Steering Problems
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Steering Problems
- This topic has 9 replies, 6 voices, and was last updated 22 years, 4 months ago by
dgs73.
October 11, 2003 at 3:16 pm #11459
I am a newbie and I need a little bit of advice. My BCG turns sharper one way than it does the other. I have pulled it apart and put it back together, cleaned and checked all I can see (even adusted the tracking bar underneath till I went mad). Any tips?
October 11, 2003 at 3:33 pm #29483
is it a BCG or a clone..? casue some clones r screwed constantly…
October 11, 2003 at 4:17 pm #29484
It is Genuine Tomy
October 12, 2003 at 4:57 am #29492
Let’s see. I guess it turns right more sharply than towards the left? Some stock cars do that somehow.
1. Open your steering assembly apart, check if the magnet is right in the middle.
2. Check if both front wheels spin freely.
October 12, 2003 at 11:41 am #29493
one more possibility is that one of the rear wwheels isn’t stuck on the axela dn instead rotates freely.
October 15, 2003 at 12:32 pm #30070
Thanks Leonli17,
I ripped the steering assembley apart (after braking one of the clips on the PCB cover). I found one of the coils wasn’t glued in properly. A bit of glue and when I finally got it back together it ran sweet.
Thanks again. -
October 15, 2003 at 1:40 pm #30071
SMP; those pcb lids are delicate, eh? Also, try adjusting the position of the steering magnet, that may help. If it turns sharp to the left, for example, shift the magnet to the right.
October 15, 2003 at 5:17 pm #28962
Dgs, a lot of people have told me to adjust the magnet – but it appears to me that the magnet is supposed to move??? Are you talking about how it is mounted in the bracket?
October 15, 2003 at 5:23 pm #28963
No worries SUper Max Power.
yes. it suppose to glue onto the bracket straghit in the middle. -
October 15, 2003 at 7:04 pm #28968
Adjusting (bending/straightening) the spring can also help straighten steering that doesnt work correctly.
:)uA
