pix of my BitchG
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › pix of my BitchG
- This topic has 7 replies, 1 voice, and was last updated 23 years, 6 months ago by
May 24, 2002 at 6:01 am #9001
I’ve decided to de-lurk and show off some picts.
It’s a cut down of a Accord Wagon. I slammed the front end and added a bra and drop top envelope.
Here are some more pix, lemme know what you think.
May 24, 2002 at 6:15 am #14055
that’s an awesome convertible, did you lowered the front? if you did, how did you do it? btw, your travel case is really cool too…..
May 24, 2002 at 6:29 am #14060
hehe thanks.
yeh, I lowered the front end by cutting a similar sized notch just above the original notch on the front end. It makes the back end look raised but it really isn’t. I tried lowering the back end but I would have to increase the rear tire well for clearance. If I can find a way to use wider tires, my next mod will be flairing out the wheel wells.
May 24, 2002 at 9:02 am #14072
Great Mod Gigabite,
Did you use modeling putty to patch the back area and make the “envelope” ? cool profile too.
May 24, 2002 at 9:58 am #14073
Really cool modification.
And what can I say, my hats off to another MAC person.
-Floyd
May 24, 2002 at 10:07 am #14075
Hey i was wondering if you could go more in-depth on the lowering of the front cause thats pretty bad ass and i dont understand what you mean with the blunt description up above. I would greatly appreciate it. Dave
May 24, 2002 at 11:17 am #14079
Dirk_Gent: Actually, i used supplies at hand. I filled in the rear deck with a hot glue gun. I gooped it in, used a heated Xacto blade to slice as much excess as possible. Sprayed w/ some primer I had for my real car. and painted it. The leather interior, leather convertible top envelope, and Leather bra is made of….Black electrical tape!! hehehe…
Floydski: But of course! and a cool place to hostonline images without ugly banners or restrictions. Mac.com just rocks my socks!
David: The front end of the chasis has a tab. the front end of the body has a slot. What i did was take a hot knife, cut a similar slot above the existing one. You will probably cut thru the body, but I just patch it with a dab of putty. You can do the same w/ the rear end but you will find that there isn’t enough tire clearance.
May 24, 2002 at 2:28 pm #14081
? And what can I say, my hats off to another MAC person.
?-Floyd
Awesome! Count me as the third..been a Mac man since I was 4!
