question about booster
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › question about booster
- This topic has 8 replies, 1 voice, and was last updated 24 years, 3 months ago by
May 19, 2002 at 11:53 am #8943
Hello everyone, this is my first post here! I’m totally new to Bit Char-G’s. Just about to place an order for my first car (Nissan Gloria). I read another thread that said that the booster kit needs the 4band control to work, but can I use the 2.2 motor in the Nissan?
May 19, 2002 at 12:15 pm #13674
Welcome aboard, Maladroit! Hope you enjoy yourself and learn a thing or two from our little community!
The Booster Set cars definitely need the special 4Band controllers to make them operate. They use a different code set from the normal cars and, of course, need a controller with an “action” button (a third channel) to make them scream off into the distance :smiley2:
And yes – you can transplant the Micro B 2.2 across to your Gloria if you want some extra punch! All Micro B motors, as long as they’re fitted with the BLACK pinion gear, will go into any of the Bit Char-G cars.
Hope that helps. Cheers!
Derek
May 19, 2002 at 12:23 pm #13675
Thx for the answer… one more thing. The 4band control operates all Bit Char-G cars right? not just the booster ones?
May 19, 2002 at 2:44 pm #13681
Correct
May 19, 2002 at 3:00 pm #13683
Maladroit – yep, 4Band controller can control the standard other cars, you just need to flick the A-B-C (code set) selector switch on the back to “A”
Cheers
Derek
May 19, 2002 at 10:56 pm #13685
thx alot
May 20, 2002 at 12:09 am #13686
I got a similar question:
Can the standard controller control all frequencies, or just a single freq? I remember reading that one controler could be set to diffrent frequencies.. but I’m not sure if it was the Char-G controller or the Digi-Q controler? Somebody clear this up for me.
BTW.. I just ordered my first Char-G, a Nissan Gloria w/ 1.0 motor. Can’t wait for it to get here!!
May 20, 2002 at 1:16 am #13687
Dirk
The standard (rectangular ‘slab’) controller can control only a single frequency. You’re thinking of the Digi Q controller :smiley15:
Derek
(6.15am Monday….another working week about to commence….errrrgh!) -
May 20, 2002 at 5:13 am #13691
ah right..
Thanks Derek!
