Steering switches
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Steering switches
- This topic has 11 replies, 1 voice, and was last updated 24 years, 3 months ago by
July 28, 2002 at 7:54 am #9152
hi, i finally found a compact charg ge yesterday, but one ofthe stering switches in the controll have alredy been damaged, when its bressed it dosent click, i still works but it dosent feel right and often gets stuck. has anyone else had this sort of problem. If so how did u fix it.
Thanx In Advance
July 28, 2002 at 7:56 am #14741
i have this problem too. it doesnt click, and a simple jiggle of the controler will set it off. dont know how to fix this problem tho.
July 28, 2002 at 8:56 am #14743
Hello,
I had the same problem butI believe I fixed it yesterday. Open the transmitter case to remove the plastic control buttons. Using a hobby knife or similar remove the molding flash from the edges of the control buttonsas they catch on the transmitter case causing the control buttons to stick. My transmitter seems fine to date.
Cheers -
July 28, 2002 at 10:13 am #14745
i think my problem is abit more serious. its not the actual seethrough stuff thats broken, its those squares with black shaft buttons comming out. they seem to have no spring in them, or whatever makes them click. either that, or they are stuck
July 28, 2002 at 10:01 pm #14748
Hello,
“those squares with black stuff comming cout” are small microswitches;
these parts are a completely standard, you can buy them from any
electronics shop and replace them. The same microswitches are used in
mouse buttons, so if you have an old mouse you can scavenge them from
there. The replacement is quite easy to do.
July 29, 2002 at 9:11 am #14755
I have this same problem also.
Were you able to fix it?
July 29, 2002 at 10:02 am #14757
That happened to my Ferrari too. I’m using my 4 chanel multicontrol with it. I think that give a better feeling than the standar control.
July 29, 2002 at 10:06 am #14758
I might just buy a new controller then . 🙂
July 29, 2002 at 10:07 am #14759
Does the 4 channel controller do both 40mhz and 45mhzchar-g?
July 29, 2002 at 10:49 am #14761
Nope the 4 channel controller ONLY does 27, 35, 45 and 57Mhz – ie the Japanese market frequencies.
July 29, 2002 at 6:50 pm #14774
The remote control does not use a strictly tuned circuitry: you can replace almost any crystal with a different one without noticeable difference in range. That is, you can replace the 27MHz with a 49MHz crystal and everything will work perfectly.
July 30, 2002 at 9:41 pm #14819
chris- or someone with more expertise- can you post a howto on this ? I’d like to use my spare tomy controllers on the oems I have on hand which are all at 49mhz. I was unable to track down anythign that looked like a crystal I’m used to from larger scale rc, and I recall there WAS a note about the radios not using crystal-tuned channels, but rather a signal that overrides everythign ont he specific frequency.
-dan
