Powertech nimh aaa batteries
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Powertech nimh aaa batteries
- This topic has 21 replies, 8 voices, and was last updated 21 years, 9 months ago by
dgs73.
April 2, 2004 at 4:57 pm #12074
for those of you that use them, Powertech nimh aaa batteries from Jaycar will be available in 900 MaH from approx. two weeks time…:D
April 3, 2004 at 3:41 am #50367
Yeah they are good stuff, I have been using the 800 AAAs and the 2000 AAs. Using a delta peak charger they usually take more than their rating as well.
April 3, 2004 at 3:41 am #50568
April 4, 2004 at 6:40 am #50370
….as all good cells should. 10% above the label is normal.
April 4, 2004 at 6:40 am #50571
April 4, 2004 at 7:11 am #50371
I got those GP 750mah nimh’s and I’m happy with them as well… I dunno about the batt’s you mention here but the GP’s have air holes at the +VE end that seem to let “gas” escape if the batts overheat or are pumpe too hard with current…..
April 4, 2004 at 7:11 am #50572
April 4, 2004 at 5:04 pm #50374
Those vents (whether you can see them or not) are what prevent all Ni-XX batts from leaking/ exploding during charging. But once they’ve vented, they’re stuffed.
April 4, 2004 at 5:04 pm #50575
April 5, 2004 at 2:58 am #50381
How much do they need to “vent” before they’re buggered? I’ve heard very faint noises once or twice but that’s it. I haven’t noticed a decrease in performance either….
April 5, 2004 at 2:58 am #50582
April 10, 2004 at 3:56 am #50694
Dont forget, the readings on a peak charger aren’t that accurate, you must allow for heat etc and other inneficiencies.
May 11, 2004 at 3:01 am #51377
Are the Powertech 900mah in yet?
Anyone tried them out?any good, any feedbacks?Can a Gp powerbank charge other Nimh batteries?
May 13, 2004 at 3:54 am #51412
yeah tim,despite what it says on the label it can charge other batteries
May 17, 2004 at 5:59 pm #51500
not in until the middle of next month, Tim. I dont think i’ll be able to tell the difference between 800’s and 900’s
May 17, 2004 at 6:01 pm #51501
I know initially I said two weeks, but that was information I was given at the store in the city at the time. Was at the Auburn store the weekend before last, and swears blind they’ll be in mid June.
May 17, 2004 at 9:35 pm #51509
Cool, thankz for reply anyway.
I’m GP fans but thoses batteries cost too much anyway like $3x for 4 750mah so i might try the Powertech 900mah to see if their better or not -
May 17, 2004 at 11:14 pm #51517
I think the powertech are more expensive like $3.35 each for 800mah.
May 17, 2004 at 11:50 pm #51519
but still 3.35×4 = $13.4!
and no shipping requires so overall is cheaper anyway -
May 18, 2004 at 1:46 am #51521
where from man?
May 18, 2004 at 8:23 pm #51550
Kevesta can you get us some from your friend of yours?
Read about that Sanyo batteries are like the best for mini-z
May 18, 2004 at 8:33 pm #51553
would’nt mind doing a comparison myself… anyone got these AND Powertech 800s?
