QuickTip: Fixing the heatsink clip….
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › QuickTip: Fixing the heatsink clip….
- This topic has 10 replies, 6 voices, and was last updated 21 years, 11 months ago by
December 29, 2003 at 1:30 am #11977
This happens to me on most of my chassis and I m sure it happens to a lot of you guys as well.
The plastic clip on the motor assembly that holds the heatsink in cracks very easily after changing motors several times. Even if you have the Bit-Racer tool (comes in the GM-xx bodysets) you still can have this happen to you.
I ve found this fix a very handy one that works quite well.
1) Remove the heatsink and motor.
2) Drop a small amount of superglue on the cracked area, spread it around with a small piece of wire.
3) Do this to the top, side and bottom of the plastic clip, spread evenly.
4) Let this set for 30 minutes.
5) Sand back lightly to even out the surface, use 400+ grit sandpaper if you can.
6) Repeat 2 -> 6, 3 times. You can do more, I ve found 3 times is fine.All done! Use good quality superglue like Selly s Quicktite or something similar. Those crappy superglues that are $2 in those cheapo shops aren t worth the time….
December 29, 2003 at 2:22 am #49085
plastic cement is awesome for this job, as it welds the plastic together.
December 29, 2003 at 5:07 am #49089
Also a fine fuse wire wrapped around the plastic, just far out enough to miss the hole but not interfere with the mounting of the body shell, works well too.
December 29, 2003 at 5:16 am #49090
that’s an interesting suggestion micro, hmmm…
I was thinking of how you would apply a wire reinforcing frame to the plastic one, hmmm….
December 29, 2003 at 6:44 am #49091
yeah i have had this trouble with my cars but the one that really stuffed my car was the perfection heatsink.
December 29, 2003 at 3:02 pm #49093
Yes, you need to be careful with those, they work ok but are too strong for the thin plastic that they clip through.
If you bend them a bit before using them, they work ok.
December 29, 2003 at 6:49 pm #49094
brendan was that a aerodynamic heat sink?
and nice avatar…
December 31, 2003 at 10:27 pm #49100
neeed mosfett done asap
January 1, 2004 at 12:15 pm #49104
g’day soopergooman!:smiley2: welcome aboard.
if you want fet mods, go to micro amps fet mod page:http://members.dodo.net.au/microamps/index.htm
everything you need plus more. hope that helps:8ball:
January 3, 2004 at 6:09 am #49134
i received 4 perf.heatsinks in m last order and the gold ones had a stoopid wide fan shape clip,
the black and silver….perfection,especialy with that nice bending tip. thanx micro. -
January 3, 2004 at 3:11 pm #49135
i just broke one myself. i used super glue to stick a couple of bits of paper clip wire to the underside. have a look;
http://community.webshots.com/photo/104275236/108455901DpyIUl
the super glue is enough as ph2t suggests, but i just wanted to be sure:8ball:
