oil problem
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › oil problem
- This topic has 14 replies, 8 voices, and was last updated 22 years, 3 months ago by
RacerX.
August 6, 2003 at 6:44 am #11215
ok heres the problem.
I read that oiling the gears makes char-g run alot smoother.
ok i went to the local hobby shop and asked some oil for gears….
they gave me the oil… went home… and put on the oil… test ran it and at first it didnt run at all… then i cleaned it a bit and it ran better but it doesnt run even half as fast as it used to… its really smooth though…
QUESTION: WHAT KIND OF OIL SHOULD I USE?Edited by – mutionu on 06 August 2003 02:45:53
August 6, 2003 at 8:48 am #21659
wouldnt oiling the gears make them slip easier instead of getting a good grip to turn the gears?
August 6, 2003 at 10:11 am #21661
well the problem aint anything like that its more like the motor doesnt have enough power to move the car.
August 6, 2003 at 8:07 pm #21670
I know the guys usually use something really light, like silicone oil spray (check your hardware store). Some use powdered graphite.
Thicker oils & grease will cause drag. Your BCG motor will not have enough torque to overcome the extra drag.
August 7, 2003 at 1:55 am #21681
Use the ceramic grease tamiya make for plastic gears, it works very well.
August 7, 2003 at 7:21 pm #21697
Use graphite powder, it has virtually no drag, and as it is a powder, it doesnt get sh*t stuck to it.
August 8, 2003 at 4:16 pm #21737
i have the tamiya ceramic grease as well, never had any problem s with it before
August 8, 2003 at 7:09 pm #21769
Oh sure, I’ve got some of that tamiya grease, and it is great stuff, but for carpet racing, it only helps to pick up crap.
Graphite has even less drag than ceramic grease (More power at the treads), and once applied, prettymuch stays there for an eternity.
August 9, 2003 at 1:22 am #21809
ok thx for the help but how can i clean it from old oil?
i cant see it anymore but it still runs a bit slow -
August 9, 2003 at 5:10 pm #21819
jamie ill give the graphite powder a go cheers
August 15, 2003 at 5:12 pm #21961
skateboard synthetic oil is the best in my oppinion, the graphite powder has some nasty health side affects…:dead:……. one drop of synth oil is more than enough
August 15, 2003 at 6:23 pm #21962Quote:jamie ill give the graphite powder a go cheers
I warn you, it can be messy…..only apply it to the idler gear…i.e. take the idler gear off, and rub it in the carbon, then replace it. Do this outside as it can get messy.
August 15, 2003 at 6:25 pm #21963Quote:skateboard synthetic oil is the best in my oppinion, the graphite powder has some nasty health side affects…:dead:……. one drop of synth oil is more than enough
Still, the skater lube manages to pick up dust and dirt…..and there is no health side effects with the graphite powder if you do it properly, its basically the same as pencil ‘lead’.
August 16, 2003 at 4:05 pm #21992
bearing lube is very thin though doesn’t clag as badly but hell it’s expensive just use sewing machine oil I use the shit on my board works the same so it should work on a bit fine
August 16, 2003 at 8:05 pm #21625
dust and fluff are a bits worst enemy, and yeah it sticks to the oil pretty bad. it’s always good to race (or cruise) on a clean surface….
the trouble is finding a clean enough environment….
