Novak Rooster
Home › Forums › 1/8, 1/10, 1/12, 1/18 – Discussion › Novak Rooster
- This topic has 11 replies, 5 voices, and was last updated 21 years ago by
merc-blue.
March 5, 2005 at 3:18 am #12574
any1 seen the novak rooster reversible. its claimed to be no motor limit but besides that i seems liek it has many functions. wat are u thoughts bout it?
Edited by – mocky on 05 March 2005 08:20:39
March 5, 2005 at 3:23 am #58771
the super rooster is NML the rooster is 15T.. its defently a bash speedy only 64 throttle steps FWD and 32 reverse
its not fwd reverse like i remember im 80% sure is fwd brake.. then if ya hold it in barke or repress brake without going forward then it reverses.. ok i guess.. personly i would go sumthing different.. -
March 7, 2005 at 6:38 am #58800
Rooster is pretty old hat.
Super Rooster is good for trucks; its a huge & heavy beast.
Not sure if there’s any good Reversible ESCs that Novak makes with low motor limit etc – otherwise I’d have one by now. 🙂 Just acquired an LRP F1R, getting worked over on the bench.
March 7, 2005 at 3:12 pm #58803
I’ve seen how big the super rooster is and I think it’ll take up more room than you have in your tub once you fit your servo/receiver in.
March 8, 2005 at 10:42 pm #58819
>< damn, i cant tell because ive neva seen i and i havent looked at its dimensions either. any used the associated super A.i esc? im having a tough choice betwwen that and the futaba mc330cr.
March 9, 2005 at 2:00 am #58822
never heard of the super AI.. give us stats and i can tell u wat it really is and what it was b4 it was rebadged the mc330 is a drcent ESC for a beghinner the 230 is crap but 330 is decent as a starter esc or a mini esc and such
March 9, 2005 at 12:46 pm #58825
This is the Associated AI Super Reverse Electronic Digital Speed Control.
FEATURES: For car motors 14 turns and above Handles 4-7 cell battery packs, 4.8V-8.4V AI (Artificial Intelligence)-no manual user setup required just pull throttle on transmitter to set up Digital interference protection circuitry guards against radio interference, empty transmitter batttery or model outside of radio range-model stops instead of continuing uncontrolled Ideal upgrade for all Ready To Run speed controls Motor and battery connectors installed-no soldering needed
NOTES FROM OUR TECH DEPARTMENT
INCLUDES: One Associated AI Super Reverse Electronic Speed Control with motor capacitors, tie-wraps, mounting tape, user guide and color sticker set
REQUIRES: Installing on vehicle and connecting battery and motor
SPECS:
Length: 1.7″ (42.5mm)
Width: 1.7″ (42.5mm)
Weight: 1.7oz (47.5g) excluding wires
Voltage: 4.8v-8.4V, 4-7 cells
Typical Voltage Drop @20A: 0.160V
Rated Current: 120A Motor
Turn Limit: 14 turns and above
BEC: 5.0V
High Frequency: Yes
Fail Safe System: Yes
Multi-Protection System: Yes
Connectors: Standard Tamiya style
Setup: Automatichttp://www.teamassociated.com/shusting/CatalogHub/lrp/AI_esc.htm
March 9, 2005 at 10:57 pm #58848
Anything AE is usually a rebadged LRP.
I think latest basic LRPs are now “AI” in that they don’t need once-off programming… instead you need to “program” it everytime its turned on.
March 10, 2005 at 2:06 am #58851
i would go the mc330 i race with a mc800 very good bit of gear also “AI” is rubbish
and yeah zoomer they are rebadged LRP/nosrams
March 10, 2005 at 2:25 pm #58858
Yeah stick with mc330cr. I surprised you want to run so hot… You must have a stash of tb02 bevel gears and outdrives somewhere ?
March 10, 2005 at 3:33 pm #58860Quote:Anything AE is usually a rebadged LRP.
not true, it needs no programing, does it itself. good idea if it works how they say. which being lrp i am sure it will
March 10, 2005 at 4:22 pm #58863
VERY TRUE… if u turn ur car on and bump backwards first ur throttle will be reversed and sometimes at a race day u dont have time to make sure. and if it u lose power for a second u can have ur throttle reversed or max throttle on trigger = 20% on car and stuff it can end ur day if it dont setup rite or i have even had one setup nutral is aobut 40% trottle..
compared to a 1 time setup do in comfort of ur own home and make it all good and never have to worry about it untill u change gear
