Pullback tyre modification
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Pullback tyre modification
- This topic has 31 replies, 13 voices, and was last updated 22 years, 2 months ago by
October 24, 2003 at 1:50 am #9809
Hi all,
I am about to put some wheels from a pullback onto my BGC.
Has anybody had any experience with this?
What should I look out for, and what problems have you had?
I had read the info on the BitPimps site, but any ground truth would be great.
Thanks. -
October 24, 2003 at 2:43 am #26402
A few thoughts:
Don’t bend the @#$%^ pins!!
Make sure the rear wheels are centred when re-doing the axle hole or it’s game over from too much wobbling.
Make sure you balance the width of the rear wheels so they don’t look lop-sided!
Otherwise, goodluck!
October 24, 2003 at 6:38 am #39090
And be careful not to bend the rear axel, they bend easier than you think and are difficult to straighten.
I think QFM has a tute on this, when you trim the rear wheels, use the extra bits on the front wheels to space them out from the knuckles.I just tried to link to the QFM site, have they shutdown??
:)uA
October 24, 2003 at 7:09 am #26262
lol ph2t speaking from experience me thinks. The wheels will stick out a bit due to the gear on the left side of the car. So don’t cut the @#$%^ hub of the right rear wheel too short.
Personally I think the wheels stick out too much, but I guess it all depends on which body you put on top of it.
One more thing carefull not to push the axel (metal) right thru the wheel (plastic) when you are putting the wheel back on.
October 24, 2003 at 2:52 pm #26198
This mod is really only for looks, the tomy red tyres have 10x more traction than pullback tyres.
October 24, 2003 at 7:45 pm #26085
yeah the rear wheels look good, but if you use the standard orange gears and with the added weight it is actually slower then using the faster gears and the tomy pink soft tyres.
October 24, 2003 at 8:07 pm #26091
Are the pull back wheels any wider than the stock ones? They look a lot wider.
October 24, 2003 at 8:16 pm #39080
yeah they are wider almost twice the width of the stock wheels.
because of this it gives them more stablity around corners, dosent cause that many flip overs.
October 24, 2003 at 8:23 pm #26082
wider and smaller.
October 24, 2003 at 8:25 pm #26083
TallduDe you beat me to the post again. I even kept that one short and to the point:)
October 24, 2003 at 8:28 pm #26084
hahahahahhhahahahahaha
:p
what can i say i got a gift, just kidding :smiley2:
October 24, 2003 at 8:44 pm #26154
I found that after a while the stock tyres got hard and split. I don’t mind because they are cheap to replace. Has anyone had this problem with the pullback tyres? They will be a bit harder to find new ones – I would have to buy a whole pullback again.
October 24, 2003 at 8:53 pm #26156
No I haven’t had any problem with the tyres. But I do have a few and seldom use the pullback itself. I mainly bought them for the bodies.
Edited by – Impreza on 24 October 2003 16:53:27
October 26, 2003 at 3:33 am #25876
Here is some info about pullback tires :
measurments
front 5×12 mm (stock 4×12)
rear 6×12 mm (stock 4×14)
with tires onBecause pullback rear being smaller than the stock ones, you automatically gain higher gear ratio, so the car is slower than with stock wheels.
here are the “real” gear ratios for pullback wheels
-from 1 : 12 you get 1:14
-from 1 : 9.86 you get 1:11.5
-from 1 : 8.25 you get 1: 9.62As you can see the green(fastest) gears on pullback wheels are very little faster than orange gears with stock tires.
I think that sponge rubber should be the best for tyres. You know that black rubber which is used for cheap mousepads. Similar rubber can be bought in some stores and I`m planning to do something with that. I must just think of the right tool for making tires …. Diameter 14 of course ….
October 26, 2003 at 3:38 am #25877
GOod suggestion matic about the sponge rubber.
These will be good for tyres. They are just like the sponge tires used on Tamiya Mini 4WD Racers.
