPMEdited by – bithed on 16 November 2004 01:13:00
November 15, 2004 at 2:02 pm #57008
well, that just got printed… lol thanks for that info Bithed! Very handy:smiley2:
November 16, 2004 at 5:49 am #57018
bithed, for the Jet Dash, i think the RPM and RPM under load should be swap around.
November 16, 2004 at 8:06 am #57021
Bithed that info is completely useless for mini Z people…
remember that mini4wd’s run 2 cells, mini Z’s run 4 cells, the current draws are gonna be much higher than listed.
November 16, 2004 at 2:52 pm #57027
…which is why i say take it all with a pinch of salt…but it gives people an idea Jamie…Its like a Paint Chart for morors you know..its just a guide…Completely useless? I dont think so…
November 16, 2004 at 3:13 pm #57028
Those jet dash motors go for ridiculously high prices on ebay. Saw one go for about $20-30 USD several weeks ago.
Is it because they are out of production or something ?
November 16, 2004 at 5:08 pm #57032Quote:Bithed that info is completely useless for mini Z people…
useful for people who want an idea of rpm etc. before they go out and buy…
November 16, 2004 at 7:01 pm #57038
…Dave is right…the above numbers dont realistically translete to use in the Z but the info itself just gives the AVERAGE user a better of what is what and what it does…Anything over a TORQUE TUNED needs a turbo and as far as i know Nelly covers ALL of them and more!! By no strech of the imagine is the above list a PURE document…it IS the list of the information of each motor provided by TAMIYA…Thats all…
…The prices of these motors is always funky and ebay isnt a great measure-mark because you might have some guy in France who wants one no matter what and the price will go up…another day, and this happened to me last week, the same motor can go for half what the pervious auction did..Jet Dash’s ARE a little harder to get than other motors, especially after TAMIYA changed their names of the motors for the RC 4WD sets…Actually BANDAI has released a SIMILAR toy to the Mini 4WD…looks quite good…but thats another thread…
December 1, 2004 at 12:33 am #57291
http://www.leoshop.com.tw/image/toy/bandai/crushgear/04138.jpg
i picked up a hi-dash upgrade set today for $6 au. came with a 29,000 rpm motor (21 g-cm)
there is also a hi-spin motor rated at 33,200 rpm but only 17g-cm.
this is a really good source of plasma-dash goodness!!! now whos going to install a nelly for me???
$10 useually
December 1, 2004 at 12:36 am #57292
this is the bandai version by the way bithed.
the standard crush gear sets are only 15,000 rpm.
some have a 15,300 rpm rated motor.
Edited by – z-beam on 30 November 2004 19:39:31
December 1, 2004 at 5:32 am #57295
Great find zbeam, i’ll check the shops asap
December 1, 2004 at 5:54 am #57296
the hi-spin motor has a warning:
continuous use for 5 minutes the motor will become so hot it has a danger of burning you and melting the plastic body of the crush gear…
imagine this thing in a z. these motors are designed for use with only 2 aa’s.
i think i just found the new speed king!
i think i should grab a few of these whenever i see them…
Edited by – z-beam on 01 December 2004 00:57:09
December 2, 2004 at 6:13 am #57308Quote:…Dave is right…the above numbers dont realistically translete to use in the Z but the info itself just gives the AVERAGE user a better of what is what and what it does…Anything over a TORQUE TUNED needs a turbo and as far as i know Nelly covers ALL of them and more!! By no strech of the imagine is the above list a PURE document…it IS the list of the information of each motor provided by TAMIYA…Thats all…
Hmmm what i said came out a tad harsh, what i am saying is that the RPM figures go up by a good 60% as do the other figures…..
December 2, 2004 at 7:55 am #57310
So zbeam, these motors available in Aus right? wherever they sell crushgear, they’ll sell them correct?
December 2, 2004 at 11:16 pm #57314
the weapon otion parts seem to be far more numerous and common than the motors but almost every stockist of the crushgears should have them or would have had them…
knowing aussie toy distibuters a box of option parts would contain one or two of the motor packs, toyworld or toys r us are your best bet…
December 3, 2004 at 4:02 pm #57318
bring these motors to the meet on the 12th man. we’ll test ’em out!
December 4, 2004 at 1:18 am #57331
i sent them to jamie kulhanek today to be fitted with the neccissary parts to be able to run on a z.
are you going to have a go at the speed records ph2t? i’ll get one sent to you if you are….
in the meantime if i find another one do you want me to pick it up for you?
December 4, 2004 at 9:33 pm #57336
by the way you should receive them by monday jamie…
December 5, 2004 at 8:04 pm #57348
Hey I’ve tried both those motors some time ago. but i can’t remember the results. I think it was before I got a nelly and if i recall correctly i had rewound them with devastating results to my pcb. All I know is I abandoned the idea. I’m using a plasma armature in an atomic case with ball bearings and neo’s and it’s brutal:evil:.But Has anyone tried a brushless motor? What about a larger motor? What size motor can nelly 1.3 handle? where’s the “big block” mini-z…. the blown v8 musclecar mini-z? huh.
December 6, 2004 at 5:31 pm #57369
related…
http://www.toyeast.com/v2/proddetail2.asp?pdtid=A05001349
It must be some glitch… 99 cents for one of those babies???
December 6, 2004 at 6:20 pm #57372
@charlie, it ain’t a glitch. The motor is crap. It doesn’t have brushes, just copper wipers that ware out in a second. TE prolly a surge of orders for it and now it’s barely moving (cause it’s crap). hence the price drop.
@z-beam, score me one of them motors mate, I’ll hook you up with the $$ at the melb meet next Sunday.
@z-nagual, nelly can handle all 130 sized motors mate. Dunno about bigger sizes though, never tested. As for the “big block”, sounds like you’ve got it already :D. The atomic bb can + plasma armature is the best you can get. Swap out the neo magnets for the original ferrite(black) magnets that come with the plasma and you’ll see a HUGE increase in speed. Acceleration will drop off, but not as much as you would think.:D -
December 6, 2004 at 9:41 pm #57375
ok:approve:
December 7, 2004 at 5:26 am #57381
i grabbed a hi-dash one for you ph2t…
