steath dual cell
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › steath dual cell
- This topic has 25 replies, 9 voices, and was last updated 20 years, 11 months ago by
rashumble7.
October 13, 2004 at 9:55 am #12378
this is my lil sleeper
from tha outside it looks like normal single cell. even after the body is removedheres sum pics of it with dubble rims
October 13, 2004 at 11:57 am #56104
Looks good dude. I like the hood. I would get a thin guitar string for the antenna. That would make it more invisible. Plus the range would be better.
October 13, 2004 at 12:18 pm #56107
nice one! but it’s just too neat! can’t you hang some wire out of the cover or scratch it?:D:8ball:
October 13, 2004 at 5:26 pm #56115
haha thnx, ill take that as a compliment. i wus gonna do guitar string like my xmod but then i wouldnt be able to put in in my pocket
i realy want to do a fet updrade but im still pretty clueless in that dept. for these lil cars. i wish i knew how:sad:
Edited by – chino on 13 October 2004 13:28:04
October 13, 2004 at 5:33 pm #56116
nice ride man 😀
October 13, 2004 at 6:00 pm #56118
You could ask Micro Amps:smiley2:
October 13, 2004 at 6:13 pm #56121
chino, there’s a sh1tload of resources on the subject man, trust me….
http://bitpimps.lixlink.com/pages/phpForum/viewtopic.php?t=1778
and
http://www.bitmod.de/elektronikmods.htm#mosfets
prolly the best two links on the subject..
October 13, 2004 at 6:56 pm #56122
thx alot for tha links. ill to learn as much as i can. do i need new fet or jus positions and jumpers? man, i wish i couls read that language. ill try to figure it out with tha pictures. thx alot, thas the most help i got in 2 years, well that maade anykind of sense anyway
October 14, 2004 at 9:53 pm #56145
Pretty Spank ride Chino,i know those double wheels must give that thing some sick torque. But really you must tell me how you managed to cram those cells so neatly in a bit chassis.Because i too am working on a low profile ride that definately needs dual celling.
October 15, 2004 at 12:12 am #56146
i forgot where i got the smaller cells from but jus a lil trimming of the part the front deck screws down(only screw in the whole car) and it drops rite in. ad i have solder tabs solderd directly to the bottom charge conections
October 15, 2004 at 9:17 am #56150
Thanks a bunch chino. My lxx chassis has a stock 200AAA cell whithin i am hoping to dual it with a 50AAA cell. hopefully in the same setup you have, so it can fit in my lxx chassis thus accommodating my custom lo pro body. Excuse the foolish ? but when you say you used soldering tabs, is that conductive? and if so would it detach if the cell becomes hot?
October 15, 2004 at 11:33 pm #56166
If the solder tabs detached, well, that would happen right after the cell self destructed and the whole bit turned into a puddle of molten goop….doubt it would be able to melt solder…
October 16, 2004 at 3:59 am #56167
Thanks for clarifying that for me jamie, i think i will go with the tabs. once again chino, that is a sweet ride :smiley2:
October 16, 2004 at 12:24 pm #56170
Rashumble, doing a dual cell mod with 1/3AAA’s is quite a big job.
Unless you have a dremel, dont even think about it….
If you need a hand, add me jamiekulhanek(at)hotmail.com to msn if you have it…
October 17, 2004 at 2:24 am #56176
jamiekulhanek, Thanks for offering your help, i assume you meant add you to my IM. Do you have yahoo, cause thats what i use. But if not i will see if i still have hotmail IM. And i definately own a dremel, thats a must cant mod without that… Thanks again:D
October 17, 2004 at 5:34 am #56177
i’ve never owned a dremmel. closest thing i have is a cordless drill that smokes when used!:8ball:
October 17, 2004 at 3:34 pm #56185
trent, goto bunnings and pick up an OZITO rotary tool, for $59 you get the tool, telescopic desk stand, flexible shaft, 40 piece accessory kit and a carrycase, plus if you bugger it theres a 2 year warranty!:8ball:
October 17, 2004 at 4:51 pm #56186
lol betty, nice work on the z’d chino.
October 18, 2004 at 5:15 am #56198
😀 BETTY, thats some hazardous equipment your dealing with there.Lets just hope thats on your xmas list.
October 18, 2004 at 5:58 pm #56220
thnx alot ppl. a returned Zipzap i had got for free had suspention springs in the front instead of the see saw sway bar thing. i jus istalled the springs in my black 350z handled so much better. ive been wanted these sprigs for long time. does anyone know wut im talkin about? and if so, where can i get more? im thinking mybe the previous owner left them in there. i havnt checked at the new ZZ’s yet ut i woder if they all come with springs now.
October 19, 2004 at 8:37 am #56241
ok sry bout that guys. i jus got bak from radio shack and saw tha all the newer Zip Zaps come with front springs.
October 19, 2004 at 9:00 am #56243
I wasnt aware of that:approve:. Chino i need your help quick fast man, i’m am now attempting that dual cell mod, same set up. The cells,pos+ to neg
– are joined/soldered together and i know i have to solder the pos+ wire from the pcb to the pos+ terminal on the unjoined section of the cell that has another wire attached running to the pos+ tab in the chassis. My ? is where does the neg- /black wire from the pcb go, do i just leave it soldered to the neg- tab in the chassis or what. im stumped please help.
this pic was my instructions, if it shows up notice no wire coming from the neg- side, i’m assuming a wire does go there and to the neg-tab in the chassis. pic courtesy of Bitmod.tk.If the image does not appear try this.
http://tinypic.com/d8wspEdited by – rashumble7 on 19 October 2004 05:21:58
October 19, 2004 at 5:21 pm #56258
pretty easy, it hooks up jus like any other dual cell. so it can still charge the same way, except for tha fact ull have another battery atached to ur controller.
edit: oh yeah and rest the board in backwards
Edited by – chino on 19 October 2004 13:23:47
October 20, 2004 at 12:45 am #56264
Thanks chino, but after staying up all night and morning i finally figured it out myself, hopefully i didn’t fry the cells in the process. Stand alone charger in the works.
October 21, 2004 at 12:00 am #56278
cool. i may need sum info o that. i jus added another cell to my controller. seems to e workin jus fine.
anyway im goi to be tryin to get mor ZZs now that i know some of them come with front srings. i put them in one of my single cell BCGs now it hanldes great resrly spins out no matter how slippery or how dirty tha tires get. i can still dpin it out at will. now im able to do a rolling 360 and recover. zombie voice* “must get more springs” haha
cars i saw the springs on
-ford f150
-jeep -
October 25, 2004 at 1:39 pm #56405
No doubt Chino, ill take a few pics of the charger for you.
check this out chino
http://www.ausmicro.com/topic.asp?TOPIC_ID=2694&FORUM_ID=9&CAT_ID=2&Topic_Title=my+Edited by – rashumble7 on 25 October 2004 17:45:12
