new pinion
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › new pinion
- This topic has 10 replies, 3 voices, and was last updated 22 years, 4 months ago by
VR-4.
August 7, 2003 at 6:55 pm #11785
heres a way to get about a 20 tooth pinion or more from your mini z.
you need a tamiya mini4wd car “well just the gears from it”
you take the gear “blue it the 20 tooth” the gear with the long shaft and 2 sets of teeth “kinda looks like a 2 speed pinion” and you just put it on your motor. you will need to make a new motor clip and a thick spacer for to get the mesh right.
August 7, 2003 at 7:10 pm #46689
Yes lets all over gear our motors and burn the hell outta them, and have not enough torque to poke a stick at!
August 8, 2003 at 7:53 am #46694
thats whare your wrong i run ether a handwound nml or a plasma dash and with a 20 tooth and i still got power and abunch of extra speed.
August 8, 2003 at 6:34 pm #46723
I bet ya it doesnt last nearly as long.
August 8, 2003 at 6:38 pm #46727
so its faster thats all that matters
August 8, 2003 at 7:28 pm #46735
There is a fine line between overpowered and perfectly set up, I like my cars to have a good balance of speed, acceleration, handling and balance.
Thats fine though, ur a typical American.
August 8, 2003 at 8:01 pm #46741
well my car “useing foams” can take off like a bat outta hell and take the turns pretty good only problem is you gotta use a solid suspension plate becouse the tork from the motor just snaps the stock plates lmao.
what can i say im american i dont understand “over powering”
August 8, 2003 at 10:52 pm #46751
if you really wanted to be helpful vr4 you could post the correct thickness for a sweet mesh…
August 9, 2003 at 7:16 am #46754
i gotta buy a new micromiter i spilled pop on mine and broke it. should have 1 either today or tomorrow
August 11, 2003 at 3:17 pm #46782
Are your foams glued on?? Cause my GPM 10 degree soft tyres fall off when they hit about 40km/h or 25mp/h.
Often wider tyres can be a problem, something to do with downforce vs tire contact area.
August 11, 2003 at 3:25 pm #46784
i used some shoe goo ta glue them on then i trued them.
get some mini 4wd reson tires they grip so good but you need 2 packs becouse 2 are wide and 2 are narrow
