QFM Spring Suspension Mod?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › QFM Spring Suspension Mod?
- This topic has 12 replies, 1 voice, and was last updated 24 years, 2 months ago by
July 15, 2002 at 4:07 am #9069
Is the http://www.questformadness.com spring mod worth doing? does it actually do anything besides look cool? does it work better with the stabalizer bar or without.
Thanx
Matt
July 15, 2002 at 12:10 pm #14365
Seems to work better for me without the sway bar (stabius). I think it performs better, but you should really wait for feedback from other people who have done the mod simply because I run that site (http://www.questformadness.com) and my opinion wouldnt be appropriate.
Is it worth doing? I am a mod freak, so yes. But another person in another forum mentioned that it was a difficult mod because he had trouble reassembling the front end. Cutting the the tiny springs to size isnt that easy either. If you dont work well with tiny parts, this may not be the mod for you.
July 15, 2002 at 9:02 pm #14381
I have 4 boosters and the mod worked on 2 of them 45mhz and 35mhz, but messed up the steering on the 57mhz. Performance improved on the cars with the shocks.
July 15, 2002 at 9:10 pm #14383
Oh and B V CAREFUL with the springs… you drop it and it’ll bounces rightoutta site….
I found that cuttingONE spring intoEXACTLY 2 halfs fitseach car perfectly i.e use one spring per car…. KAPEESH??!!!….
July 16, 2002 at 3:19 am #14399
My steering diameter is now larger, but I shorten the “springs should improve that (not yet time for it)
But with this U maybe can make your bits turn left and right at the same distance !!
July 20, 2002 at 8:31 am #14527
Will this help my car go in a more straight path forwards and backwards? I’ve managed to adjust the steering trim knob thing at the bottom so that it goes in a straight line forwards, but it still *always* reverses to the left. Is there any other way to fix this?
July 20, 2002 at 12:47 pm #14533
It?s very straight now !! = )
BUT you gotta take your time to adjust the lenght of the springs !!
July 20, 2002 at 2:08 pm #14535
Cool, now I’ll have to find an easy way to get some springs…
July 20, 2002 at 5:09 pm #14544
im thinking of doing this spring thing also after reading this im fairly convinced;)
July 21, 2002 at 6:33 am #14556
You can buy the Gold plated springs at http://www.questformadness.com for $2 USD.Click into the Online Store.
July 21, 2002 at 11:07 am #14559
i have also found these springs in the Tomy AFX slotcar tuneup kit guys, just in case you feel you need these urgently and you have access to a shop selling these AFX goods. These are in Australian shops at about $AUS 4.00- $AUS 6.00, although you also get alot of other bits and pieces which may come useful in some way…
Cheers.
July 21, 2002 at 11:51 am #14560
Thanks Djinn! Just the kind of info I needed!
August 8, 2002 at 12:42 am #15150
they are back in stock at questformadness.com!
