solar panels
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › solar panels
- This topic has 13 replies, 8 voices, and was last updated 22 years, 9 months ago by
SurfmyStrat.
May 3, 2003 at 4:22 pm #10377
i was just thinking today, what if i take a mini solar panel from an old calculator and attach it to the spoiler on the back, so it slowly recharges the battery if your in the light driving. You guys think it would work, could it fry the circuits?
you are currently at: http://www.ausmicro.com
May 3, 2003 at 9:15 pm #32050
I have seen a solar bit racer on the net somewhere.
It used the solar cell to charge a capcitor and when it was charged took of and drove a few meters.
You would need a solar cell a little larger than just a calculator one I think. This guy was using one about 6cm x 10 cm.
Give it a try and let us know how you go.
May 4, 2003 at 2:24 am #32058
I do think it would work, but I think it would only extend the driving time a few seconds at most. Calculators don’t really use a whole lot of power.
May 4, 2003 at 11:23 am #32064
ill give it a try and see what happens, couldnt hurt.:smiley2:
May 5, 2003 at 7:00 pm #32020
You might wanna visit Dicko’s, they sell small photovoltaic cells for only a few bux. Might need one size of a creditcard to give you any noticeable improvement.
(probably kills your handling though)
May 9, 2003 at 6:04 pm #31699
what about replacing the batt altogether with a solar panle so that in the right light conditions you could race for eva
________________________________________________________
Bit Char-G 57mhz Booster Fairlady Z
MINI Z Wrx WRC 2000 This thing RIPS -
May 9, 2003 at 9:49 pm #31682
A better idea… Tamiya makes a little working model of the Honda Dream solarcar about 4″ long, its not very expensive (vs buying the solar cells alone).
Why not try graft your BCG’s mechanics to make the Dream into an RC model instead? 🙂
May 10, 2003 at 2:47 pm #31643
not a bad idea, but ive decided to drop the project, because as you micro_amps said there wont be enough energy from the panels, and i checked the cells arent cheap so… maybe someone else will give it a try in the future.:D
Edited by – SurfmyStrat on 10 May 2003 10:49:04
May 11, 2003 at 7:55 pm #31572
dickies solar panels are cheap shizzle!
they are crap recycled old broken ones this is why they are cheap! for there weight very inneficient.
a decent panel would give easy enough current to trickle charge a bits bat.nice idea, the surfmysolar mod.
good solition panda, you know your supplies well!!!
May 15, 2003 at 11:22 am #30680
the key is keeping it in direct light. if you can keep it in direct light you woiuld be in better shape.. why would you not just compltely run the car from solar? if its a issue of juice just slap on another panel. if the panels are getting good light and are producing their max output you should be just fine.
http://www.siliconsolar.com/unicells.htm
get some of the small ones.. or get some scrap solar cells this way you can play..
May 15, 2003 at 2:25 pm #30660Quote:A better idea… Tamiya makes a little working model of the Honda Dream solarcar about 4″ long, its not very expensive (vs buying the solar cells alone).
Geez panda i think we share the same brain lol…that is exactly what i was thinking when i was looking at one a few weeks ago, only problem the solar cell only develops 0.5 volts 🙁
Guys, a calculator solar panel will only develop a few mA of current, a bit uses over 100mAh….so i doubt it would have any benifit whatsoever.
May 15, 2003 at 4:38 pm #30672
:sad::sad::sad:
:dead::sad: -
May 15, 2003 at 5:04 pm #30676
Correction, it will make about a 1-3% difference in runtime (bout 8 seconds), but only in full sunlight :p
May 19, 2003 at 5:14 pm #30116Quote:Geez panda i think we share the same brain lol…that is exactly what i was thinking when i was looking at one a few weeks ago, only problem the solar cell only develops 0.5 volts 🙁
Calculator solar cells are useless for bits, they’ll never
power anything motorised. They may supply 1.5-3V (usually are
4 cells in series) but the current is microscopic.
Their current is probably not enough to even power the RX.No, I was browsing thru Dickos, and they’ve got a panel
that does 1.0V at about 100mA. Only drawbacks are
(1) its pretty big, about large playing card size and
(2) its not cheap… $20+.For that $ I wasn’t even interested in buying one to test,
and its mass won’t do anything to your BCG’s handling. :p
