settings to drift
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › settings to drift
- This topic has 9 replies, 5 voices, and was last updated 22 years, 5 months ago by
jamiekulhanek.
September 17, 2003 at 11:00 pm #11350
wat motor? or settings? or hop ups so u need to drift?
September 18, 2003 at 12:05 am #33621
an x-speed and 800mah batts will get ya started…
i find that inertia drift is easier, if not more effective than just booting it and trying to power drift…
September 18, 2003 at 12:17 am #33623
does more mah mean more power or longer time?
or does volts mean more power? -
September 18, 2003 at 9:01 pm #33939
volts is more power but batteries with a higher mah retain their “freshness” for longer.. so its more punchy.
September 19, 2003 at 5:56 am #39700
Think of MAH as the size of a petrol tank, the bigger the number the bigger the storage.
Higher voltage gives more power, but not all cells will hold voltage under load.
September 19, 2003 at 5:57 am #39701
I think the bog stock mini z with ball bearings drifts the best.
September 19, 2003 at 7:55 pm #33362
the stock motor doesnt really give that much “potential” if u know what I mean.. on a tennis court sized area, an x-speed and a big pinion is a must…
September 19, 2003 at 9:19 pm #33308
I find too much speed makes it spin out rather than drift, but im talking about concrete.
September 23, 2003 at 2:14 am #32733
All I know is that I have fitted a fairly large (largest I have) pinion to a stock motor, some NiMH 650mAhs and some medium foam tyres and the thing simply won’t drift any more.
OK the post is about drifting – but I actually found the profound lack of traction annoying … although I’m finding the turn too hard and flip the car trick marginally more annoying 😉
Tips to drift though…
Use a ball diff and “lock” it up so both rear wheels drive equally.
Use a large pinion (more torque to wheels to break traction easier)
Use hard tyres as they’re usually spin up on smooth surfaces unlike soft ones that tend to grip.
Use batteries with a high discharge rate
X-Speed motor does help but a good stocker will do good for starters…Also tighten up yourfront wheels so they don’t free spin much – that slows the forwards movement of the car and gives marginally more control 😉
September 23, 2003 at 7:23 pm #32279
trust me, the mini z will drift right after you drive it around for a few days and when the wheels collect dust. That’s what happened to mine. I usually drift by making the mini z go at half the possibl speed and just when I need to furn, I accelerate and turn in whatever direction I need to go. Works fine for my CLK-GTR
