My Gloria
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › My Gloria
- This topic has 8 replies, 5 voices, and was last updated 22 years, 4 months ago by
micro_Amps.
October 13, 2003 at 6:48 pm #11461
I’ve been workin on this car for a while now. It’s been in the garage on and off over the last month. Hope you all like it as much as I do. She’s great for a bit of night driving.
Her specs:
Custom lights setup using my 5V DCDC Convertor PCB.
Spring suspension
Green gloria shell painted with Holden Gunmetal duplicolour autopaint
DoubleStacked mosfet H-Bridge
Guitar string antenna
150mAh NiMh Battery
Custom modified Bit-CharG rims.
EM3.0 motor, orange gears.Yum!
Edited by – ph2t on 13 October 2003 14:51:38
October 13, 2003 at 11:06 pm #29507
Here’s some shots of how I did all the (very messy) wiring.
As you can see I’m using one of my little 5V light PCB’s to run the leds, in this photo I have it hooked up to a 3V lithium for testing. The 3V doesn’t really matter since I get the same output from a 1.2V source anyways.
Here you can see how the front white and blue leds are mounted. I made sure to keep the light fixtures clear so I had masked them before painting. I’m a big fan of using surface mount leds and not drilling holes through the shell, that’s just me. I put a drop of superglue on the area and then hold the led to it to ensure its flush and I get a good contact so the light from the led gets a much brightness through the plastic as possible.
The same goes for the rear lights. Dang there’s a lot of wires there!
The Rims
The rims were made from normal Bit-CharG rims with some putty(bluetak) and some masking/painting.
First I bogged up every other spoke. I then used a cut up eraser to flatten the surface of the bluetak. Bluetak is used to hang posters n stuff so it’s pretty soft and prone to warping.
Once that was done I then masked the outer edge of the rim to keep the silver edge. I also masked the inside surface of the centre hub to keep it silver as well. Lookin’ a bit freaky at the moment, lol.
I then spraypainted it white. Approx 3 coats giving about 10 minutes drying in between. Once it had dried fully I then removed all the blutak and I got this. Pretty cool!
The front rims were done using the same method. They might be pretty small but it’s still achievable.
Once all the rims were done I threw them on the chassis and we are cool to go.
Yeah baby!
October 14, 2003 at 1:29 am #33180
nice work ph2t, looks great. nice whells, and as always, nice electronic work.
October 14, 2003 at 12:39 pm #29296
I’ve been tempted to go down the same road with the wiring stuck to the body. You’ve convinced me to give up on a light set to swap between shells, and just have a body that has lights.
Love the wheel idea. Good result. Should leave longer between coats though, unless the pait says recoat after 10 minutes. Rushing the coats will give a less smooth result, and a light sand between coats does wonders too.
October 14, 2003 at 1:06 pm #29419
Awesome!! That looks so cool.
October 15, 2003 at 2:48 pm #30074
You’re enterring that in the Comp, yeah!!?!?!!
October 15, 2003 at 4:15 pm #39157
Good stuff ph2t, love the wheel idea, might look good in other colours too.
October 15, 2003 at 5:58 pm #28964Quote:You’re enterring that in the Comp, yeah!!?!?!!
A few touchups are requred first. Gotta do the old “paint the inside black” mod to it first to realy make the lights how I want them.:p
October 18, 2003 at 1:17 pm #28286
Here’s some custom ph2ty video action:
http://www.prahranpianos.com/bit_g/day_final.avi
Divx format of course, if you don’t have divx got kick your own arse then visit http://www.divx.com.
