Painting Question:
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Painting Question:
- This topic has 19 replies, 10 voices, and was last updated 23 years, 3 months ago by
PandaBear.
July 3, 2003 at 10:01 pm #11524
i got some Humbrol Enamel model paint and was wondering if i can just it on bitcharg shells?
any tips on painting the shells will be appreciated
thanks -
July 3, 2003 at 10:59 pm #24699
I like to use spray paint, I havn’t tried using enamel but I think spray would be easier and still looks good.
July 4, 2003 at 2:17 am #24701
I brush on Acrylic paints, because it gives me a lot more freedom while painting, and then put a layer or two of Clear coat over it. It gives a surprisingly smooth look if you keep your brush strokes even and in the same direction.
Enamel sprays kept bubbling on my bodies.
July 4, 2003 at 3:16 am #24706
I use the spray paints for my Bits too. It doesn’t cause bubbles but somehow it’s so easy to get dust on it. And it’s somehow easy to rub off as well. why?
July 4, 2003 at 3:20 am #24707
Mine doesn’t bubble either, I usually leave it out in the sun for a few hours after I paint it so any small bubbles that do appear are gone by the time I take it out of the sun.
July 4, 2003 at 3:22 am #24708
Is use spray cans. The cheaper and nastier the better! lol! Getting into decals now though, they’re pretty darn cool as well.
July 4, 2003 at 3:26 am #24709
yeah, im on hobbyone’s phone list for when they receive clear decal paper, has anyone used this? is it good?
July 4, 2003 at 12:22 pm #24716
i like using acrylics, ive used sprays before, and it just doesnt look they way i want it too. acrylics give you a lot more freedom, and they will definetly not bubble or rub of easy. Make sure to clear coat to or else it can leave rough marks and other wierd spots… good luck:D
July 4, 2003 at 4:05 pm #24723
so if i use the Enamel paint it, it will bubble?
July 4, 2003 at 5:05 pm #24725
i used car paint on my wrx.. silly me it came out mat so i had to get a cutting compound and polish it…just like a 1:1
July 4, 2003 at 5:35 pm #24736Quote:so if i use the Enamel paint it, it will bubble?
There’s another earlier thread on this… :smiley16:
Enamel paints can only be applied over other enamels. If you paint enamel over acrylic, the acrylic below will wrinkle/bubble.
(But you can apply acrylic over other acrylic or enamels.)
If you’re painting over an existing painted shell, I suspect the factory paint is acrylic. You’ll have to strip it back to bare, or start with one of the unpainted spare shells.
As for dust… gotta paint & let-dry in a dust-free environment. :smiley2:
The pros have ventilated filtered paintbooths with waterbath floors… -
July 4, 2003 at 9:20 pm #24589
so can sumone just clear this up.
if i use enamel paint on a clear unpainted shell everything will be fine.
if i paint over one that alrd has paint on it i have to remove it or it will bubble. can i just put a primer coat over the paint and use the enamel on top with no problems.
right? -
July 4, 2003 at 9:26 pm #24590
I dont know, looks confusing to me, I think clear shells will be fine, I think you have to use primer if you are going to paint a already painted shell.
July 8, 2003 at 7:13 pm #24245
enamel has a hard time without prior sanding (aargh!!! dust) or a use of an enamel primer, the colour spray has a hard time sticking to smooth plastic.
i recomend using an undercoat on any paint job as it greatly improves the look of the finish, especially acrylic. if you are using light colours a white is good but for all metalic and darker tones a black is best. if in doubt a grey spray never goes astray!
3units of art at high school tought me pretty well. suprisingly the opposite on the colour wheel will give a perfect contrast as an undercoat, e.g red under green, the reason being it reflects every available particle of light to the eye( thankyou Monet!!!)
July 10, 2003 at 1:19 am #24027Quote:yeah, im on hobbyone’s phone list for when they receive clear decal paper, has anyone used this? is it good?
July 10, 2003 at 2:12 am #24031
what was that quote for? I meant to say its paper that you can print your own decals. It comes in white and clear but hobbyone didn’t have any clear sheets in stock, so they are going to call me when some arrives. Has anyone used this? is it good?
July 10, 2003 at 2:29 am #24032
sorry barto what I ment to post was are the deacls printed off a pc or painted because kmart has transpearent labels for printers but you need a good printer
July 10, 2003 at 3:03 am #24035
yeah its just going to be a blank sheet and I was going to print them myself, but it probably will be quite difficult.
July 10, 2003 at 3:10 am #24039
try somewere like office works it’s good stuff just do test runs with normal paper. or you can do my last system and buy a techdeck and use the mini stickers that come with that:D
July 10, 2003 at 3:13 am #24040
oh ok, yeah I will run some test prints on normal paper first. I’ll have a look at those tech decks, thanks. If I go ahead with the hobby sticker paper I’ll post results on what I think.
