Newbie needing help with electronic stuff
Home › Forums › 1/8, 1/10, 1/12, 1/18 – Discussion › Newbie needing help with electronic stuff
- This topic has 17 replies, 7 voices, and was last updated 20 years, 7 months ago by
mocky.
February 14, 2005 at 10:52 pm #12552
I m gettin into 1/10 and was wonder if this electronic equipment is good enough to me goin?
ESC – http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGNG5&P=ML
Receiver – http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFAG7&P=7
– http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXALN9&P=7
Servo – http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXVW07&P=ML
Motor – http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHUJ1&P=7i m not sure of the receiver, which one should i get?
all tips and suggestions are welcome cos i need all i can get. -
February 15, 2005 at 2:15 am #58505
thats speddy is for 1:18 even a low rated 540 motor will blow it
as for RX/servo its about the same to get a whole new kit so ya get a new transmitter (better than what u would be using with these).. i would suggets somthing like http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXENN3**&P=0
is a very good radio for beginners and intermadiate racing..
as for that motor.. well i wouldnt touch a motor that isnt rebuildable.. if ya gonna race ur gonna probly need a 540 silver can to start with and then get a stock (27T) motor when u go up a class.. but 5430pro istons fast enough for ur first 8 months – year if you are bashing i would suggest http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCUP8&P=7or check this out 😀
http://www.ausmicro.com/topic.asp?TOPIC_ID=3027&FORUM_ID=23&CAT_ID=7&Topic_Title=HPI+sprint+FS&Forum_Title=nonMicro+RC+%2D+Forsale+%7C+Want+%7C+Swap
i can get you radio gear motors batterys chargers ETC to get it RTR if your interested -
February 15, 2005 at 9:03 pm #58520
are u sure bout the esc being for 1:18? ive done some diggin and its suggested to be a 1:10 esc.
http://www.teamnovak.com/products/esc/xrs/xrs.html
Quote
“The XRS Sport Reversible ESC is the ideal ESC upgrade for the following popular vehicles:
Tamiya TLT-1 Rock Buster, any XB series car “
this is wat ive found .also on the intruction manual it says its for a 1/10. so im a bit confused bout that novak esc.
also im afta 27mhz am receiver, prefer not to ship in a whole controller.ive got this esc in mind
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXAXT8&P=7
or this one
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHSV8&P=7
, will it work with 27mhz am receivers?Edited by – mocky on 15 February 2005 16:10:38
Edited by – mocky on 15 February 2005 16:16:59
February 15, 2005 at 9:29 pm #58522
What sort of 1:10 do you have in mind monkey…
February 15, 2005 at 10:09 pm #58525
tb02…
i;ve decided the servo and im definitely headin towards a 27mhz am receiver, hard choice is the esc and batt pack.
any help me out with the receiver and esc. urgent help needed, thanks for the feedbak thats been comin in btw, the more the merrier.Edited by – mocky on 15 February 2005 17:17:04
February 16, 2005 at 2:03 am #58529
mocky. personly i think ur doing it the hard and more expensive method.. but its your money
.. the novak XRS is reated to 40 amps a cheap 1:10 esc is rated 200 amps it would only handle silver can or sport tuned motorsas for radio gear why do you want to buy a RX and servo seperatly?
that servo is only .01 seconds faster so not really any better than a S3003 and both will break just as easly (never if your running a good servo saver)maybe u should look at sumthign like this:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBJA6**&P=0100 USD
if you just bought a RX and servo what TX would u run?
February 16, 2005 at 12:46 pm #58531
i’m assuming you want to use your i waver tx, and that’s why you want a seperate rx and servo. there’s nothing wrong with that really, i did.
i’ve been abusing a futaba s3003 for a while now and it holds up fine, maybe a little slow. i’t currently in my monster and serves me well.
but when it comes to an esc, spend as much as you can. when you’re new you make lots of mistakes that can fry even a good esc. i killed my first esc by using throttle when there was a rock in the belt and it was rated at 240a continuous, 940a peak. so that esc you’re looking at will probably pop the first time you touch the throttle!:8ball: -
February 16, 2005 at 4:03 pm #58536
yeah.. if ur gonnna use a IW TX well.. enjoy. buy a 27megAM RX.. smaller is better.. futaba or Jr are good and a 3003 is good if ya wnat better get a hitec cheap and faster
get a GOOD speedy best u can budget -
February 16, 2005 at 9:03 pm #58545
well afta calculating it will cost me 20usd more if i buy a radio receiver and servo pack BUT i get a new tx which is always handy if one breaks.
that novak esc im not getting afta hearing bout wat u guys have said beta safe than sorry.
rite now its a battle between the nocak explorerII or the futaba MC330CR or associated a.i automatic super esc. which one would be the best and safest choice? mines a tb02 so i wont get stuff stuck in the belt.Edited by – mocky on 16 February 2005 16:19:10
February 17, 2005 at 1:16 am #58548
it’s only been about 3 or 4 months since i got my first 1:10 and lemme tell ya, if i knew then what i know now i would have bought a brushless setup at the beginning. they sure look expensive to a new feller but after wearing out 3 motors (3 x $60) and zillions of brushes they don’t looks so expensive any more!:shock:
just get an esc with the highest current rating you can afford. and don’t forget to check if it has the features you want (brake, reverse, have kettle boiled in time for end of race!:smiley2:):8ball: -
February 17, 2005 at 1:35 am #58549
lolz, i aint gonna be a hardcore racer and kill a motor per run. and brushless is way outta my price range atm.
from wat it looks like now i’ll have nearly the same setup up as kevsta had. -
February 17, 2005 at 4:42 pm #58554Quote:are u sure bout the esc being for 1:18? ive done some diggin and its suggested to be a 1:10 esc.
Quote
Tamiya TLT-1 Rock Buster, any XB series car “Novak XRS is made for 1/10, it’ll take anything down to 15turn motor.
Its about the same (specs & target market) as a Futaba 230 or 330.Disregard all the current amperage ratings; each ESC mfgr has their
own way of calculating the ratings and even Novak has *changed*
their methodology in recent times – don’t even compare ‘old’ specs
to the current Novak specs. :dead: -
February 17, 2005 at 5:30 pm #58555
What I always thought strange was ESC makers say somethign is good for XX Turns, but knowning the there’s other factors in play the ESC may not handle a brand X 12turn vs a Brand Y 12turn.
I tend to think you’d pick an ESC rating these days by like buying a 14turn friendly ESC and only running down to 16 or 18T… Margin for error 🙂
I’ve always been happy with the low end GM V4Rs but I’m not a mad keen racer, just a hack around typa guy ….
February 17, 2005 at 9:03 pm #58556
yeah i do the same never run it on a limit.. and pandawould u run a 15T on a 80A esc?
February 17, 2005 at 9:55 pm #58558
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXENN3**&P=ML
i just bought that but im wondering if it comes with crystals??Edited by – mocky on 17 February 2005 16:55:32
February 17, 2005 at 10:48 pm #58559
From Tower… Don’t they give you 75 Mhz crystals ?
February 18, 2005 at 2:09 am #58561
yes it will come with xtals and look out make sure its a 27 or 29 not 75.. 75 is illegal in australia
February 18, 2005 at 12:54 pm #58563
damn..
