PN Racing Anima motor
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › PN Racing Anima motor
- This topic has 12 replies, 5 voices, and was last updated 20 years, 5 months ago by
dgs73.
April 30, 2005 at 4:25 pm #12627
I gots one!
Very nice! First thing I noticed was how quiet this motor is. I m just used to the “plane on the runway” sound of the plasmatomic, lol…
Also, this motor has a very smooth acceleration, great for smaller track, aka my driveway.
I will be testing this motor against my plasmatomic (neo) and my S03 soon and I ll let you knwo how it goes.
Bottom line so far is that, if you want a fast, efficient motor, get this baby.
I ve got a new charger that also doesn motor breaking in. During the motor break in for 10 minutes. At 2.4v the Anima had settled into 0.83A drain. For the same time (10minutes) with a plasmatomic break in it was around the 1.43A. So you can see that the Anima doesn t suck the juice like the plasmatomic.
more to come,
cheers,
April 30, 2005 at 5:39 pm #59424
Good to hear a review of this motor finally, Thanks:smiley2:
May 11, 2005 at 6:56 pm #59507
this anima motor is the one that can work with stock z s right?
can you compare it with a stock kyosho x-speed if you or betty have one ph2t?
im interested in hearing about it as the spaces i run my z’s are all pretty tight and i find my kyosho x-speed to be the best motor ive ever had in terms of reliability, long runtimesand performance.
May 11, 2005 at 7:30 pm #59511
I second that motion. X speed again proved itself down at Meadowbank on Sunday too… who says you cant go fast with stock(ish) motors? Just quietly, my 01 with a 10 tooth and X speed is slower than my 02 with 9 tooth and X speed. Odd, and not just a little bit slower too. Alot. And that 01 is fast for an unfetted car
May 11, 2005 at 7:39 pm #59512
quote:
this anima motor is the one that can work with stock z s right??can you compare it with a stock kyosho x-speed if you or betty have one ph2t?
im interested in hearing about it as the spaces i run my z’s are all pretty tight and i find my kyosho x-speed to be the best motor ive ever had in terms of reliability, long runtimes?and performance.
No Z,
The Anima and Sabre motors require a fet or turbo mod, Your thinking of the SpeedyNM or the So5 :smiley2: -
May 11, 2005 at 8:12 pm #59514
I think because you were running Sanyo 900 s in the 01 is where the difference was Dave…
I know what you say about the 01 being on rails, the 02 looked to me to be on rails also…Its otNa aconBa
May 11, 2005 at 8:19 pm #59515
so whats been done to the mr02 dave?
still want to take my Z s out for a run!!!
[/quote] -
May 11, 2005 at 8:31 pm #59516
02is unfetted too (and willstay that way…), add to that the motor in the 02 is as yet not broken in, so i d guess there’s a tiny bit more speed to be squeezed out of it yet. Pete; yes, Sanyo 900s in the 01, and Sanyo 800s in the 02. What you saying anyway dude? Now that i’ve put it like that it seems the 800s were getting better performance than the 900s, hence the greater speed in the 02. Less powerful batts., one less tooth on the pinion, and an unbroken in motor.My 01 should have eaten it alive. I’ll be sticking with the 800s, me thinks. TD; track will be out again this Sunday, you guys by chance NOT racing at Tempe this week?
May 11, 2005 at 8:45 pm #59517
sorry tempe racing this Sunday
i can do next sunday plus if there is racing at castel hill next friday ill be there if you guys are going.
let us know if ur going on the firday and want to race on the sunday.
May 11, 2005 at 9:06 pm #59518
thanks pete!
quote:
Quote:I think because you were running Sanyo 900 ”’s in the 01 is where the difference was Dave… I know what you say about the 01 being on rails, the 02 looked to me to be on rails also… Its otNa aconBai thought that the higher the rating the longer the runtime, i.e. my 600mah batts allways go harder than the 700mah and especially the 800mah batts. but the 800mah allways run for longer than the 600mah rated batts..
i think thats what petes getting at dave.
May 12, 2005 at 1:09 pm #59521
Z Beam; yeah, I knew that. We had a chat about it last night, he thought i had the 900s in the 01. But it was nt the runtime, it was the performance. Is there a trade off in that respect (ie. punch vs. runtime)? Hope that made sense dude… TD; every friday mate, so yes will be therenext week.
May 12, 2005 at 3:50 pm #59522
in my observations yes there definatly is a trade off. ask me to explain why and id be lost for words tho…
remember how tomy bcg s came with ni-cads installed, then the whole rave about ni-mh’s came around and well they didnt make the car go any harder really on the SAME charge as standard batts. they could take a longer charge because of the higher mah rating (double charge) but in the end overall the nimhs never had the overall power of the lower rated ni-cads…
but then all that could be a bad example because im comparing 2 types of battery…
May 12, 2005 at 4:16 pm #59523
yea, it s got me baffled as well… not what you just posted, but the earlier point
