storage solution..
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › storage solution..
- This topic has 6 replies, 1 voice, and was last updated 24 years, 5 months ago by
April 22, 2002 at 2:53 am #8824
If anyone has an empty 50 cd spindle plastic “box” thing with a twisty lid.. the make great portable storage boxs with a liddle foam padding :).
I’d post pics but no cam heh.
Shard
April 22, 2002 at 6:14 am #13164
I wouldn’t have thought the controller would have fitted in too well around the spindle?
Will have a go tonight, Shard, and post some pick-shers tomorrow
Cheers
April 22, 2002 at 7:47 am #13168
This works too, but does require a small out-of-pocket investment:
http://communities.msn.com/TheAdmiralsLair/bitchargstorage.msnw
April 22, 2002 at 10:24 am #13172
Guy’s…. Like that add on the telly says, “think outside the square”… I realise that will have a spare empty spindle (or two…) lying around, but that really is a lot of effort…
I have discovered that the “Deeko” butter container (tupperware type stuff
) is the best sized container for transport…I also have a roll of 4mm foam I bought from Clark Rubber a few years back, this stuff is great for making damping mats to bung under your PC, if its on the desk, to not only protect
the surface of the desk, but also to reduce/eliminate the vibrations of the PC throught the desk!!!
I measured out a small rectangle and cut out the corners, and folded the piece into the Deeko… This looked fine, untill I realised I needed to cut out a bit for the antenna stub…
So here’s my “carry case”…
Sorry these pics dont have the clarity of the others, but this is a poor old DC20!
April 22, 2002 at 11:58 am #13173
yeah but what about extra parts :), not a lot of room in there hehe.
With a spindle thing you can just turn it upside down when you want to open it, there’s room for quite a bit :).
Shard
April 22, 2002 at 12:51 pm #13174
Deeko make a LARGE selection of containers…
May 19, 2002 at 9:03 am #13672
I use a fishing tackle box. Just make sure you have one that when the lid is closed, that all the compartments are completely close as well.
Cheap and available from Big W, Target
