Reverse/Forward Speed Difference
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Reverse/Forward Speed Difference
- This topic has 11 replies, 8 voices, and was last updated 21 years, 11 months ago by
leonli17.
November 11, 2003 at 2:28 am #9610
Has anyone found that their bit goes backwards faster then forwards? Mine does this always. It becomes even more noticable as the battery is depleted… So.. Any thoughts?
November 11, 2003 at 2:48 am #24858
i,ve noticed a similar thing too. when ive just run the motor from the pcb and listened to it in forward and reverse, it sounded like it was reving the same both ways, so i’m not sure if it’s true but it certainly looks that way to me too:8ball:
November 11, 2003 at 3:39 am #24859
if i does i c no reason y u cant do a bit of a switch swap the forward and backward cables as well as the steering wires and hold the contorller upside down… .. or u can just swap the forward/baclward wires and then doe the same in then controler .. but that requires u to scrtch out conections and re wire them(waste of time)
November 11, 2003 at 5:21 am #24193
Why don’t you just turn the motor over?:D
Edited by – Super Max Power on 11 November 2003 00:22:02
November 11, 2003 at 2:22 pm #24194
cause then the foward button is backward and tha backward button is forward
November 11, 2003 at 3:00 pm #24195
i think super max is just gaggin’ with us. and if you don’t believe me try turning your motor over!! (nice one super max! hook, line and sinker!):D:8ball:
November 11, 2003 at 4:18 pm #38946
.. oh i thpugh he meant just to switch the motor wires
November 11, 2003 at 5:06 pm #38953
It’s easier to pull something than push it. This would explain the better performance when the batteries are close to dead.
November 12, 2003 at 12:03 am #23553
Yep, spot on ph2t. Even if you reversed the motor wires I think you would find the same things happening, although I havent tried it.
The circuit is exactly the same for forward and reverse, so there is no electrical difference.
If you lubricate the gears and the rear axel you will find the difference between forward and reverse reduces to almost nothing.
November 12, 2003 at 5:00 am #38971
I agree with ph2t. But when u just spin the motor freely(without the gears, just the motor in the car.) The noise still seems stronger when reverse. And that happens to every single car. Why is that???
November 17, 2003 at 2:43 am #22730
could b to do with the weight shifting to the back of the car since its a rear wheel drive.
November 17, 2003 at 5:56 am #22735
almost julz. you have it the wrong way round. when you go into reverse from forward, you are also braking, throwing weight to the front of the car, letting the drive wheels spin more freely due to less weight over them.