They also as a shock absorber. Just have to find the size that fits BCGs. -
October 26, 2003 at 9:59 pm #25888
Can anyone tell me the easiest way to remove the pin from the front wheel of a BCG, as I’m half way thru the same mod.
October 27, 2003 at 12:44 am #25895
Leonli17, let me know if you find the right size tires. I have an old Tyco mini slot car which has cool sponge tires but diameter is only 10mm… Maybe slot cars are the answer …..
About removing front pin:
Take a surface with the 3-5 mm hole. place the wheel side on it so the head of the pin is above the hole then use a small pin or nail (diameter LESS then 1.2mm) and small hammer to punch axle out.
Or you can sink the knuckle in the boiling water then pull out the axle with pillers. -
October 27, 2003 at 11:16 am #25859
I have used 2 pairs of needle nose pliers.
Or if you turn it over and hold it (like in a small vice), you can tap the pin out from the knuckle side.
Goodluck
October 27, 2003 at 8:39 pm #25824
I am intersted to see if anybody finds some sponge rubber that fits as treads.
October 27, 2003 at 8:59 pm #25826
Yes me too on this one. If anyone has had success finding something suitable please post it here.
The sponge will be the best tyre for these cars (just like the larger cars)but I dont know of anything that will fit….yet.:)uA
October 28, 2003 at 8:06 pm #26317
nothing yet but the pullbacks and alloys provide the best traction that I have noticed. I also find it easyer to mount the Super pullback tires as opposed to the regular gen 1 pullbacks
November 21, 2003 at 3:39 am #22563
OK, how have people got around the fact that the pullback rims (rear) have a bigger hole than the axle from the BCG?
Has anyone filled it with glue and prayed they weren’t wonky, or is there another method?
November 21, 2003 at 5:15 am #22487
im thinking of this mod on one of my spare chassis. i dont see how it changes the gear ratio at all, after all you are changing wheel size, not the size of the gear on the axle. saying that, it probably doesnt change the ratio, the fact that the tyres are smaller means lower top speed or something.
November 21, 2003 at 5:32 am #22489
super max; i’ve never tried this but i’ve got an idea. put a little glue on the axle where the wheel will sit and hold it vertically till the glue dries. this should fatten the axle for a snug fit. then glue the wheel on. as i said i’ve never tried it before, but that’s what i would do if i was:8ball:
November 21, 2003 at 5:45 am #22490
Yeah right. Do you mean use a small amount of glue on the axle and the surface tension should make the glue have even thickness?
I will try it. If it doesn’t work it should be easy to clean up and start again.
Thanks BK -
November 21, 2003 at 5:52 am #22491
yep, that’s exactly what i meant. lemme know how it goes:8ball:
December 3, 2003 at 10:22 pm #20960
didn’t work so good – any other ideas?
December 10, 2003 at 1:58 am #43567
Here is a guide for the pullback MOD:
http://bitpimps.lixlink.com/pages/articles/article_postings.php?id=14&catId=4
And another: http://www.tinyrc.com/forums/showthread.php?s=&threadid=12568&highlight=pullback -
December 13, 2003 at 2:08 pm #38844
whoever says this mod doesnt ad any performance is obviously an idiot.
http://hogjowlz.lixlink.com/thud.wmv
Edited by – hogjowlz on 13 December 2003 09:10:04
December 19, 2003 at 6:47 am #38644
as for the pullback wheels, i did it once and it looks nice but the turning cicle got so crap. no good for track work. maybe i did it to tight…..
and the foamys… pengrips…. cut to size they work awesome on some surfaces but when multiple foam equiped cars colide the tires tend to lose their orientation. i have access to a wide range if anyone cant find them. PM me if interested. with out a shell the rounded balloon ones work well..
December 19, 2003 at 4:33 pm #38631
i got mine PERFECT on the knuckles and rear axle, problem is, i trimmed the axle 0.01mm too much! *dies*
an easy way to get the rear wheels centred on the axle is in a vice grip, dont use too much pressure though.
December 19, 2003 at 4:45 pm #38626
the pull back wheels are to damn wide, and really more drag=less speed.
